Why are my tools too high?
ChasF04/06/2017 08:38:17
2 forum posts
I recently aquired a Myford ML7 lathe which is in good condition and as far as I know, pretty much as it came from the factory. I bought an inexpensive set of basic cutting tools (12mm) as all the tools that came with the lathe were too small, mostly 8mm. When I check the cutting height with the centre point they are all slightly too high, maybe about 1mm.
So do I have the wrong size tools or is there some adjustment I can make on the lathe?
Neil Wyatt04/06/2017 09:12:08
19226 forum posts
749 photos
86 articles
Hello Chas,
Welcome to the forum, they usual size for an ML7 is 3/8" or 10mm, shimmed up with thin metal if required.
roy entwistle04/06/2017 09:18:46
1716 forum posts
All my tools are 5/16 or 1/4 with shims stuck underneath
Roy
Rick Kirkland 104/06/2017 09:28:18
175 forum posts
Nobody seems to be asking why 8mm is too small for an ML7. I use down to 3mm square and 2mm round on my ML7. I'm intrigued to know why 12mm is needed and 8mm is "too small"
Clive Hartland04/06/2017 09:31:49
2929 forum posts
41 photos
Rigidity, my ML10 I use 12 mm tools as I machined off about 1.5 mm from the bottom. easy enough with milling cutter and the tool on it's side in the tool post.
Circlip04/06/2017 09:41:11
1723 forum posts
Perhaps a headstock riser is required? with right riser you could use 25mm tools?
Regards Ian.
Neil Wyatt04/06/2017 09:44:20
19226 forum posts
749 photos
86 articles
3/8" is the 'design' size, but I am sceptical that a Myford can deliver a cut heavy enough to cause issues with an 8mm tool.
JasonB04/06/2017 10:15:45
What toolpost is fitted to the machine as they can determine the max tool size that will work and how the height is adjusted
Neil it also depends on how far your tool sticks out, a thicker one will be less prone to chatter as the tool overhang increases regardless of actual cutting load.
Rik, by "too small" the OP probably means to small to come upto ctr height
Edited By JasonB on 04/06/2017 10:19:39
jason udall04/06/2017 10:42:43
2032 forum posts
41 photos
My guess.
Op finds 8 mm "too small"..ie needs packing...
Bought in 12 mm notional tooling ( because the manual says 12 mm....being myford I would bet it said something "imperial")...
And then finds 12 ( are they all 12.00 mm?) too high...well sorry thats why we have shims...
One other thing...on machines with significant "dive" ie tendency for tool to dive under load we might set tool high to allow it to be at right height under cutting conditions. .. esp in carbide tools.
peak404/06/2017 11:11:54
2207 forum posts
210 photos
Whilst the tool capacity for the Myford toolpost(s) may be advertised as 1/2", it probably refers to using the "Boat" type tools which allow the toolbit to rock to allow adjustment in height.
If you're using 1/2" HSS blanks for rigidity, then just grind the cutting edge a little lower.
Obviously it's a bit more of an issue with carbide tooling, either brazed, or inserts. In this case you need to mill or grind a bit off the bottom to lower the cutting edge proportionally.
it's obviously less of an issue with the single tool holders where the base of the tool bit sits directly onto the topslide.
In my case, I made something similar to this many years ago. Obviously the issue is that the bit of metal below the slot for the tool needs to be of a suitable dimension to prevent it bending under load, and it's this thickness which restricts the tool height.
I got round this by losing that piece altogether and machining a plain rebate rather than a more conventional slot. i.e. there is no bottom to the LH edge of the toolholder. I then cut and welded a short length of ex-bed angle iron in place. This provides a very thin base to the toolholder, but it's still rigid as one now has a square hole for the tool, rather than a three sided slot. I can now use 1/2" tooling without issues.
Sorry for all the external links, but the relevant parts are on my other lathe 30 miles away, so I can't photograph them at the moment.
Mick Henshall04/06/2017 11:13:36
562 forum posts
34 photos
+1 for Clives suggestion to mill off a couple of mm from base of tool
Mick
ChasF04/06/2017 11:23:36
2 forum posts
Thanks for all the replies. To clarify a little, I thought, perhaps niaively, that the toolpost would be designed to accept a certain size standard tool without shims. I have a couple of 12mm tools that came with the lathe and have obviously been reground, that are pretty much spot on centre height so I bought a set of 12mm tools expecting the same result. I have used the 8mm tools with shims but find it quite a faff to get the height right - I understand people strip down feeler gauges to get the fine adjustment so I'll give this a go. Also I had thought that I would mill off the extra height to get my new cutters just right which would make them handy for everyday jobs and whilst I'm at it, I would make some accurate 1 piece shims to use with my smaller cutters.
Thanks again for all the advice, I feel I'm much better informed on the subject now
Edited By ChasF on 04/06/2017 11:33:27
Russell Eberhardt04/06/2017 11:38:45
2785 forum posts
87 photos
Posted by ChasF on 04/06/2017 11:23:36:
That's the best way to go. I would suggest even going down to 1/4 in or 6mm toolbits. Far less material to remove when grinding and with a solid packing underneath will be rigid enough.
Russell
Bazyle04/06/2017 11:54:05
6956 forum posts
229 photos
You do not need to use feeler gauge material for shims. It doesn't need to be that accurate for most turning until you get down to turning 1/8 or the very centre of a bar that isn't going to have a hole in it anyway. Just collect bits of thin aluminium, hard plastic (credit card), drinks can, paper even for the final thous. Cut to size and stick in a box, Then setting height becomes a ten second job and some people keep the shims with the tool using a rubber band.
Roger Baker 204/06/2017 12:31:24
16 forum posts
Hi Chas
If your tool is too low, face a piece of bar for a couple of mm then measure the remaining sprig. Shims of 1/2 that diameter will put your tool on centre. It may work the other way if too high but I havent tried it ( you will have to be careful that you dont knock the sprig off as the tool will be pushing into it.
Roger form OZ
Howard Lewis04/06/2017 21:16:32
7227 forum posts
21 photos
Shims can be made by cutting up biscuit tins, or sardine / fish tins, The material of often about 0.010" so makes for fairly accurate adjustment.
Coca Cola tins can be used, but you are starting with curved material, and being aluminium based, soft, and liable to collapse in the longer term.
Howard..
John Haine04/06/2017 22:08:53
5563 forum posts
322 photos
In my view, an essential accessory is some sort of quick change toolholder for the Myford, such as the Dickson type or clone. Then use 8mm tools, no need for shims, adjustable and repeatable height. Or make something similar, such as Mike Cox's here.
I bought a Dickson system when I got my Super 7, have never had a problem with tool rigidity down to 3mm sq.
John Reese05/06/2017 00:06:31
1071 forum posts
+1 for John Haine recommending a QCTP.
Before selecting a toolpost check the cost of extra toolholders. The Dickson toolpost is a fine tool but the price and availability here in the US is a show stopper. I have Aloris clones on my two lathes. I am highly satisfied with them. The Chinese made toolholders that fit them are inexpensive and quite satisfactory. The grub screws in those holders, however, are junk
john carruthers05/06/2017 08:32:37
617 forum posts
180 photos
I've superglued appropriate shims to each tool ready for use, saves faffing about every tool change.
mark costello 105/06/2017 17:00:07
800 forum posts
16 photos
Pallet strapping is thin and hard, 2 usual thickness, .020' and .025"
