SillyOldDuffer | 07/05/2017 17:16:01 |
10668 forum posts 2415 photos | Dropping a hammer this morning got me thinking about the dangers in my workshop. Actually, apart from scratches and the odd near miss, Model Engineering for me has been very safe. Or am I living in a fool's paradise? I think the single most dangerous tool I own is a woodworking table saw. On the metalwork side, I don't really trust the Grinding Wheel, and am careful not to burn the place down with a blowlamp. The lathe and milling machine are docile beasts, but I've had the pillar drill snatch a couple of times. The band-saw doesn't worry me at all compared with a Stanley Knife. I'm of the opinion that straightforward precautions make home metal working very safe even compared with something like Amateur Radio where chaps fall off roofs. However, ignorance and over-confidence cause accidents and I may be guilty of both. What tool or process would you consider the most risky in an ME workshop? Ta, Dave
Gray62 | 07/05/2017 17:26:57 |
1058 forum posts 16 photos | ME! |
Nick_G | 07/05/2017 17:28:41 |
![]() 1808 forum posts 744 photos | . Blunt tools that shouldn't be so. Nick |
Antony Powell | 07/05/2017 17:30:34 |
![]() 147 forum posts 19 photos | I once new a guy who ... sliced down his thigh - cutting gaskets with a stanley knife dance after dropping a 4 inch grinder between his feet whilst it was still running shatter his thumb when he hit it with a hammer badly gash his hand with a chainsaw (luck he didn't loose it, it was running) have more car crashes than anyone deserved And finally get sacked because he was a danger to everyone in the workshop especially himself !! Tony PS he was a nice guy outside work.
Journeyman | 07/05/2017 17:32:54 |
![]() 1257 forum posts 264 photos | No tool is dangerous! If you leave them untouched they will do no harm at all. Unfortunately as soon as you pick something up or switch it on you have imediately turned it into potential agent of destruction John |
Mike E. | 07/05/2017 17:39:16 |
![]() 217 forum posts 24 photos | The most dangerous tool is a brain that is tired. |
Mike Poole | 07/05/2017 17:52:23 |
![]() 3676 forum posts 82 photos | We are the most dangerous element in the workshop, personal protection helps to stop many accidents doing harm but I believe an accident to be a very rare thing. As many of us teach ourselves to use workshop machinery we miss out on the old hand showing the safe way to do things so we will have the accidents that should never happen if shown the right way. I think the drilling machine has the reputation for most accidents. The picture of a finger and all tendons pulled out of the forearm on the table of a drill has stuck in my mind for 44 years and I never wear gloves when using powered machinery. The photo of a small drill stuck in the lens of a friends safety glasses will always remind me to wear them on an offhand grinder. I think some of the shock and horror pictures and stories do stick in the mind and help to work safely. I have only used a surface grinder once since I was an apprentice but it sticks in my mind to start the wheel before turning on the suds and tun the suds off before stopping the wheel. It is amazing how much a dry wheel can soak up which will put it out of balance and possibly cause a wheel failure. Maybe we should have a thread of horror stories of how not to do things. Mike |
richardandtracy | 07/05/2017 17:56:05 |
![]() 943 forum posts 10 photos | The most dangerous tool in the workshop is me. Especially using the metal lathe for wood & having a lathe tool snatched from my hand, spun round the work, breaking the handle and then the point embedded itself through the lower wall of twin wall PC roofing. And stayed there. No injury to anyone, but one heck of a scare. Next for danger is the shaper. Loads of leverage, and moves slowly enough to seem safe to someone lulled into a false sense of security. Then the woodworking mitre saw. Regards Richard.
An Other | 07/05/2017 18:25:57 |
327 forum posts 1 photos | hand-held circular saw, even with all its safety guards. I hit an unseen nail once in a (new) piece of timber, which somehow caused the saw to be flung back towards me. This happened so quickly that the spring loaded blade guard had no time to close over the blade before the damn thing cut a six inch gash across the top of my knee. almost to the bone. (six stitches) It went in the dustbin, and I won't use one at all now - stick to the saw table or do it by hand. |
Matthew Reed | 07/05/2017 18:29:11 |
41 forum posts | I remember being told that the most dangerous item in a workshop was the clock: rushing things, not taking precautions, not thinking it through, running machines too quickly, or leaving things in a dangerous state, all because it needs to be done by a certain time. Perfectly safe equipment becomes dangerous when you are trying to get things done too quickly. To be fair, I am completely unaware of time when I am in the workshop these days. Most troubling aspects is the "thought you were only going to be 20 minutes, I've did all the washing up two hours ago" comments when I return to the world....... |
mike T | 07/05/2017 18:36:50 |
221 forum posts 1 photos | The band-saw. Pushing hard by hand, to cut some thick stock, suddenly the blade is out the other side and there is no longer any resistance to your pushing. Ouch! |
Brian Wood | 07/05/2017 18:37:05 |
2742 forum posts 39 photos | I have never used it because to me it was inviting disaster and probably serious injury and that was the ghastly horizontal table that was supplied with my metal cutting band saw. I shuddered when I saw it and scrapped it out of hand. |
Matthew Reed | 07/05/2017 18:57:07 |
41 forum posts | Putting things in perspective, probably the most dangerous thing in a typical old workshop was the ash tray. There will be far more deaths from smoking than machinery. |
JA | 07/05/2017 19:09:48 |
![]() 1605 forum posts 83 photos | Alcohol - I don't mean meths. I won't work after a drink. JA |
John Reese | 07/05/2017 20:06:20 |
![]() 1071 forum posts | Posted by Mike E. on 07/05/2017 17:39:16:
The most dangerous tool is a brain that is tired. True. Probably as dangerous as working drunk. |
mark smith 20 | 07/05/2017 20:25:09 |
682 forum posts 337 photos | I think all tools are dangerous if your unlucky or careless. I have a radial arm saw which are supposed to be notorious but never had a problem using it as yet. Worse accident ive had was when i was using a handheld router and the cutter went across my thumb but no lasting damage. Second worst a rotary table |
Jon Cameron | 07/05/2017 20:26:26 |
368 forum posts 122 photos | Posted by Graeme W on 07/05/2017 17:26:57:
ME! That was going to be my answer |
Tractor man | 07/05/2017 21:17:07 |
426 forum posts 1 photos | I learned the art of knife Grinding on a 30 inch diameter 8 inch wide stone which I sat astride on a wooden "horsin" so that the wheel was a few inches below my most valued possessions. If you ever thought about the wheel bursting you would never sit there. The man who taught me had a stone burst into three large pieces,one flew up into the horsin and threw him off, one fell into the trow of water and the third ended up in the next door shop thru a new hole in the wall. Crikey. |
Tractor man | 07/05/2017 21:20:24 |
426 forum posts 1 photos | All that recalling of Sheffield reminded me of old trade words that have now lapsed. One of my favourites was mousing, polishing a blade with a stone that made a smell like mouse wee. Time for a biting on before I do some cuckoo. |
Windy | 07/05/2017 21:22:44 |
![]() 910 forum posts 197 photos | An accident I saw when I first started work in the car trade made me cringe a work mate using a 7 inch sander before we started used the small air operated ones caught the edge of a panel wrong way. Oops it kicked back then his arm artery was showing another compressing a suspensions spring in a machine got it wrong another hospital case. Complacency and tiredness are things I've to be careful off it's easy to go down that route.
