petro1head | 07/04/2017 09:45:44 |
![]() 984 forum posts 207 photos | I sometimes find my chuck is a bit large for some of the work I do. I have a small Myford chuck and was wondering if its ok to hold that in the bigger chuck?
Russell Eberhardt | 07/04/2017 09:57:14 |
![]() 2785 forum posts 87 photos | Should be OK but remember that the run-out errors may accumulate. Russell |
mgnbuk | 07/04/2017 10:06:40 |
1394 forum posts 103 photos | The turners at work regularly hold a small 4 jaw in the normal, larger, 3 jaw as it is easier than swapping chucks. Nigel B |
Weary | 07/04/2017 10:09:41 |
421 forum posts 1 photos | Yep. Not an issue. I do it regularly when working on material too fine for large chuck.
Regards, Phil. |
Henry Artist | 07/04/2017 10:14:31 |
![]() 121 forum posts 46 photos | Depending on the size of the larger chuck you may also like to consider using a six sided collet block if you need to hold round stock...
petro1head | 07/04/2017 10:20:56 |
![]() 984 forum posts 207 photos | Thanks guys, good to know its ok. Those collet bocks also look like and interesting idea
Neil Wyatt | 07/04/2017 10:22:43 |
![]() 19226 forum posts 749 photos 86 articles | Avoid holding a steel bodied chuck in another chuck as they have been known to slip out with obvious consquences. Neil |
MW | 07/04/2017 10:44:59 |
![]() 2052 forum posts 56 photos | I would admit to having used the 2" sherline chucks in the outside jaws of a 5" 3 jaw chuck, and to be honest I expected to see a runout error of some sort but didn't notice anything unusual, it appeared to turn true by eye atleast. It's very handy to use for very small work pieces where the bigger chuck would crush the material. You just have to be careful not to damage the chuck you are holding.
Michael W Edited By Michael-w on 07/04/2017 10:58:21 |
mechman48 | 07/04/2017 10:45:49 |
![]() 2947 forum posts 468 photos | Posted by Henry Artist on 07/04/2017 10:14:31:
Depending on the size of the larger chuck you may also like to consider using a six sided collet block if you need to hold round stock... **LINK**
Edited By mechman48 on 07/04/2017 10:48:35 |
Ian S C | 07/04/2017 10:58:14 |
![]() 7468 forum posts 230 photos | Can't remember what the job was, but I held the 2 1/4" four jaw chuck from the Super Adept in the 8" 3 jaw chuck on my big lathe. Ian S C |
richardandtracy | 07/04/2017 11:02:48 |
![]() 943 forum posts 10 photos | With my ER32 collets I go down to 6mm, but sometimes need to hold stuff smaller than that. In that situation I use an ER11 collet chuck on a cylindrical shaft held in a 10mm ER32 collet. So that's a chuck in a chuck too. The whole ER11 range of collets & collet chuck on a shaft cost the same as 1 ER 32 collet. When drilling precise small holes using my milling head on the lathe, I use this method rather than use the Jacobs chuck (the Jacobs can't grip drills smaller than 2.9mm either). Regards, Richard.
Bazyle | 07/04/2017 13:17:10 |
![]() 6956 forum posts 229 photos | If you assess the runout of each chuck you should be able to rotate the smaller one to compensate it out. As mentioned above hard steel jaws will not grip well a hard steel chuck body. Interpose aluminium drinks can shim or perhaps rings of copper pipe bearing in mind that pipe is not extruded with even wall thickness. |
JA | 07/04/2017 14:06:32 |
![]() 1605 forum posts 83 photos | I would consider it as bad practice with conventional chucks. I was not taught not to do it (I doubt if my instructor had ever even considered the idea). I think the increase in overhang would be the major objection. Obviously mounting something like a lantern chuck (for shortening small screws) in a large chuck or collet chuck is OK. JA |
MW | 07/04/2017 14:22:10 |
![]() 2052 forum posts 56 photos | Posted by JA on 07/04/2017 14:06:32:
I would consider it as bad practice with conventional chucks. I was not taught not to do it (I doubt if my instructor had ever even considered the idea). I think the increase in overhang would be the major objection. Obviously mounting something like a lantern chuck (for shortening small screws) in a large chuck or collet chuck is OK. JA Yeah I agree with that, I was talking about small fixtures that you can hold in the palm of your hand, trying to hold a full bodied chuck inside another would probably be venturing into dangerous territory! I would say if you find you're making a habit of it, consider making a back plate adapter rather than "piggy-backing" the small one. Michael W |
Nick_G | 07/04/2017 14:41:03 |
![]() 1808 forum posts 744 photos | . I saw this done only today in a commercial workshop. A small 125mm 4 jaw held in a much larger 3 jaw. - The big 3 jaw was using soft jaws though so I suppose the gripping was better. I imagine it's one of those cases where "It ain't what you do it's the way that you do it" that matters.
Nick |
mick70 | 07/04/2017 17:35:18 |
524 forum posts 38 photos | Posted by Henry Artist on 07/04/2017 10:14:31:
lists two different nuts. which is better one to have? |
Neil Wyatt | 07/04/2017 18:07:01 |
![]() 19226 forum posts 749 photos 86 articles | Posted by naughtyboy on 07/04/2017 17:35:18:
lists two different nuts. which is better one to have? Ball bearing every time, and only 80 pence more. Neil |
mick70 | 07/04/2017 18:46:34 |
524 forum posts 38 photos | great cheers. |
duncan webster | 07/04/2017 18:49:48 |
5307 forum posts 83 photos | Posted by Ian S C on 07/04/2017 10:58:14:
Can't remember what the job was, but I held the 2 1/4" four jaw chuck from the Super Adept in the 8" 3 jaw chuck on my big lathe. Ian S C You could put the whole of a Super Adept in an 8" 4 jaw. |
mgnbuk | 07/04/2017 21:06:12 |
1394 forum posts 103 photos | You could put the whole of a Super Adept in an 8" 4 jaw To turn it into something useful ? Nigel B |
