Face mill
Sorry, yet another question
petro1head29/01/2017 12:01:20
984 forum posts
207 photos
After a face mill but not the fly type.
My axmisnster, Emco copy, has a M2 taper. Maching mild steel and aluminium.
What do you think the biggest dia my machine will handle?
Any views on the ones available from far east ie -**LINK**
Robbo29/01/2017 12:18:46
1504 forum posts
142 photos
The "real" Emco FB-2 manual shows a 40 mm dia face milling cutter, if that helps. 50 mm probably OK
Spurry29/01/2017 12:40:34
227 forum posts
72 photos
Posted by petro1head on 29/01/2017 12:01:20:
The item referred to looked fine, but I would be Very apprehensive about ordering with that amount of negative feedback.
If you do take the plunge, do let us know the result.
Pete
petro1head29/01/2017 12:46:57
984 forum posts
207 photos
Agreed re negative feedback. However this link was just as an example. This is better although not many sales http://www.ebay.co.uk/itm/MT2-M10-Shank-400R-50mm-Face-End-Mill-Cutter-10pcs-Carbide-Insert-APMT1604-CNC-/262770375002?hash=item3d2e55b95a:g:F0YAAOSwux5YWM3K  I always look for the best feedback, harder when buying from China tho, and best delivery
Edited By petro1head on 29/01/2017 12:49:14
petro1head29/01/2017 13:02:39
984 forum posts
207 photos
RDG do one - **LINK**
Tony Pratt 129/01/2017 13:15:07
2319 forum posts
13 photos
Posted by petro1head on 29/01/2017 12:46:57:
Agreed re negative feedback. However this link was just as an example. This is better although not many sales **LINK** I always look for the best feedback, harder when buying from China tho, and best delivery
PayPal should cover you if there are problems, obviously long lead time & will you get charged VAT on the Chinese ones?
Tony
mechman4829/01/2017 16:19:11
2947 forum posts
468 photos
I have one shown in Tony's link, I have a Warco WM 16 mill with a MT2 spindle & it has coped with what I've given it, nice on ally & brass, but I don't give it stupid doc's, your machine should be capable of handling it.
​George.
petro1head29/01/2017 16:36:51
984 forum posts
207 photos
Everything I have bought from China has been the price as advertised with no extra costs
Enough!29/01/2017 17:26:54
1719 forum posts
This thread prompted me to look at some of these.
Some are used with round (RDMT1003) inserts; some with rectangular (APMT1604) inserts. What would be the pros and cons of the two types?
Presumably the rectangular ones gives two cutting areas while the round ones give somewhat more? What else?
I could imagine that the round inserts give a better finish at the expense of depth-of-cut but I don't know.
Edited By Bandersnatch on 29/01/2017 17:29:40
John Reese29/01/2017 17:36:26
1071 forum posts
Round or triangular cutters will have near zero rake on the cutting face. APMT, APKT inserts have a positive rake molded into the insert and will have reduced cutting forced. I have two insert cutters, 2" diameter with APKT inserts and 3" diameter with SEKT inserts. The SEKT has high positive rake and takes less horsepower and feed pressure than the APKT. Downside of the SEKT insert is the 45 degree lead angle.
Raymond Anderson29/01/2017 17:54:01
785 forum posts
152 photos
Round Milling inserts of the type RDHX give a very soft cutting action. Designed for Aluminium but with common sense depths of cut / Feed rate will also handle most common steels of the type used by modellers.
Emgee29/01/2017 17:59:39
2610 forum posts
312 photos
Bandersnatch
Round inserts can't cut to a square shoulder without leaving a radius = to the rad of insert..
Emgee
MalcB29/01/2017 18:14:21
257 forum posts
35 photos
My friend has just recently bought a 160mm self centre chuck direct from China and ended up paying VAT. Almost as expensive as UK with the VAT.
I personally have bought items up to about £45 from China ( motorcycles and tooling suff ) but never got an extra VAT request. Never really spent more there.
Not sure if they just do random checks or if there are checks when weights rise like for a chuck.
Brian Oldford29/01/2017 18:56:57
686 forum posts
18 photos
Posted by MalcB on 29/01/2017 18:14:21:
It's even worse buying stuff from the US.
Edited By Brian Oldford on 29/01/2017 18:59:45
not done it yet29/01/2017 20:01:49
7517 forum posts
20 photos
There are a few things to consider.
Always seem to get the £8 collection charge (along with VAT added) if the parcel is bigger than 2kg (small parcel limits) and so delivered by parcelforce.
Anything over about £15, including delivery, can attract VAT (you can look up the actual limit).
Things often get pushed through at busy times, if you are lucky - just before Christmas for delivery can be a good time for getting lucky.
Often just pot luck if you get charged for smallish items at any time, unless someone, somewhere, notes multiple orders to the same addy.
petro1head29/01/2017 20:11:14
984 forum posts
207 photos
Well, so far, touch wood, I have never been charged any extra and bought items from Ebay and AliExpress
Muzzer29/01/2017 21:27:20
2904 forum posts
448 photos
Avoid using DHL for starters. They charge you a tenner if you incur any paperwork - on top of any vat and duty demanded by the IR. Freeloaders.
Enough!29/01/2017 22:41:24
1719 forum posts
Posted by Emgee on 29/01/2017 17:59:39:
Good thinking Emgee - I missed that one. And thanks for the other comments folks. I might just get both types and one arbor.
Ian S C30/01/2017 11:20:38
7468 forum posts
230 photos
I would get two arbors, once the head is fitted to the arbor, its best left there, infact I would have difficulty separating mine.
Ian S C
John Reese31/01/2017 04:34:32
1071 forum posts
Posted by Raymond Anderson on 29/01/2017 17:54:01:
Thank you. I was not aware there were RD style cutters. That opens some new possibilities for me.
