David Brown 9 | 18/11/2015 19:42:20 |
81 forum posts 4 photos | Hi, is it possible to cut through 16mm diameter round bar on a Sieg SX2 mini mill? I am not sure if it is iron or steel (I found it on the street a long time ago and thought it might come in handy!). How could I do this? It is not stainless steel as it is a bit rusty. I realise I need a metal cutting band saw but I don't have room, finding space for the mini mill was a struggle. I have an Evolution/Rage circular mitre saw but no way am I going to try to cut throught that thickness of metal with this, the sparks when cutting through much thinner hard metal are scary enough! David
JasonB | 18/11/2015 19:47:22 |
![]() 25215 forum posts 3105 photos 1 articles | Hacksaw works for me. I suppose you could make several cuts across the bar with say a 6mm milling cutter but seems a bit wasteful of metal and costly on cutter ware. If its short lengths then stood vertically in the vice and sliced off with a slitting saw is another option. |
Frances IoM | 18/11/2015 19:52:43 |
1395 forum posts 30 photos | Before I invested in a near essential bandsaw I had a cheapie (from Screwfix) Evolution/rage mitre saw with carbide tips - 40mm steel was easy (tho use it outside the workshop as throws metal even further than flycutting) - did struggle however on 20mm stainless (which I had to mill down on an SX1) - 16mm is no problem on an SX1 just slower (use a small slotdrill to progressively cut a channel |
John Haine | 18/11/2015 20:10:04 |
5563 forum posts 322 photos | Have you thought of using a hacksaw? 16 mm would only take a few minutes with a decent blade. |
Paul Lousick | 18/11/2015 20:44:18 |
2276 forum posts 801 photos | Use an angle grinder with a 1mm cutting blade. I have cut thru 50mm bar with one of these. Then clean up the cut surface on the milling machine. |
Roger Provins 2 | 18/11/2015 21:03:21 |
344 forum posts | I agree with John, just hacksaw it and it'll be done in five minutes. |
Chris Evans 6 | 19/11/2015 10:23:58 |
![]() 2156 forum posts | If you can control a hacksaw reasonably well then use "Allhard" blades. They last a lot longer than the generally available flexible ones. You will hacksaw 16mm bar without raising a sweat. |
colin hawes | 19/11/2015 11:06:48 |
570 forum posts 18 photos | An angle grinder, as Paul advises, is very quick at cutting steel bars and it doesn't matter how tough the steel is. I have a cheap one and it has done a lot of work. It's also a quick way of carving high speed steel toolbits to near the desired shape. I also use a bandsaw for most cutting off though. Colin. |
Mike Clarke | 19/11/2015 11:17:51 |
![]() 95 forum posts 2 photos | I'm always reluctant to use abrasive cut off wheels in the workshop as not keen on the dust sticking to my oiled slideways. Noisy too. I've cut many a 50mm slug off with a hacksaw - it's almost therapeutic and definitely good exercise! I find a little lubricant on the blade helps (tend to use Trefolex). Cheers, Mike |
David Colwill | 19/11/2015 11:28:02 |
782 forum posts 40 photos | Even though I have a bandsaw (getting long lengths into it takes some rearranging), I still find a hacksaw with a sharp blade is the goto tool for anything less than 25mm. As others have said sharp good quality blades are essential. Regards. David. |
Neil Wyatt | 19/11/2015 11:38:07 |
![]() 19226 forum posts 749 photos 86 articles | 16mm is an all in one go job with a decent hacksaw blade. When you get up to 2", take it in a few short sessions rather than all in one go. X2 will go through anything, if you take muiltiple cuts. Neil |
Bob Youldon | 19/11/2015 12:02:00 |
183 forum posts 20 photos | Hello David, When I first read your post I though you'd left a nought off and it should have been 160mm, but as many have suggested use a hacksaw, 24tpi X 12" blade, plenty of cutting oil, don't go at it too fast and keep your thumb out of the frame. When it comes to the larger sizes above 2" etc then a steady go with the hacksaw, turn the radio on, get yourself a comfortable stance, an 18 tpi blade, again plenty of cutting oil and away you go, it'll whizz through. My wife can't even cut bread straight, hopeless! Cutting things off straight is one of those aquired arts, me, I hate wood with a vengence! Regards, Bob |
Mick Henshall | 19/11/2015 13:14:00 |
![]() 562 forum posts 34 photos | Bob--my wife is exactly thr same with a bread knife, do they do it on pupose do you think just to get us blokes to do summat in the kitchen? Mick |
Ian P | 19/11/2015 13:21:21 |
![]() 2747 forum posts 123 photos | Posted by Mick Henshall on 19/11/2015 13:14:00:
Bob--my wife is exactly thr same with a bread knife, do they do it on pupose do you think just to get us blokes to do summat in the kitchen? Mick Have you actually checked that the correct breadknife is being used? They are made in left and right handed versions (I'm serious) and using the wrong one is a recipe for making toast of the bread! Ian P
mark costello 1 | 19/11/2015 19:23:18 |
![]() 800 forum posts 16 photos | Groan |
David Brown 9 | 19/11/2015 20:32:41 |
81 forum posts 4 photos | I will use a hacksaw, it didn't occur to me that 16mm isn't actually that thick!
David |
norman valentine | 19/11/2015 21:03:54 |
280 forum posts 40 photos | When I worked as a teacher of Design Technology I often had kids ask me if it was possible to cut steel. To them it was the hardest thing in their universe. I have watched many people using a hacksaw, brisk cuts (60 per min) and light pressure seems to be the way to cut quickly and accurately. |
John Rudd | 19/11/2015 21:54:18 |
1479 forum posts 1 photos |
Posted by David Brown 9 on 18/11/2015 19:42:20: I have an Evolution/Rage circular mitre saw but no way am I going to try to cut throught that thickness of metal with this, the sparks when cutting through much thinner hard metal are scary enough! David
I too have a Rage Mitre saw, the 14" tct bladed job......made for cutting through steel, I've used mine for cutting through 1/2" plate and 2" square bar..... Dont be afraid to use it and take your time.... |
Brian John | 20/11/2015 06:20:48 |
1487 forum posts 582 photos | I use an angle grinder with a cutting wheel but please do it outside as it can make a hell of a mess if you try to do it inside ! Obviously, you should always wear eye protection when using this tool. Edited By Brian John on 20/11/2015 06:21:37 |
Ian S C | 20/11/2015 09:54:03 |
![]() 7468 forum posts 230 photos | Use a hacksaw, take cuts at a steady 70 per min, but before you get set into your work, take a cutting stroke, just to see if the metal is soft enough to cut, if not either use the angle grinder, or the wheelley bin. Ian S C |
