Any one had experience?
Jesse Hancock 1 | 28/02/2015 10:43:48 |
314 forum posts | My question is to anyone who has experience with these Tee shaped verniers and would they justify the cost? Jesse. |
Windy | 28/02/2015 11:23:00 |
![]() 910 forum posts 197 photos | Are these what you mean **LINK** If so I use them a lot on my cylinder bores etc. you just have to be delicate when measuring with micrometer. |
Jesse Hancock 1 | 28/02/2015 11:33:31 |
314 forum posts | Windy would you say there are worth the price and less fuss than a blunt nosed vernier? If not I can't see the justification. John please excuse me for not putting pictures on here. I don't own a camera or phone which is equipped to transfer to my laptop, or at least I haven't found a lead as yet. Links I have tried but so far no success. Jesse |
Windy | 28/02/2015 11:49:44 |
![]() 910 forum posts 197 photos | I find them very useful for checking my cylinders for piston clearance and parrelism which is very critical on the flash steamer. For one offs a home made go, no go gauge might be of more use. |
Bob Brown 1 | 28/02/2015 12:33:55 |
![]() 1022 forum posts 127 photos | For small bores 0.4 to 1.4 I use this |
Emgee | 28/02/2015 12:44:17 |
2610 forum posts 312 photos | Hi Jesse I also use the telescopic gauges for measuring slots and bores. They are simple to use and you attain a feel when tightening, removal from the bore is achieved by tilting one end over. Measure over the gauge with micrometer or vernier, with continued use you will achieve repeatable and accurate results. Some other internal measuring aids shown in my photos, they were Emgee |
Hopper | 28/02/2015 13:01:05 |
![]() 7881 forum posts 397 photos | If you are measuring small holes, say half inch and under, the ball-type small hole gauges are much easier to use. And get the full ball type, not the cheapo half-ball rubbish that I fell for without realizing it. For the bigger stuff the T gauges take a bit of practice to get the right "feel" but work just fine if you have a gentle touch. |
FMES | 28/02/2015 13:18:44 |
608 forum posts 2 photos | Posted by Bogstandard2 on 28/02/2015 10:54:24:
Jesse, It would be nice for you to put up a picture or a link, as what you have decribed I couldn't picture in my head.
John Hardly surprising Bogs, ya don't see too many Telescopic Bore Gauges with a vernier scale on |
JasonB | 28/02/2015 13:24:02 |
![]() 25215 forum posts 3105 photos 1 articles | I've got one of the sets that ARC sell, at £13.50 I'd say they are worth the money. Don't use mine that often, mostly on cylinder bores or the hole in a casting to take a cylinder liner. You can feel if the bore is tapering once you get the feel for them and a blunt mosed veneer won't reach far down a 6" long bore.
J |
John Haine | 28/02/2015 15:03:42 |
5563 forum posts 322 photos | I think they are good, use them all the time for measuring bores. I got a nice Mitutoyo set at an MEX in a tatty plastic wallet, about 6 for a tenner, brilliant value! |
Tony Ray | 28/02/2015 15:14:53 |
238 forum posts 47 photos | I bought a set recently, I can now get decent fits whereas I struggled before. Best £14 I have spent recently.
Jesse Hancock 1 | 28/02/2015 15:16:44 |
314 forum posts | JasonB, very good point mate, hadn't thought of that. doh! Emgee, Nice selection of kit. I'm getting there. Thanks guys for your comments and tips. Jesse |
Neil Wyatt | 28/02/2015 17:24:28 |
![]() 19226 forum posts 749 photos 86 articles | I find them useful and accurate - the long handle makes it reasonably easy to get them at right angles to the bore. I set them so they can slip under pressure then moving them in the bore squeezes them to the right setting, then I tighten up a nip. They seem to be consistent to a thou. Neil |
John Stevenson | 28/02/2015 23:53:33 |
![]() 5068 forum posts 3 photos | I do a lot of bores in reclaiming bearing housings. Over the years I have convinced myself that I need to try a better / faster more accurate methods and have bought bore gauges, internal micrometers of 7,310 various types but always come back to these telescopic gauges.
I use then with a set of cheap digital verniers as they are so quick and give you a direct reading but when close I swap to micrometers as I love the digital verniers but do not regard them as an accurate means of measuring to a tight tolerance. |
Ian S C | 01/03/2015 01:56:15 |
![]() 7468 forum posts 230 photos | I got a set at a clearing sale, some one said that's a bit of a waist of cash(I hadn't used them before), they cost me $NZ 5, they get regular use, and I wouldn't be without them. With the end telescoped out a little larger than the bore, put it in the hole at an angle, straighten it up, there by pushing the end in as you rock it, tighten and remove at an angle. ( I know what I mean) Ian S C |
Paul Lousick | 01/03/2015 07:19:12 |
2276 forum posts 801 photos | These are a bit more expensive but eliminates the need for the correct "feel" required to correctly measure a bore diameter. Easier for us less experienced operators. Paul. Edited By Paul Lousick on 01/03/2015 07:20:03 |
Ian S C | 01/03/2015 09:55:46 |
![]() 7468 forum posts 230 photos | Paul, until I got the second hand telescope gauges, A bore gauge like yours was all I had used, mainly measuring cylinder bores in sizes around 5 inch. Ian S C |
Tony Pratt 1 | 01/03/2015 10:03:37 |
2319 forum posts 13 photos | Posted by Paul Lousick on 01/03/2015 07:19:12:
These are a bit more expensive but eliminates the need for the correct "feel" required to correctly measure a bore diameter. Easier for us less experienced operators. Paul. Edited By Paul Lousick on 01/03/2015 07:20:03 What do you mean by 'a bit more expensive'? Tony |
Paul Lousick | 01/03/2015 11:05:15 |
2276 forum posts 801 photos | Available on fleebay from $65 - $360. Depends on make and precision but includes a dial indicator. I had previously bought a cheap set of telescopic gauges and that's what I got. Cheep! Was not happy with them. Quality gauges are a different matter. Edited By Paul Lousick on 01/03/2015 11:10:08 |
Gordon W | 01/03/2015 11:20:15 |
2011 forum posts | What's wrong with calipers ? The old style stiff-jointed type I mean. Mine will reach about 4" down a hole and iare good for bearing fitting etc. after a bit of practice. I suspect that the same amount of practice is needed for the bore gauges. |
