Nick_G | 05/02/2015 14:40:37 |
![]() 1808 forum posts 744 photos | . I have a newish compressor. It's obviously of far eastern origin and I have seen the same one several times just with different branding on. (this one is branded Michelin) I 'think' it's this one :- **LINK** The original documentation that came with it stated that the original oil should be replaced after about 2 hours of 'running in' with one of ???? grade. But I cannot find that documentation. Has anybody any idea what oil would be suitable.
Cheers, Nick |
Jens Eirik Skogstad | 05/02/2015 14:53:00 |
![]() 400 forum posts 22 photos | Edited By Jens Eirik Skogstad on 05/02/2015 14:54:30 |
Jens Eirik Skogstad | 05/02/2015 14:54:49 |
![]() 400 forum posts 22 photos | http://www.shell.com/global/products-services/solutions-for-businesses/lubes/products/types-oils-lubricants/compressor-oils.html |
JasonB | 05/02/2015 14:58:35 |
![]() 25215 forum posts 3105 photos 1 articles | Pop down your local Machine Mart and get a 1lts or 5lts can, its got "compressor oil" on the lable |
Neil Wyatt | 05/02/2015 15:10:21 |
![]() 19226 forum posts 749 photos 86 articles | Sorry to hijack, but as the question has been answered, what sort of spec of compressor do folks use in their workshops? More to the point, what sort of compressor would suit the average user (i.e. one suitable for paint spraying and occassional light use for some air tools (say pumping up a tyre or a pneumatic wrench, not running an angle grinder or air hammer 24/7)? Neil |
JasonB | 05/02/2015 15:26:08 |
![]() 25215 forum posts 3105 photos 1 articles | The one Nick linked to would do that sort of thing like tyres or a cleaning blower. But if you want to use it a bit more often or run rotary tools then its worth thinking of a larger one as they run a bit quieter and only need to fill the tank occasionally. I have used one that size with a 1/2" drive impact wrench but its running nearly all the time so better off with something around the 8cfm FAD size or more |
Nick_G | 05/02/2015 15:34:17 |
![]() 1808 forum posts 744 photos | Posted by Neil Wyatt on 05/02/2015 15:10:21:
Sorry to hijack, Neil . You ain't as far as I can see. It's related and anything that promotes forum activity has got to be a good thing for the site / community. ....................... Right.?
Nick |
Nick_G | 05/02/2015 15:35:12 |
![]() 1808 forum posts 744 photos | Posted by JasonB on 05/02/2015 14:58:35:
I suppose that would be considered a good clue.
Nick |
pgk pgk | 05/02/2015 15:35:17 |
2661 forum posts 294 photos | Posted by Neil Wyatt on 05/02/2015 15:10:21:
Sorry to hijack, but as the question has been answered, what sort of spec of compressor do folks use in their workshops? More to the point, what sort of compressor would suit the average user (i.e. one suitable for paint spraying and occassional light use for some air tools (say pumping up a tyre or a pneumatic wrench, not running an angle grinder or air hammer 24/7)? Neil I bought one of the lidl 'parkside' compressors when I bought this farm. It was cheap enough (under £100) and quite apart from being invaluable for tractor tyre repairs, blowing out the chainsaw and running sanders and rust scalers it's small enough to park in the shed and blow rubbish off the mill and lathe. The tank's big enough that once it's filled itself I can turn it off and have enough air stored for swarfing ( switch on compressor, fire up laptop, light woodburner,put aay last night tools, switch off compressor). I;ve never used it for spraying but have no doubt that the right gun would be fine |
martin perman | 05/02/2015 15:37:05 |
![]() 2095 forum posts 75 photos | I use a 7.5 cfm compressor for driving small tools, an orbital sander, air gun, die grinder, snips, hammer gun and a nail gun for taking paint off of castings which does use up the air but I supplement this with a truck brake tank which extends the running time and also takes longer to fill but it doesn't bother me as its not regularly used, not used it for spraying yet. Martin P
Gordon W | 05/02/2015 16:12:55 |
2011 forum posts | I have a cheap (sub £100 ) one, it does most things well enough. I don't think they are good for spraying paint, maybe with oil and water traps fitted they would be OK. Good for oil , creosote etc. I have run air tools such as wrench and hacksaw but the motor is going most of the time. If I was starting out from scratch I would get a big one and use a lot of air tools. |
mechman48 | 05/02/2015 16:13:21 |
![]() 2947 forum posts 468 photos | I use a 7.5 cfm compressor from Machine Mart (bought on VAT free day, usual disclaimer ) for general use, one of my intentions is to rig it up for mist coolant system that I've got in mind for the mill & lathe plus a take off for running little oscillators, Stuarts etc. .. when I get round to starting them.. had the kits for over a year now, just never got round to starting them... The one I have... **LINK** A bit in the noisy side but does what I want it to. George. |
Bob Brown 1 | 05/02/2015 16:13:23 |
![]() 1022 forum posts 127 photos | Compressors are inefficient as most of the energy put in comes out as heat, as far as spec for a workshop, it comes down to what it is going to be used for. I have a 2.5hp belt driven machine which is a lot quieter than the direct drive machines although still not what one would call quiet. It will do all of the jobs I need it for but may be a little small for a large spray job or any serious sand blasting. Bob |
Clive Hartland | 05/02/2015 17:02:52 |
![]() 2929 forum posts 41 photos | The small compressor we have at work has the entry in the handbook, use ASE 30 oil, which to me sounds like normal engine oil. Makes a lot of condensation so needs regular blow out from the valve at the bottom of tank. If you do not blow down regularly the quick detach couplings soon fail as does the pressure switch. Clive |
Rik Shaw | 05/02/2015 17:31:25 |
![]() 1494 forum posts 403 photos | I have an ALDI special branded PowerCraft. 2.5hp and 25litre capacity compressor which I use mainly for blowing out work after machining. The handbook recommends changing the oil after 50 hours operation but although the machine is around two years old I am still in the "I'll get round to it sometime" phase. Recommended oil is SAE 15W/40. I have used it for sandblasting stuff - again with ALDI kit - and although it made the thing wheeze a bit, it coped. It's noisy but I'm married so it doesn't bother me! Rik |
oldvelo | 05/02/2015 19:08:01 |
297 forum posts 56 photos | Hi Go with a synthetic oil for your compressor for the best performance and protection. A bit more expensive than a straight mineral oil. Stay clear of motor oils for as there is no benefit in using a multigrade detergent oil.
Eric |
martin perman | 05/02/2015 19:55:24 |
![]() 2095 forum posts 75 photos | Several years ago I was given an old industrial compressor and tank powered by a 3ph 3hp motor, I acquired a single phase 3hp motor and fitted it and set it all up and switched it on, the motor was fitted with a centrifugal switch so run up reasonably quickly, no sooner was it running when my wife appeared at the garage door and said that her television had reduced its picture to a little white dot so we went in doors and found the TV working ok, so back to the garage and I started the compressor again to the tune of its doing it again, I never did tell her it was me causing the tv to go awol I just made sure I always had plenty of air and ran the compressor when swmbo wasn't watching her box.
Martin P Edited By martin perman on 05/02/2015 19:57:58 |
Jens Eirik Skogstad | 05/02/2015 20:59:28 |
![]() 400 forum posts 22 photos | Nick, after 2 hours running in and compressor oil is renewed, the next compressor oil will be renewed for each 50 hours and check/blow clean or change airfilter under normal maintenance. Empty water from air pressure tank periodically. |
Neil Wyatt | 05/02/2015 21:12:14 |
![]() 19226 forum posts 749 photos 86 articles | Thanks for the thoughts. John, I know what you mean, but I'm specifically thinking along the lines of an 'under the bench' machine for occasional use to solve a few awkward tasks, not a workhorse. Neil |
Bob Brown 1 | 05/02/2015 22:08:58 |
![]() 1022 forum posts 127 photos | Neil, May be you are thinking of something like this **LINK** , would be OK for a blow gun and small spray gun/air brush, mist coolant. Critical bit quiet noise level: 68dB. Bob Edited By Bob Brown 1 on 05/02/2015 22:11:11 |
