Free sources of materials.?
Add any ideas.
Neil Wyatt27/05/2014 21:16:39
19226 forum posts
749 photos
86 articles
Looks exactly like the overflow pipe I pulled out of our bathroom. Galvanised and until I got it ought I thought it was lead. I did manage to bend it, just. I haven't tried machining it yet.
"Bill Hancox"28/05/2014 01:54:34
257 forum posts
77 photos
All blindfolded darts at the bull. It is definitely the barrel from a Model 1847 Congolese Monkey Musket.
Ian Hewson28/05/2014 08:56:29
354 forum posts
33 photos
Hi
You need to get some of the modern yellow plastic coated gas pipe if you can, that machines beautifully.
Never seen a weld in it, got some short lengths when they were doing repairs around here, wish i had more.
Clive Hartland28/05/2014 09:35:59
2929 forum posts
41 photos
When they first started making and distributing coal gas for lighting purposes they used musket barrels joined up and sealed to carry the gas, obviously a bit hit and miss but cheaper that specially made gas tube. The way they keep digging up the roads to replace gas tubes I think they are still using the old musket piping!
Ian S C28/05/2014 15:01:21
7468 forum posts
230 photos
Mmm That looks like a handy bit of tube.
One of the tele co firms in Christchurch bought up the redundant gas supply pipes in the city, left them in place, and fed the optic fiber cables through them. Ian S C
martin perman28/05/2014 18:36:29
2095 forum posts
75 photos
The company I work for is Italian and we make very large to small industrial washing machines, these are made such that each machine was come in parts that will fit through a standard door and then assembled inside the room where they are required, certain sub assemblies arrive with bracing, all of the machines are made of high grade 306/316 stainless and when we have built the machines the bracing pieces are skipped, usually into the back of my van, as they are no longer needed. The biggest piece to date I have acquired was 6' long 6" wide and 1/4" thick with two small holes at each end, there are usually smaller pieces as well, we also throw away castors made of stainless with nylon wheels fitted with sealed bearing which I either pass on to friends to make skates with to move stuff around or I strip for the bearings etc, all of the above would otherwise be scrapped.
Martin P
mick7016/10/2015 08:23:05
524 forum posts
38 photos
picked up job lot of stuff from auction that included 3 electric tile cutters, used nvr switches of two, one on my ml6 myford and one to repair my belt sander.
guy at club took motor of one to make tool post grinder.
always take brushes out of motors.
microwaves are good for strong magnets.
ega19/10/2015 16:36:59
2805 forum posts
219 photos
I have just dismantled a 12' long window blind consisting of vertical slats that can be moved laterally and swivelled about their long axes. I was curious as to how when you pull the control cord the slats space themselves out automatically like so many squaddies taking up their dressing. It turns out that each slat has a length of spring steel attached with a hook at each end which connects to the adjoining slat - the same idea as the telescopic swarf guards one sometimes sees.
Anyway, I now have twenty or so lengths of spring steel c 4" long x 1/4" wide x 0.008" thick which seemed too good to throw away without first asking whether they are of any use to someone.
Incidentally, the swivelling is achieved by a very neat piece of engineering: a tri-lobed rod runs the length of the blind and engages in the bore of a tiny worm which in turn rotates a gear attached to each slat - rather like the feed rod on a lathe.
daveb19/10/2015 17:01:00
631 forum posts
14 photos
Posted by Clive Hartland on 28/05/2014 09:35:59:
I grew up in the east end of London, they still had gas lights (gas fed through musket barrels?) and bollards made from cannon from the Crimea.
mark costello 119/10/2015 18:38:37
800 forum posts
16 photos
History just drips from Your country!
Johnboy2519/10/2015 22:20:34
260 forum posts
3 photos
Rick.... That's not old boiler tube by any chance? It's just the wall thickness looks a lot thicker than your normal malleable gas pipe. I think gas/heating pipes have a high lead content which make its crap to weld. I can stand to,be corrected.😋
Ian Welford19/10/2015 22:28:37
300 forum posts
Next time you stop at Mcdonalds ( for the kids you know !) for a snack.
The coffee sticks make excellent epoxy stirrers and there's no limit to the number you're allowed!
Ian Welford19/10/2015 22:34:17
300 forum posts
Oops going senile I mentioned this earlier in this threadblush
Always worth asking about cardboard at department stores as we get rid of large ( 5ft by 3 ft) bits and it's great for templates etc. For the same reason if you know a printer it's worth asking for a few sheets of litho sheet ( thin aluminium which is great for shims etc).
Film pots 35mm are good for small amounts of oil, thinners for cleaning small brushes etc.
Nick_G19/10/2015 23:04:12
1808 forum posts
744 photos
Posted by Ian Welford on 19/10/2015 22:34:17:
Film pots 35mm
I saw one of those on antiques roadshow last week. winkwink
Nick
Danny M2Z20/10/2015 00:52:18
963 forum posts
2 photos
Next time you visit the dentist, if you ask nicely you may get a handful of these:
Shafts are 2.3mm, hardened steel and the small one (bottom right) is a diamond coated ball nose cutter.
* Danny M *
ian j20/10/2015 07:56:22
337 forum posts
371 photos
Posted by Nick_G on 19/10/2015 23:04:12:
Film pots 35mm
Nick
If you go to Boots The Chemist you an get a bag full ( take your own bag !) for free. Good for storing ER 25 collets.
Ian
Bruce Edney20/10/2015 08:15:25
167 forum posts
53 photos
Two of us model engineering types in Wellington NZ have just had the opportunity to strip a very large commercial colour laser printer - What a wealth of bits and bobs - shafts, bearings, 10mm flat aluminium plate, switches, stepper motors and heaps and heaps of metric screws and bolts
Photocopiers and large printers are great
Bring on the next one
This is a view of my workshop - Need to get to the scrap dealer this weekendimg_20151020_201216.jpg
Bruce
Paul Narramore20/10/2015 20:04:16
34 forum posts
6 photos
And I thought I was a hoarder. I got talking to a neighbour this morning who has recently retired but did own a breakers yard. He was telling me about all the old engineering lathes, milling machines, pillar drills, stainless and mild steel, etc, etc he used to break up for scrap. Had I known...........
mick7027/10/2015 10:25:53
524 forum posts
38 photos
old bike wheel spokes are good for thin rd rod.
also make good pointers and depth gauges.
also had some good bearings of bikes.
Howard Lewis27/10/2015 17:48:26
7227 forum posts
21 photos
Surely, you only put stuff in a skip as an absolute resort?
There is very little scrap metal in the world. Only when it is too small to hold for further work, or when it is already in small blue or brown curls!
My experience of rebar is that it is not nice stuff to turn.
Wish that there was space for all the stuff that "will come in useful one day", (Probably for my great grandchildren!)
Not tight, just careful, y'ken!
And I'not a Scot.
