Guess the Chemical?
Michael Gilligan28/07/2019 07:29:33
23121 forum posts
1360 photos
Posted by Robin Graham on 28/07/2019 01:05:53:
+1 for water - it's got to be nuts of Neil wouldn't have posted. Had a look at the MSDS for Cleanline deionised water:
Ingestion: Rinse mouth thoroughly with water. Give plenty of water to drink. Get medical attention if any discomfort continues.
Robin.
Whilst the statement appears ridiculous, Robin ... I believe that there is a safety risk associated with deionised water, due to the use of Sodium Hydroxide in its production.
Blue Heeler28/07/2019 08:46:11
342 forum posts
Not sure what Neil's is, but beware of Palmolive Shaving Foam !
Shaving Cream
Kiwi Bloke28/07/2019 09:36:07
912 forum posts
3 photos
If it's whisky - or indeed any other alcoholic beverage - I shall continue to use it in the manner to which I am accustomed, DIRE WARNINGS notwithstanding.
Geoff Theasby28/07/2019 09:50:58
615 forum posts
21 photos
Dave, small amounts of water added to red hot coke = Producer Gas? Some railway locos were designed to generate and use it.
Neil Wyatt28/07/2019 10:04:23
19226 forum posts
749 photos
86 articles
It's water...
I think the clue was " If breathed in, move person into fresh air. If not breathing, give artificial respiration. "
Clearly after that initial insight the person filling it in just went with the default low-hazard answers.
David Colwill28/07/2019 10:13:55
782 forum posts
40 photos
SECTION 5: Firefighting measures
5.1 Extinguishing media
Suitable extinguishing media
Use water spray, alcohol-resistant foam, dry chemical or carbon dioxide.
5.2 Special hazards arising from the substance or mixture
No data available
5.3 Advice for firefighters
Wear self-contained breathing apparatus for firefighting if necessary.
I had thought water but had ruled it out due to the above!
Regards.
David.
Frank Gorse28/07/2019 10:18:24
104 forum posts
I believe it’s also called di-hydrogen monoxide which sounds very nasty.
V8Eng28/07/2019 10:34:22
1826 forum posts
1 photos
I am very puzzled about extinguishing burning water (can it catch fire) using water perhaps somebody can explain that one?
SillyOldDuffer28/07/2019 10:35:23
10668 forum posts
2415 photos
Posted by Neil Wyatt on 28/07/2019 10:04:23:
It's water...
Very naughty of them. This excerpt from an MSDS for Water may be more typical:
Even though it fails to mention that asbestos burns in the nasty stuff, this MSDS is more exciting.
nerd
Robin Graham29/07/2019 00:03:18
1089 forum posts
345 photos
Posted by Michael Gilligan on 28/07/2019 07:29:33:
Robin.
Well, OK, maybe! I picked that at random because of its apparent absurdity which seemed to match Neil's example.
I'd be quite unhappy if I found harmful levels of NaOH in the deionised water I use though - it wouldn't really be deionised! The MSDS I quoted from gives a maximum pH of 9.0 which isn't too corrosive - the upper limit for potable water is 8.5 I think.
Apologies if I've got it wrong - I'll wash my mouth, or at least my typing fingers with soap (pH around 10) if so wink
Robin
Michael Gilligan29/07/2019 00:43:22
23121 forum posts
1360 photos
Posted by Robin Graham on 29/07/2019 00:03:18:
Well, OK, maybe! [ ... ]
Pedant that I am, Robin ... I did carefully use the term 'safety risk' rather than 'safety hazard'
... my logic being that although the product should be within spec. there is a specific risk associated with the process by which it is [presumably] manufactured. This appears to be recognised by the inclusion of reference to Sodium Hydroxide in that MSDS.
For what it's worth [admittedly not much in the present context], there is an outline of the production process here: **LINK**
http://www.tmasc.com/di%20water%20specs.htm
Robert Atkinson 229/07/2019 07:48:36
1891 forum posts
37 photos
A bigger risk with distilled or DI water is mixing containers. Many years ago I worked for a small airline on an island and we did frequent compressor washes of the turboprop engines but were still having sulphidation issues on the blades. The washes used distilled water bought in large containers from a local supplier. Turned out that their main market was the motor trade and they were not fussy about cross contamination between battery acid and water.
I found out when asked to pick up an order from Boots as I was going into town. My little car was totally filled with 2l bottles of distilled water. When I found out what was going on I suggested an Elgastat deioniser. It took a bit of convincing (DI could strip ions from the blades but as we added a detergent to the wash this was moot) but they changed to DI and had no further issues. It also cured the high failure rate we were getting with the "wet" NICAD aircraft batteries.
Robert G8RPI.
SillyOldDuffer29/07/2019 09:20:32
10668 forum posts
2415 photos
Curious 'fact' I picked up somewhere is that drinking nothing but de-ionised water for too long is unhealthy. Something to do with kidneys requiring trace ions to function properly. I also believe drinking water made by bulk de-ionising sea-water has salts added back before being piped to customers.
Can de-ionised water damage kidneys? Now I've read my own post again I have doubts...
not done it yet29/07/2019 09:30:42
7517 forum posts
20 photos
Posted by SillyOldDuffer on 29/07/2019 09:20:32:
One’s blood electrolytes would come under severe strain in that scenario. Only true if the person was not eating anything else at all, I would suggest, as there are loads of ions in most foods (too much salt in many!)?
Nicholas Farr29/07/2019 11:14:40
3988 forum posts
1799 photos
Hi NDIY, might be worth looking at this **LINK** scroll down to Health effects of drinking purified water, also this **LINK** I think the main concerns are that the deionised water may strip your body of important minerals over time.
Regards Nick.
Martin Kyte29/07/2019 11:51:43
3445 forum posts
62 photos
Toxic in large quantities if ingested (Brain swelling, fits, coma, death)
regards Martin
not done it yet29/07/2019 11:52:56
7517 forum posts
20 photos
Posted by Nicholas Farr on 29/07/2019 11:14:40:
Regards Nick.
Hi Nick,
This bit from the first link really sums it up, I think.
Quote ”This results in demineralized water, which has not been proven to be healthier than drinking water. The World Health Organization investigated the health effects of demineralized water in 1980, and its experiments in humans found that demineralized water increased diuresis and the elimination of electrolytes, with decreased serum potassium concentration. Magnesium, calcium and other nutrients in water can help to protect against nutritional deficiency.” Unquote
Not proven (either way?) and as I indicated, there are plenty of minerals in a proper, balanced diet. I’m most certainly not “nutritionally deficient”. Are you?smiley Somehow I doubt that would be the case for the vast majority on here.
Some Scots must be quaking in their shoes - well at least those that live at altitude and drink run-off from granite rocks - long before it has chance to collect lots of minerals.
De-ionised water might be classed as a ‘junk’ drink. Perhaps like a lot of the ultra-processed junk some people eat?
I would suspect that the ‘five-a-day’ would likely counteract any mineral loss without needing extra protection via the water one drinks.
But it seems clear that you must be agreeing with me - that it is blood electrolytes that are the problem, not the kidneys directly?
Regards, NDIY
Edited By not done it yet on 29/07/2019 11:56:13
JA29/07/2019 12:25:45
1605 forum posts
83 photos
Is drowning a health risk?
Robert Atkinson 229/07/2019 12:40:16
1891 forum posts
37 photos
A weird one is "Smartwater" from Coke where they distil perfectly good British spring water and then add Calcium Chloride, Magnesium Chloride and Potassium Bicarbonate back in! For starts if you are going to distil it why use spring water rather than tap water?
Bizarrely (to me anyway) people buy the stuff. I guess they are the same people who pay 3 to 4 times as much for the same painkiller or other medication with a fancy name and packet as the generic version. I just checked Boots website Neurofen 200mg tablets 14p each, generic 3p each. Neurofen is more than 4.5 times the price).
duncan webster29/07/2019 12:52:55
5307 forum posts
83 photos
Many moons ago the New York health authority tested various brands of bottled water for purity. The best was the stuff that comes out of the tap at very little cost. Just shows the power of advertising
