Member postings for Frank Gorse
Here is a list of all the postings Frank Gorse has made in our forums. Click on a thread name to jump to the thread.
Thread: Use of coal, oil and fossil fuels
03/08/2023 10:23:04
It’s a line from another Python song that keeps playing in my mind- “pray that there’s intelligent life somewhere up in space ‘cause there’s beggar all down here on earth”
Thread: Moths
12/07/2023 19:24:19
I think that’s a question for a naturalist rather than a naturist.
Thread: What did you do today? 2023
27/06/2023 14:04:06
Don’t know anything about the other stuff but ,if it is JK, spraying glyphosate on it is worse than useless. It’s a major industrial process to get rid of it. Luckily for you it sounds as though it is your neighbour’s estate who would be responsible for the cost.
27/06/2023 10:48:05
That weed also sounds a lot like Japanese Knotweed. If it is you have a problem, not from seeds but from the root system spreading underground. You really need to identify it without delay.
Thread: Titanic submersible
22/06/2023 20:38:56
Never used the “ignore member” button till now but don’t want to read anything else fulmen has to say
Thread: No longer a free postage threshold at Arceurotrade?
12/05/2023 19:07:00
I placed an order with CuPalloys on Wednesday night,had an email at 0826 next morning to say it had been posted and it arrived via the much maligned Royal Mail around midday today. 10/10 to both organisations.
Thread: Increasing Machine Tool Height for Improved Ergonomics
09/04/2023 17:32:30
I tried digging a hole in front of the machine Andrew but it just filled up with swarf.
09/04/2023 17:25:31
I’m about the same height as you Jelly and I know I couldn’t work with machines at ‘standard’ heights.Apart from the effect on your back it’s harder to see what’s happening,another thing that doesn’t improve with age.
My miller stands on 6” of concrete,another one that I had was raised by 8”. My lathe is on a purpose made stand so I’ve no idea how that compares to the manufacturer’s one except that it’s a lot higher.
My advice would be to cast a concrete slab,slightly bigger all round than the base, with bolts cast in. It’s not that much work and once it’s done it’s done.
Thread: Hemingway large bore fixed steady kit
12/03/2023 18:32:14
I made one of these recently. It was from an old casting from Ivan Law,I think,but I’m sure the new ones are the same. I cut it in half first of all and only gave the back faces a bit of a rub on wet and dry on a flat surface,that’s all it needed.
Then made the hinge using a 1/4” s&f cutter on the vertical mill, cut very nicely,then treated it as one piece. I clamped it to a n angle plate to drill the holes for the fingers,one at a time of course.
Thread: Centec 2B Mill buying
02/03/2023 16:18:38
They are great machines and that one looks to be in fair condition but I would have thought it was on the big side for clockmaking, especially as you say your space is limited.
Also,if you plan to do both horizontal and vertical milling you will soon get fed up with lifting the vh on and off and will be looking for a raising block- see correspondence on this site.
I’ve got a Tom Senior ‘E’ type now which suits me much better and would probably do all you need.
Thread: Looking for material for solid tool post mount
23/01/2023 22:36:30
M- machine metals will have something very close and give very good service.
Thread: Teeny tiny rulers
12/01/2023 22:39:46
Pepin the Short?
Henry VI was only 8 months old when he succeeded so he must have been a right short- arse.
Thread: Tom Senior light vertical motor swap
25/12/2022 20:27:57
I fitted a motor/inverter package to my S type. (Newton Tesla,very happy,usual disclaimer) Had to open up the recess in the mounting plate a bit but it was easily done on the Myford faceplate,soft ally and no special accuracy required. Also needed to elongate the screwholes a bit,easier if you have access to another milling machine.
Thread: Stuart No9 question
10/12/2022 12:10:29
The “Stuartturnersteam.com” website shows examples with and without and also one with “Stuart Turner” on it . The maker’s own website shows it without ,presumably patterns got lost over the years and it was easier to make a plain replacement. Seems a shame,really
Thread: Perfectly ground Twist Drills every time.
10/11/2022 20:51:29
Please could you point me there too?
Thread: Centec riser block
13/10/2022 22:45:37
Be aware that there are two slightly different widths of dovetail-the vh that I had wouldn’t fit the machine without the raiser,quite apart from the advantages of having the (long) block in place.
And shop around for the aluminium. I paid about £100 for mine,several years ago. One supplier wanted nearly twice that for the same stuff.
Thread: National Trust : free tickets
01/10/2022 10:44:35
Me too,thanks Michael
Thread: Mill preparations
28/09/2022 18:50:39
Think carefully about the height of the table. My new acquisition stands on a 6” slab,cast in place with hold down bolts cast in. Takes care of the flatness problem too.Admittedly I’m on the tall side but most machines seem to be designed for the more compact user.
Thread: Centec 2C
27/09/2022 19:53:21
I think all those Centec VH’s leak slightly,mine did. I’ve seen a picture of one in Cherry Hill’s workshop- in an old MEW I think- with a little tin hanging from it to catch the drips. If it’s good enough for her…
Edited By Frank Gorse on 27/09/2022 19:55:12
Thread: Exactly
26/07/2022 22:28:20
Thanks for the recommendation,I’ve just ordered a copy. Not from amazon.
