Brazing Mild Steel
Con Nicoll 1 | 01/11/2018 15:54:01 |
5 forum posts | Hi Everyone, Thank you for all your responses. I only have relatively small parts (3"x2"x3/4" I have a blowtorch with a MAPP gas cylinder which I hope will do the job. My thinking now is:
I attended the Silver soldering lecture at the Fosse the other week. It was stated there you should mix the flux with water and washing up liquid before applying it to the job. Will the washing up liquid not contaminate the job? Con Nicoll |
Russell Eberhardt | 01/11/2018 16:19:52 |
![]() 2785 forum posts 87 photos | I've always added a drop of washing up liquid to the flux mixture with no problems. For best advice see **LINK** Russell |
Neil Wyatt | 01/11/2018 16:44:53 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Con Nicoll 1 on 01/11/2018 15:54:01:
I attended the Silver soldering lecture at the Fosse the other week. It was stated there you should mix the flux with water and washing up liquid before applying it to the job. Will the washing up liquid not contaminate the job? Con Nicoll Only use a drop. It doesn't seem to do any harm and helps the flux 'wet' the metal. Neil |
Keith Hale | 02/11/2018 10:08:53 |
![]() 334 forum posts 1 photos | A couple of points to add... I said during my talk at the Fosse that cleaning of the joint is not your job - it's the function of the flux. The joint must be clean at brazing temperature not at room temperature. You cannot achieve this but the flux can and will. Using citric acid is a waste of time. Use it if you wish but just make sure that you wash it off. The heat from the torch will leave a deposit of citric acid salt that the flux will not remove. Result - poor joint! The amount of detergent used in making the paste has no deleterious effects. I also stressed at my talk "ask questions,- don't be afraid to ask". Why didn't you? There is more information and technical help on silver soldering and/or brazing at CuP Alloys than eBay, Amazon,car boot sales, welding distributers etc put together. Why not use it? At worst, you will be talking to someone who has been in this business for 24 years. Strike lucky and he has 49 years! I'm getting old! Keith |
MW | 02/11/2018 10:56:48 |
![]() 2052 forum posts 56 photos | I can vouch for that, the advice on CuP really helped me understand what was going on when soldering, why using the right type of flux is very important etc.. I do believe CuP has written a guide you can buy, which i suspect i will do myself, in good time. Not to be sniffed at! Michael W |
Tim Stevens | 02/11/2018 12:08:48 |
![]() 1779 forum posts 1 photos | I think that the need for a gap in a soldered or brazed joint is because of the nature of the melting process. Unless you have a eutectic alloy, the melting process starts with pasty rather than completely runny metal. This is because some of the metal melts first, and what is unmelted comprises small crystals. And it is these crystals that prevent or interfere with flowing into the joint. Once the whole joint, filler and all, are up to a higher temperature, the crystals dissolve and flow properly. And this is, of course, what you need, as otherwise your joint will be partly eutectic, and partly some other alloy, rather than uniformly the same. Another cause of poor flowing is the presence of dust from the air and minute solid particles remaining in the melted flux. Some dusts (especially emery, for example) act to repel the flux so that flow is impeded, and a wide joint gap may help to allow any grains to be flushed out by molten flux or brazing alloy. I would be keen to learn of any more scientific explanation (based on tests rather than experience etc). And PS - silversmiths always relied on borax until fancy modern fluxes were made available. I think this was in the early part of last century - but for may, borax is still generally used, for silver and gold solders. Regards, Tim |
Bill Phinn | 02/11/2018 15:42:14 |
1076 forum posts 129 photos | Posted by Tim Stevens on 02/11/2018 12:08:48:
And PS - silversmiths always relied on borax until fancy modern fluxes were made available. I think this was in the early part of last century - but for may, borax is still generally used, for silver and gold solders. Regards, Tim That's right, Tim. I mentioned my use of borax in jewellery making earlier. The "fancy" flux I sometimes use instead (on heating it bubbles up less than borax) is auroflux. It works well on gold and silver. I'd like to know what's in it. One other thing jewellers often use is a boric acid slurry brushed on before soldering to reduce the dreaded fire-scale you can easily get when soldering sterling silver, and even with some gold alloys. Some people say the boric acid improves solder flow. I use it a lot but I'm not sure whether it does help, nor whether its help (in addition to the flux) is really needed if your soldering discipline is good. |
Michael Gilligan | 02/11/2018 16:15:54 |
![]() 23121 forum posts 1360 photos | Posted by Bill Phinn on 02/11/2018 15:42:14:
The "fancy" flux I sometimes use instead (on heating it bubbles up less than borax) is auroflux. It works well on gold and silver. I'd like to know what's in it. . Bill, Have a look at section 2.2 of the Safety Data Sheet It wasn't difficult to find ... under 'Questions & Answers' on the link that you provided . MichaelG. Edited By Michael Gilligan on 02/11/2018 16:23:23 |
Bill Phinn | 02/11/2018 17:03:28 |
1076 forum posts 129 photos | Posted by Michael Gilligan on 02/11/2018 16:15:54: Bill, Have a look at section 2.2 of the Safety Data Sheet It wasn't difficult to find ... under 'Questions & Answers' on the link that you provided . MichaelG. Edited By Michael Gilligan on 02/11/2018 16:23:23 Sorry, Michael, I've searched the questions and answers section of that link high and low and I can see no safety data sheet. |
Meunier | 03/11/2018 19:53:53 |
448 forum posts 8 photos | Bill, it took me 2 attempts to get there but here is a link to the SDS, DaveD |
Michael Gilligan | 03/11/2018 20:29:44 |
![]() 23121 forum posts 1360 photos | Posted by Bill Phinn on 02/11/2018 17:03:28:
Sorry, Michael, I've searched the questions and answers section of that link high and low and I can see no safety data sheet. . Bill, The second item on the Questions & Anwers tab is: Do you have a safety data sheet for this product ? ... now click the little 'down arrow' [or the text] and you will see the answer. MichaelG. . Note: Meunier kindly provided a direct link, but I thought you might also find 'how to' useful for future navigation of Cookson's site. Edited By Michael Gilligan on 03/11/2018 20:33:38 |
Bill Phinn | 03/11/2018 22:29:10 |
1076 forum posts 129 photos | Thank you, Meunier and Michael! I've worked out why I couldn't see what you were seeing, Michael; I was viewing the page on my desktop, which has a browser extension that blocks ads, trackers etc. I had to disable the browser extension in order to be able to see the actual questions and answers lurking beneath the tab of that name. |
Eddy Curr | 11/11/2018 20:10:03 |
39 forum posts | Posted by CuP Alloys 1 on 02/11/2018 10:08:53:
Posted by Neil Wyatt on 01/11/2018 16:44:53:
I attended the Silver soldering lecture at the Fosse the other week. It was stated there you should mix the flux with water and washing up liquid before applying it to the job. Will the washing up liquid not contaminate the job? Con Nicoll Only use a drop. It doesn't seem to do any harm and helps the flux 'wet' the metal. Neil The amount of detergent used in making the paste has no deleterious effects. Keith Washing up liquid or dish detergent is a surfactant, a "compound that lowers surface tension between ... a liquid and a solid." As indicated by Neil, adding detergent to the water used with the flux paste facilitates improves dispersion or wetting action of the flux by reducing the surface tension between the flux mixture and the surfaces it is applied to. While I defer to CuP Alloys 1 in all matters brazing, a little detergent goes a long ways. |
Brian H | 11/11/2018 21:41:18 |
![]() 2312 forum posts 112 photos | The 'drop' of detergent is specified in Rolls-Royce Aero literature (or used to be). They also specify surgical spirit instead of water. When a flame is applied the spirit burns and bakes on the flux (I always use Tenacity 5) Brian |
not done it yet | 11/11/2018 21:55:59 |
7517 forum posts 20 photos | Posted by Eddy Curr on 11/11/2018 20:10:03
I think they work on liquids to liquids, too. Think here - those dirty dishes or oil slicks? |
Eddy Curr | 11/11/2018 23:53:45 |
39 forum posts | Posted by not done it yet on 11/11/2018 21:55:59:
I think they work on liquids to liquids, too. Think here - those dirty dishes or oil slicks? Yes. The ellipsis in the quotation denotes words left out. Liquid-to-liquid and gas-to-liquid seemed superfluous to the discussion at hand. The full phrase reads as follows: "Surfactants are compounds that lower the surface tension (or interfacial tension) between two liquids, between a gas and a liquid, or between a liquid and a solid. Surfactants may act as detergents, wetting agents, emulsifiers, foaming agents, and dispersants." Source: Wikipedia
Eddy Curr | 12/11/2018 00:42:47 |
39 forum posts | Posted by Tim Stevens on 02/11/2018 12:08:48:
I think that the need for a gap in a soldered or brazed joint is because of the nature of the melting process. I would be keen to learn of any more scientific explanation (based on tests rather than experience etc). No, the need for enough, but not too much gap is to facilitate: 1) capilliary movement of the braze filler metal along the length of the joint between parent metals; and 2) joint strength. The article in the following link discusses aspects of gap size, joint tensile strength, flux voids and brazing atmosphere. "The Famous Joint-Strength vs Joint-Clearance Chart" Dan Kay. 2013.04.07 While the conclusions hold implications for industry and obsessives, hobbiests such as myself can continue to follow age-old practice to enjoy satisfactory results. |
Hopper | 12/11/2018 02:41:18 |
![]() 7881 forum posts 397 photos | Interesting reading there, Eddy. I always think that if the ideal gap is somewhere around half to one-and-a-half thou, depending on which chart you follow, any two pieces of metal will have about that clearance between them unless they have been blued and hand scraped to a better fit, or perhaps surface ground and micro polished. Most pieces of metal in the home workshop cut straight from stock, or even milled to shape, and given a bit of a rough up with some coarse emery paper before brazing will have a tiny gap in this range due to surface imperfections, lack of true flatness etc. I remember from apprentice days the weeks of painstaking filing it can take to get two pieces of steel to mate within less than one thou. It's a lot harder than many people think. |
J Hancock | 12/11/2018 09:38:04 |
869 forum posts | Just be careful that the mild steel is not leaded. The joint will look good but a good smack with a hammer will show the problem. |
Chris Trice | 12/11/2018 10:49:53 |
![]() 1376 forum posts 10 photos | I've used neat washing up liquid (no water) in my flux mix with no discernible drawbacks and it's easier to control how many drops of detergent you add than drops of water. Usually it's a 50/50 mix of water and detergent though. |
