Here is a list of all the postings Con Nicoll 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Citric acid cleaning of mild steel prior to and post silver soldering |
17/09/2020 15:35:48 |
Hi, Citric acid causes mild steel to corrode on removal of items from solution. it appears that this can be avoided by:- Total immersion for cleaning in solution. No part of item exposed to air. Immediately rinsing in clean soap and water on removal. questions:- Suppliers recommendation is 20gms/ltr solution. Is this the minimum necessary for 100% solution? Is 100% solution necessary to avoid corrosion of mild steel? This appears to work but I'd like confirmation that my assumptions are correct. |
Thread: email alerts |
20/11/2018 12:21:59 |
How do I turn off them off? I am being inundated. |
Thread: Brazing Mild Steel |
01/11/2018 15:54:01 |
Hi Everyone, Thank you for all your responses. I only have relatively small parts (3"x2"x3/4" I have a blowtorch with a MAPP gas cylinder which I hope will do the job. My thinking now is:
I attended the Silver soldering lecture at the Fosse the other week. It was stated there you should mix the flux with water and washing up liquid before applying it to the job. Will the washing up liquid not contaminate the job? Con Nicoll |
26/10/2018 16:13:45 |
There was an article a year or two ago in ME about fabricating a bogie for a 5 inch gauge Princess Coronation using silver solder. I think this was using mild steel plate. Does any one know anything about what advantages silver solder has over other brazing alloys. In fact can anyone point me at any information on brazing mild steel. I am fabricating a bogie "casting" for a 2.5 gauge tender. I would like some guidance. Thank you in anticipation |
Thread: New Member |
26/10/2018 15:33:13 |
Hi I'm a rejoining member after a couple of years away lost to website, so I'll start again. I have a small brickbuilt workshop which is lined with insulated flooring grade tongue and groove chipboard. This is infinitely preferable to the plasterboard some people use as it's not so liable to distortion due to damp. It also has the advantage that it is strong enough to take the weight of virtually anything you care to screw to it. I have 3 machines, a Myford ML10 and a 4 inch Murad Antarctica lathe and a Chester Conquest chinese milling machine. I would like to replace the milling machine with something a bit more civilised, it makes a terrible row, I have fitted the ML10 with a variable speed (VSD) which I would highly recommend to anyone to fit. I would also like to fit one to the Murad. |
