JA | 10/12/2016 13:59:07 |
![]() 1605 forum posts 83 photos | Second thoughts about clocks. Usually you have to cut and cross the wheels which is time consuming. You may be able to get cut and crossed wheels but they will not be cheap. JA |
pgk pgk | 10/12/2016 14:53:39 |
2661 forum posts 294 photos | A nice home made hammer and screwdriver and a book on DIY ... should then leave you more time to yourself. |
Iain Downs | 10/12/2016 15:04:38 |
976 forum posts 805 photos | Showing his ignorance he asks, 'What is cut and cross'?
Iain |
Alan Waddington 2 | 10/12/2016 15:13:35 |
537 forum posts 88 photos | An ironing board.....obviously |
Michael Gilligan | 10/12/2016 15:17:50 |
![]() 23121 forum posts 1360 photos | Posted by Iain Downs on 10/12/2016 15:04:38:
Showing his ignorance he asks, 'What is cut and cross'? . ... Cut the teeth on the wheels, and 'cross-out' the spokes. MichaelG. . Edit: This video is short & sweet: https://m.youtube.com/watch?v=Nlw1NQQGlXI but doesn't cover 'crossing-out' ... I'm sure you can find something now you know what you're looking for. Edited By Michael Gilligan on 10/12/2016 15:34:20 |
V8Eng | 10/12/2016 16:14:09 |
1826 forum posts 1 photos | I think a scanning machine to ensure there is not a spot of grease/oil anywhere on skin or clothing (before going indoors from the workshop).
Edited By V8Eng on 10/12/2016 16:21:52 Edited By V8Eng on 10/12/2016 16:32:26 |
SillyOldDuffer | 11/12/2016 13:07:02 |
10668 forum posts 2415 photos | I've not had much success impressing my family. They are an ignorant unappreciative lot. This peg got some positive comments: This one went down well after reassembly. I gave away the real one, but the impossible nut is amusing Dave |
John Haine | 11/12/2016 13:31:18 |
5563 forum posts 322 photos | Napkin rings. |
Iain Downs | 11/12/2016 13:48:37 |
976 forum posts 805 photos | HI, Having had some time to think about this, I'm veering towards a candlestick. I'm thinking it could even be a Christmas pressie if I get my act together. My current thoughts are to make it in steel / ally since I have some stock in my bin. What I thought I'd do was something like this. Cylinder (100mm) for the base and for the candle holder (might be smaller). Face off the cylinders and bore to put a (say) 10mm thread in. For the base cut 3 legs (say 8mm deep) out using the mill and a rotary table. For both make a mandril to fit the 10mm internal thread and turn the outside. For the stick part, take 15 - 20 mm round bar, put a step on both ends and an M10 thread to assemble afterwards. Move over the tailstock and turn a nice taper. I'd definitely make the base of steel (one should try and make it hard for these things to fall over, I'm told). THere's two things I don't really know how to do. First is that I'd like the base and top to be curved smoothly rather than square. I understand about ball turners and whilst there is a strong temptation to make one, that just puts me back in my making tools to make tools to make.... obsession. Can I cut some angles and then smooth with a file? Or is there a cleverer way? The other thing is finish. Brass would be finished by virtue of being brass, but steel probably needs a coating of some kind? I'm also not sure what I need to do to get a burnished or mirror finish. I guess it's a lot of sanding with increasingly fine paper and then the dremel with some rouge and a buffing wheel? I'm afraid that I've been focusing so far on stuff that's functional. Pretty is a bit daunting! Any advice (as always) very welcome.
Iain |
pgk pgk | 11/12/2016 21:40:22 |
2661 forum posts 294 photos | Back when i was making my sterling engine I graphed out the curve I wanted and used the DRO to turn to depths and distances then filed. 'Oxtool' used a similar method making part of his bullet vice on youtube using the mill.. he thought it was called kellering. Jason has also used the same type of techniques in some of his pics. Quickest would be a nice fat round of ally to turn the base.. and if you want to weight it then bore from below and press fit in some steel..or even a plug and sand. You can always save cost by using thinner for a log shaft fitted with all-thread and threadlock then turn it to match. Edited By pgk pgk on 11/12/2016 21:44:52 |
JA | 11/12/2016 23:03:01 |
![]() 1605 forum posts 83 photos | If you make candle sticks make sure they match. My niece made me two wooden ones when she was about 15. Each were very very good but they were very different. Edit: I think candle sticks come in pairs. JA Edited By JA on 11/12/2016 23:04:42 |
Ian S C | 12/12/2016 10:53:51 |
![]() 7468 forum posts 230 photos | One thing I made for my brother in law was a stainless steel coffee (not sure what it's name is) hammer/compressor. you'll need a bit of stainless about 2" dia x 3" or so long, You will find them in the shops, here they cost up to $NZ80. Ian S C |
richardandtracy | 12/12/2016 14:07:26 |
![]() 943 forum posts 10 photos | A kit pen? I made my first in 3.5 hours including the time involved in making the mandrel to turn it on. Whatever people say, it can be done on a metal lathe with carbide insert tools. Take a look at this: **LINK** Need not be a fountain pen. Axminster Tools do many, many kits of all types from rollerballs to fountain pens & ball points. Avoid the 'polyester' blanks. The resin is too brittle to survive the pen being dropped on concrete. Thick superglue or epoxy is the best adhesive. These days expect pen #1 to cost about £15 to make. You may find some cheaper bits elsewhere if you continue. The 'Wow' factor with 'er indoors is pretty high with the first one. By #250 there's rather less astonishment (speak from experience here). Hope that inspires a little. Regards, Richard.
Martin Kyte | 12/12/2016 14:29:54 |
![]() 3445 forum posts 62 photos | Have a look at the craft-pro kits at Just made two egg shaped Kaleidoscopes for the two elder great nephews. There are a host of other things you could make without too much investment of time. Quite do-able to turn small wooden items on your metal lathe. Or if you don't fancy wood there are a host of acrylic blanks for scent bottles, wine stoppers, salt and pepper shakers,pepper mills or pens as has already been suggested. They supply the "works" you do the housings. regards Martin |
Anthony Knights | 12/12/2016 18:17:39 |
681 forum posts 260 photos | On the subject of nut crackers (mentioned earlier), I have found that the usual design is pretty useless. The best device I have found for cracking nuts is a pair of Mole Grips. |
TSH | 12/12/2016 20:09:08 |
45 forum posts 11 photos | Some time ago I found myself in a very similar position. In my case my wife expressed an interest in a honey 'dibber', so I made one from stainless steel—no precision needed at all: By the way, I made the grooves on my Myford using a large parting tool—that was before I learned that was supposed to be difficult! Trevor |
SverreE | 12/12/2016 21:44:59 |
22 forum posts 14 photos | Some years ago I made 6-7 Rolling Pins (in Norway it is called a "Kjevle" To my great pleasure, my wife likes to show the Rolling Pin to guests and I willingly shows them my workshop in the garage! Merry Christmas from Sverre |
David Standing 1 | 12/12/2016 21:58:55 |
1297 forum posts 50 photos | Posted by Ian S C on 12/12/2016 10:53:51:
One thing I made for my brother in law was a stainless steel coffee (not sure what it's name is) hammer/compressor. you'll need a bit of stainless about 2" dia x 3" or so long, You will find them in the shops, here they cost up to $NZ80. Ian S C Ian If you mean what I think you mean, you mean a tamper. From, a coffee snob |
Clive Hartland | 12/12/2016 23:06:49 |
![]() 2929 forum posts 41 photos | A honey, 'Drizzle' I think Trevor, I make mine out of Holly wood, as I cut down a male Holly tree ( No berries) and seasoned the wood for a long time and it turns very nicely. Clive |
Iain Downs | 13/12/2016 07:17:33 |
976 forum posts 805 photos | I've made a start on a candlestick, but getting a lot of roughness so need to either change to HSS tooling or strip the cross-slide (it keeps getting loose - I suspect that there's a bolt loose somewhere in there). I've also ordered some 2 inch brass bar and will have a go at some tea light holders. I liked the kits and will explore. Honey drizzle and rolling pin sound good, but sadly all the cooking is done by 'im indoors and not SWMBO. Keep the ideas coming!
Iain |
