treadle power
Gordon W04/06/2014 10:22:00
2011 forum posts
I am thinking of getting a new workshop building, without any power supplies. I have a generator but to cut running time and expense am thinking about treadle powered lathe. I know these used to be common but have only seen very small ones in use. My lathe is a chester DB8 belt drive, I will have no problem building the thing, countershafts etc. Just wondering if anyone has experiance of a lathe of this size with manual operation. Will it be possible ? Any ideas on flywheel mass ? etc. etc. I read somewhere the human body can produce about 1/10 HP, my electric motor is 3/4 HP but does not work that hard all the time. This is just a thinking exercise at the moment.
Michael Gilligan04/06/2014 10:37:14
23121 forum posts
1360 photos
Sounds a great idea, Gordon.
It might be worth searching some of the "Alternative Technology" websites for design ideas.
If you fancy working the lathe sitting down, then something based around an exercise bike may be suitable.
[Hecklers: let's please skip the Armchair Engineer jokes.]
Edit: Here is a useful place to start collecting ideas
Edited By Michael Gilligan on 04/06/2014 10:41:55
Swarf, Mostly!04/06/2014 10:46:21
753 forum posts
80 photos
Hi there, Gordon,
I suggest that (among other things) you browse that 'well-known auction site' and study the pictures. You might even encounter some usable kit close to your location.
A work colleague of mine, many years ago, used to support a charity that helped blokes with lower limb disorders. He (George) used to search for and help buy treadle-powered lathes that were loaned-out to the 'patients' for occupational therapy. 'If you don't use it - you lose it!'
He observed that pedalling a treadle lathe motivates the pedaller to learn how to sharpen their tools!
Best regards,
Swarf, Mostly!
WALLACE04/06/2014 11:10:28
304 forum posts
17 photos
Someone did an article on this very subject a couple of years ago in MEW with a Unimat lathe...
W.
Edited By WALLACE on 04/06/2014 13:54:05
Ady104/06/2014 12:10:11
6137 forum posts
893 photos
The Drummond M series flywheel must weigh at least 150-200lbs, I reckon it's heavier than the lathe
Keith Long04/06/2014 12:41:37
883 forum posts
11 photos
Ady is certainly in the right ball park with those figures, I've just checked the Drummond book for the round bed which I guess would have had a much lighter flywheel by the nature of the beast and found the following:-
Diameter of flywheel rim 21 inch
Diameter of steps on flywheel 16, 14 3/4, 13 1/2 inch
Weight of flywheel 100 lbs. (weight of lathe 105 lbs)
It looks as though there was NO intention to use the rim of the flywheel for a drive as the main spindle pulley had 3 steps and the flywheel has 3 steps in addition to the overall rim. Also it's not clear whether the weight given for the flywheel includes the pulley steps or not, but it appears to be one lump so I guess it does.
Generally the bigger the better for flywheels for smoothness and to cope with the glitches from turning, but the more momentum they have the harder it is for you to accelerate or brake them. One point to look out for - make sure that you can't get your toes caught under the treadle. If the flywheel is still turning and you get your toes trapped you might be looking at a trip to A&E and a plaster shoe for a bit. One way to avoid that is to have the "pitman" slotted so that it will only drive on the down stroke, the crank-pin on the flywheel being free to run up and down the slot when the flywheel is "free-wheeling" so that it doesn't drive the treadle.
Keith
Ian S C04/06/2014 13:07:21
7468 forum posts
230 photos
Got a Popular Mechanics article on a home made wood lathe with a 6' centre hight, the flywheel is 17" x 3'', and made of concrete.
In one of my "Amateur Mechanic & Work" Handbooks, The Drummond 3 1/2" centre Lathe (1902) Has a FW of 92lb. Ian S C
Edited By Ian S C on 04/06/2014 13:14:39
Gordon W04/06/2014 14:05:58
2011 forum posts
Thanks for all that. I had an idea that .the f/wheel might be those sort of figures. does seem a lot to get moving but ok once cutting. A clutch or fast/loose pulley will be a good idea. I did muse about using a free-wheel drive and chain, this would help to stop toe chopping. Main prob will be building up my old leg muscles.
Neil Wyatt04/06/2014 16:12:46
19226 forum posts
749 photos
86 articles
Apparently Bradley Wiggins can produce around 427 watts, or about half a horsepower.
So you should be able to treadle your lathe without resorting to chemical stimulants!
I've heard treadling is more better than you expect if you a have a big flywheel as long as you avoid long deep cuts.
Michael Gilligan04/06/2014 16:13:43
23121 forum posts
1360 photos
Posted by Gordon W on 04/06/2014 14:05:58:
... I did muse about using a free-wheel drive and chain ...
Years ago [probably late '40s, early '50s] there was an article in ME, where someone did that to drive a little grindstone unit ... definitely worth considering.
Bob Brown 104/06/2014 16:17:13
1022 forum posts
127 photos
You may be able to adapt the drive on a bicycle to give you the free wheeling bit.
Steve Withnell04/06/2014 19:11:32
858 forum posts
215 photos
I think this may be still available -
The treadle plate was about somewhere - if it is of interest, PM me and I'll go and hunt down the bits. It's a Britannia with about 3-4inch centre height.
Steve
JasonB04/06/2014 19:17:58
25215 forum posts
3105 photos
1 articles
Or there is this one on Homeworkshop
Michael Gilligan04/06/2014 19:29:32
23121 forum posts
1360 photos
Gordon,
I presume, from your first post, that you intend to Man-Power your existing Chester DB8
If so, it's worth looking at the Barnes for inspiration ... Roughly the same size.
Nigel McBurney 104/06/2014 20:18:41
1101 forum posts
3 photos
50 years ago my neighbour owned a workshop set up by his father in victorian times and was never modernised, One of the lathes was around 6 inch centre height and was set up for treadle drive and line shaft drive, early lathes could be quite large in capacity but their spindles were small,very often solid and easily rotated.I asked how did their workers manage to treadle a six inch lathe,he replied that tredalling was used for small quick jobs where it was not worth getting the line shaft working though he said the treadle worked well and was easy to operate, perhaps if an operator complained they got the sack. none of the lathes had index collars on the cross slide screw,the screw had a square end to take a simple handle,operators worked to chalk marks,a steel rule and stiff joint calipers,that was skill, how different to modern times when folks cannot seem to be operate a machine unless it has digital readout .
Nigel McBurney 104/06/2014 20:21:39
1101 forum posts
3 photos
Oh I forgot why bother with a treadle,why not use a old stationary engine like a Lister D steady 500 rpm with a large solid flywheel ideal for driving a lathe.
V8Eng04/06/2014 20:23:29
1826 forum posts
1 photos
Somebody will just have to go away and invent steam power, a nearby coal mine might come in handy as well.
Sorry Nigel, my post appeared just after yours, similar ideas just a few decades apart.
Edited By V8Eng on 04/06/2014 20:25:13
Steve Withnell04/06/2014 22:38:10
858 forum posts
215 photos
Posted by JasonB on 04/06/2014 19:17:58:
Dad's got one of those, but he has a 1.5HP Motor strapped on the back, the treadle bits went maybe 50 years ago...
Steve
Ady105/06/2014 00:49:18
6137 forum posts
893 photos
I hung on to my treadle because in Edinburgh a donkey goes faster than a car and once they ban electricity (after smoking alcohol cars and fatty foods) I'll be the core of a corporate explosion in manufacturing
Britain
The cradle of the industrial revolution and the crucible of the ecological stagnation
Edited By Ady1 on 05/06/2014 01:23:18
Clive Haynes14/06/2014 14:31:51
57 forum posts
9 photos
I was given a treadle lathe many years ago when I was still at school and I found it impossible to do anything useful on it but the tools were probably blunt and I didn't know much then just thought I did. Have you considered low voltage and battery power?
