Here is a list of all the postings Clive Haynes has made in our forums. Click on a thread name to jump to the thread.
Thread: How to cut a tapered shoulder? |
28/02/2017 23:55:55 |
If you were buying a wife! |
Thread: Britannia buffer beam |
28/02/2017 00:36:33 |
Hi Julian, thanks for that reply, I guessed loctite might be the best solution. It does however seem that I have problems ahead. Clive |
Thread: Tin openers |
27/02/2017 15:37:29 |
Do it with your mouth open. |
27/02/2017 15:24:19 |
Why not mount the shaft on a ball socket. that way you could change the orientation of the model to suit your mood. i.e nose up when you are happy and the opposite when you are not. |
27/02/2017 15:17:36 |
You can mount the can in a 3 jaw and part the lid off or an angle grinder works well. |
27/02/2017 14:24:37 |
Hi I am building a brit and I note that the real thing and models I've seen has rows of rivets in the buffer beam but the drawings do not show this. To copy the real thing is it best to put short rivets in and loctite them? Clive |
Thread: What Did You Do Today (2016) |
22/12/2016 17:32:09 |
It's gone very quiet on here, must be Christmas. |
30/11/2016 19:06:04 |
I'm allergic to the vacuum cleaner, washing up suds, household dusters and cooking fumes. |
24/11/2016 17:38:27 |
It makes for a softer landing if you drop something, there's always a plus side. Clive |
Thread: Pad printing/painting |
21/11/2016 18:45:35 |
Thanks Richard. that sounds like an interesting option.
Clive |
21/11/2016 16:49:17 |
Hi Ian, I intend to change just the one word from amps to volts and to use the guts of the volt meter but keep the original dial face but remove the +30, -30 and the 0. Regards Clive |
21/11/2016 15:53:34 |
Hi Ian P, I said that I was in the process of converting from ammeter to volt meter, not converting the ammeter. I have got a segment type volt meter from a Triumph Stag which I intend to graph into position. The lettering must be exact as there is other lettering on the same dial face which I think would rule out letraset. Regards Clive |
21/11/2016 15:30:03 |
I think that a vinyl stencil would be the easiest way forward with this one. Thanks geary for your offer, I have downloaded some photo's to show what needs to be done. |
20/11/2016 16:44:06 |
I have a small engraver to make the type but it all seems a bit involved for 5 very small letters (VOLTS). I am beginning to think maybe a stencil would be easier. Clive |
20/11/2016 15:31:39 |
Thanks Michael, that's a good start. Clive |
20/11/2016 15:09:10 |
Hi, is anyone familiar with the above topic? I have a classic car which I have converted from dynamo to alternator and am in the process off converting from ammeter to volt meter and need to change the wording . I know that instrument manufacturers use the pad printer process for their dials but what paint to use etc. Any info would be helpful. Clive |
18/11/2016 19:09:28 |
I hope you're going take it al apart give it 3 coats of paint and then re-assemble it before you give it to the child! |
15/10/2016 17:06:41 |
You are not supposed to mount that on the wall!
14/10/2016 18:23:08 |
I bet you can make some serious swarf with that lot. Did you plan to build the workshop around the machines for ease of crane off or did it just work out that way? Clive |
17/09/2016 17:43:02 |
Isn't that how we all dress in our workshops or is it just me. |
