Woman's Logic
Oompa Lumpa11/01/2014 17:18:12
888 forum posts
36 photos
So, because I now have a workshop for metal, it naturally follows that the Brass Firegrate set which my good lady prizes can now be cleaned.
By Me.
Now!
Now that I have volunteered for the job - how should I begin to get the brass clean? Ideally I would like to give it a good soak in something to get rid of the most of the ingrained tarnish, then I am going to have to set to with a polishing mop. Mop and soap (abrasive) I have, but I am looking for an easy way out here
graham.
OuBallie11/01/2014 17:23:57
1181 forum posts
669 photos
Patina, patina, patina.
People pay huge premiums for this.
Geoff - Sparrow nests up after thinking about it for 5 years! I get there eventually.
Mike Teaman11/01/2014 17:26:28
58 forum posts
Most of the "modern" firegrates have a coating on them to "preserve" them. They usually deteriorate, flake, degrade or whatever. If yours has this coating, it can be stripped back to solid brass (assuming that it is?) with a metal polish or abrasive (steel wool?) and polished. The trouble is that once you polish, you need to repolish on a regular basis or find a protectant that can do a better job than the one you already (may or may not already) have. Or have one of the "downstairs" staff do it for you!
.... assuming that makes sense ................... which it probably doesn't!
Polishing brass can be very therapeutic ...... and time consuming!
jason udall11/01/2014 17:31:22
2032 forum posts
41 photos
Some might say thin endof the wedge..
Others might say small price to pay...
I see it as excuse to get more toys...
Pickel and polish.
jason udall11/01/2014 17:32:20
2032 forum posts
41 photos
Oh and opportunity to establish brass or plate..just for future reference. ..
Andrew Moyes 111/01/2014 17:48:25
158 forum posts
22 photos
I'd paint it black and have done with it.
NJH11/01/2014 18:11:09
2314 forum posts
139 photos
Graham
Without seeing the state of your brass it's difficult to judge however HOROLENE is a pretty effective way of cleaning clock plates. Make up a bucket full and dunk the item in . See HERE and search for Horolene - elbow grease may be cheaper!
Norman
Edited By NJH on 11/01/2014 18:12:25
John Stevenson11/01/2014 18:17:27
5068 forum posts
Diane DO NOT READ THIS !!
Only way to address women's logic is with men's logic.
Just get any old cleaning material, Brasso will be fine.
Spend 10 minutes polishing a bit then go off and do what you want for the next hour.
Storm into the house in an evil mood and curse that this is hard work and all you have to show for an hour and ten minutes is this. Waving said poker around.
have a cup of tea, 'calm down' and say this thing isn't going to beat me.
Outside again 10 minutes cleaning, one hour making bits.
Anyone who sends this post to Ower Gert is dead.......................
Oompa Lumpa11/01/2014 18:21:59
888 forum posts
36 photos
Hi guys, thanks for the comments.
Firstly, it is not a Firegrate, it is a Firegrate Set - Poker, Tongs, Toasting Fork and stand, it is solid brass and it is also early 1900's. If it was worth anything I wouldn't be cavalier with it, it isn't, I will
Sisal mop to start with it is then. I will do a before and after
Well you didn't think I was going to sit there with a tin of Brasso did you?
graham.
Oompa Lumpa11/01/2014 18:27:49
888 forum posts
36 photos
Very good John, I like your thinking
Posted by John Stevenson on 11/01/2014
18:17:27:
Swarf, Mostly!11/01/2014 18:57:53
753 forum posts
80 photos
Hi there, Graham,
Once polished, try saxophone lacquer, from your local branch of Boosey & Squawks or any other good music shop!
Best regards,
Swarf, Mostly!
Edited By Swarf, Mostly! on 11/01/2014 18:58:23
Springbok11/01/2014 19:27:37
879 forum posts
34 photos
Go to your boots get a packet of citric acid, mix in a large bucket put items into take out after a while brasso and tell dear wife what a clever person you are.
bob
Edited By Springbok on 11/01/2014 19:28:42
Speedy Builder511/01/2014 20:09:29
2878 forum posts
248 photos
Don't make too good a job of it or you will have to do all the other brasswork in the house.
mickypee11/01/2014 20:25:51
39 forum posts
8 photos
Autosmart "Smart Wheels" It is used for cleaning brake dust off wheels. Use it all the time for cleaning engine components etc, brilliant stuff. Spray it on, wash it off. Tell her it took you two hours and play to your hearts content.
Stub Mandrel11/01/2014 20:43:58
4318 forum posts
291 photos
Shame, a firegrate set. If it was the grate I was going to say black it with zebrite
ChrisH11/01/2014 21:46:37
1023 forum posts
30 photos
I'm confused, how do you combine 'women' and 'logic' in the same sentence .....................?
Edited By ChrisH on 11/01/2014 21:47:05
andrew winks12/01/2014 01:53:02
117 forum posts
After the cleanup and polish, give it a coat of Protecta clear, google Everbrite Coatings. Specially made for clear coating of polished metal surfaces such as copper flues above wood heaters.Takes high temps. Hellishly expensive, must be a cheaper equal to it in the UK.
OuBallie12/01/2014 09:44:44
1181 forum posts
669 photos
JohnS & ChrisH,
Stop it please!
My sides are hurting and ready to burst.
Geoff - My day has been made with laughter.
Hopper12/01/2014 10:18:36
7881 forum posts
397 photos
Posted by John Stevenson on 11/01/2014 18:17:27:
You've done this before, haven't you.
Ian S C12/01/2014 11:09:17
7468 forum posts
230 photos
Stick the bits in citric acid over night (the home brew shop should be cheaper than Boots, or try the garden shop), then a few minutes with the Brasso and an old tooth brush. Then get one of the clear coatings, preferably a heat proof one, you should be right for a few years before you need to clean them again. Ian S C
