Here is a list of all the postings OuBallie has made in our forums. Click on a thread name to jump to the thread.
Thread: LED Angel lights |
03/10/2023 19:57:21 |
Thanks MichaelG & Ian P Geoff - On the mend with luck. |
30/09/2023 16:59:34 |
I still use the two machine lamps where necessary though. Geoff - First post in some time Edited By OuBallie on 30/09/2023 17:05:22 |
Thread: Headband magnifier - blessed relief! |
15/02/2023 16:22:46 |
Thanks Andy. Geoff - Late in response due to toothache! |
10/02/2023 17:43:26 |
jaCK Hobson, Details of the clone please. Geoff (OuBallie) - Back in business I hope from too long a layoff. |
Thread: Coffee grinder __ recommendations please |
20/09/2022 19:34:24 |
MichaelG, Let us know what you decide. I was introduced to French coffee when I worked for Merlin Gerin, Grenoble in the early ‘70s. Steve Gibson on coffee and grinders is interesting. I’m a percolator man myself. Geoff - Mowed lawn today Edited By OuBallie on 20/09/2022 19:35:00 |
19/09/2022 05:00:42 |
MichaelG, I’ve been using my Krups GVX2 grinder for years now and find it perfect. It’s sat on a piece of foam that allows me to give it a shake to get recalcitrant beans to head for the grinding mill. Geoff - Insomnia strikes again grr! |
Thread: Babbitt metal |
06/09/2022 14:03:12 |
Something of interest are my Austin Seven two bearing conrods with cast in place bearing material. Considering age of car these are in nigh on perfect condition, other than the oil retaining ‘pits’. Geoff - Feeling somewhat human again Edited By OuBallie on 06/09/2022 14:05:45 |
Thread: Tom Senior M1 Z axis problems |
15/08/2022 13:59:21 |
Old Mart, Now that’s something fairly easy to do, thanks.
My M1 has the same hex bolts for locking the Knee. Geoff - Not melting today phew! Edited By OuBallie on 15/08/2022 14:02:59 |
Thread: Hemingway flycutter |
17/07/2022 11:14:06 |
Howard, The hard weld blunted my tangential toolbit hence having to switch to TC. Geoff - Keep cool everyone. |
15/07/2022 17:13:05 |
Bazyle, Howard, Geoff - So much cooler today, ready for the furnace to come. |
14/07/2022 10:32:06 |
not done it yet, Ah easy to do then, thanks. Geoff |
14/07/2022 10:16:23 |
Bazyle, Used the bit to produce the square hole. Geoff - Trying not to melt |
12/07/2022 14:21:05 |
Thanks for all the comments. Andrew, Howard, The very best move was fitting one to the drilling machine that transformed it as now easy to adjust speed to suit drill size. Ady1, Geoff - Just replaced battery in iPhone 6s, and a doddle. |
11/07/2022 17:46:50 |
Thanks Michael. Doing my best to do so. More photos: I had forgotten just how hard arc weld is as it soon blunted HSS so switched to TC and that produced a perfect finish. In place but needing the tool bit ground: Geoff - Hemingway kit number 4 soon |
11/07/2022 15:47:39 |
My third Hemingway kit since doing their Drawbar and later the ‘simple’ knurling tool 2015:
Thread: Chattering when cutting with countersink tool on lathe |
11/07/2022 14:58:38 |
Both tools are best one I’ve ever had: The other tool is for setting lathe tool height and is perfect. Geoff - Workshop 25°, outside 30°+ |
Thread: Warco green paint |
24/06/2022 22:56:54 |
Very pleased how it turned out as it looked a wreck when received. Edited By OuBallie on 24/06/2022 22:58:53 |
24/06/2022 15:55:13 |
Used a part off of my BH600G for them to scan. Geoff - Somewhat cooler thank goodness |
Thread: Setting up a Warco BH600G |
19/03/2022 20:30:17 |
Thanks Rik, much appreciated👍 Geoff - Workshop’s been feeling neglected😥 |
19/03/2022 17:59:32 |
Michael,
Can’t believe I’ve finally finished adding the independent power feed to the Carriage, using a windscreen wiper motor.after trying various plain DC motors plus stepper ones, and having to learn how to control steppers. Geofc - Still in shock having finished that project😳 Edited By OuBallie on 19/03/2022 18:00:46 |
