Paul Scholey | 15/10/2013 19:08:55 |
87 forum posts 1 photos | I need to sharpen a carbide tipped lathe tool but dont have a suitable sharpening stone. I did buy a green silicone carbide stone from a well known dealer recently, no makers name on it, but found several cracks in it and got a refund., they are still being sold. My question is have diamond sharpening stones taken over now from silicone carbide stones? and I have been told they have to be used with water? Regards Paul. |
Ian P | 15/10/2013 19:58:11 |
![]() 2747 forum posts 123 photos | I would say that diamond is the best way to sharpen carbide. I have only ever seen and used Diamond wheels dry but I use water on the diamond 'stones' that have many advantages over the traditional oilstones (although they are much favoured by craftsman woodworkers. So water not oil, for the hand held diamond files etc. Ian P
Michael Gilligan | 15/10/2013 20:27:43 |
![]() 23121 forum posts 1360 photos | In the immortal words of the song: Diamonds are a Girl's best friend. [and also a Model Engineer's] MichaelG. |
Richard Marks | 15/10/2013 21:53:17 |
218 forum posts 8 photos | Gentlemen The usual advice given is to use water with diamond stones but I have found that it can leave traces of rust from the metal that has been removed, I now use plusgas as a lubricant and have had no trouble since. Dick |
Paul Scholey | 15/10/2013 23:03:43 |
87 forum posts 1 photos | What I meant was the circular ones to fit on a bench grinder, are you talking about the hand held ones? I cant see it will be very good using a lubricant on a bench grinder? |
Ady1 | 16/10/2013 01:42:40 |
![]() 6137 forum posts 893 photos | Used a silicon carbide wheel for a long time now and never had a problem, most tools only need a brush up |
Thor 🇳🇴 | 16/10/2013 05:15:37 |
![]() 1766 forum posts 46 photos | Hi Paul, I used a silicon carbide wheel to dress up carbide tools, and as Ady have not had any problems. I guess though that diamond wheels is the way to go, and I use a diamond hone to give of carbide tools a sharper cutting edge. Thor |
Russell Eberhardt | 16/10/2013 07:16:33 |
![]() 2785 forum posts 87 photos | The diamond wheels are good for light sharpening and give an excellent finish. If I have much material to remove I still use my green grit wheel. Russell. |
Paul Scholey | 16/10/2013 09:24:09 |
87 forum posts 1 photos | Thanks for the reply, sounds like one of each might be best, what abrasive grade would you go for with the silicone and where can I buy a decent one from with a makers name on it thats not going to have cracks in it ? |
Trevorh | 16/10/2013 09:38:40 |
![]() 316 forum posts 89 photos | Would it not be a good idea for someone out there to post a list of the types and colours of of the grind wheels and stones, I can never remember what is best for what, I am sure someone will know |
RICHARD GREEN 2 | 16/10/2013 09:39:34 |
329 forum posts 193 photos | ABTEC 0800 027 1928 I've used them, nice company , reasonable prices. Richard. |
donkey | 16/10/2013 16:46:02 |
![]() 85 forum posts 5 photos | http://www.georgiagrindingwheel.com/grindingwheels_basics.htm#faq2 trevorth try this for colour codes. Bri |
Thor 🇳🇴 | 16/10/2013 16:49:35 |
![]() 1766 forum posts 46 photos | Hi Trevorh, Was this the kind of information you were looking for? Thor Edited By Thor on 16/10/2013 16:50:11 |
mechman48 | 16/10/2013 17:27:19 |
![]() 2947 forum posts 468 photos | Trevor / Paul Some info from my 'Universal Grinding Data Book'... may be helpful. Edited By mechman48 on 16/10/2013 17:29:07 |
Paul Scholey | 16/10/2013 20:46:31 |
87 forum posts 1 photos | Thanks everyone for your help. |
Trevorh | 17/10/2013 09:12:08 |
![]() 316 forum posts 89 photos | Morning Thor/Mechman, Thor I was thinking more along the lines of an "idiots" guide for example HSS use Pink grit wheel, for tungsten use Green and so on Mechman sorry but I can't get your link to work Thanks |
