Member postings for RICHARD GREEN 2
Here is a list of all the postings RICHARD GREEN 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Osborn Titanic (not Titanic II) Chuck conundrum.
20/09/2022 16:27:31
Thread: Stuart steam hammer
15/09/2022 17:20:08
Hello Steve, did you make the Stuart steam hammer , how did you get on with it ?
I am about to start one,
Richard.
Thread: Stent tool and cutter grinder
13/06/2022 15:15:27
Does anyone know the maximum size of end mill the "Stent " will sharpen ?
Diameter and length
Thread: yet another angle plate
16/03/2022 11:10:23
here's some more views, I've found this fixture plate far more useful than the slots, which never seem to match up with anything you need to clamp to it.
15/03/2022 12:18:51
Fabio, whatever angle plate you buy, consider fitting a fixture plate with threaded holes like this, It makes it far more usable,
Thread: BAMFORD TULIP TOP ENGINE
06/11/2021 17:04:13
Has anyone got any details regarding the gears on the RLE engine, OD , tooth count, DP etc,
I have a set of drawings, but the details of the gears is well faded and unreadable,
Richard.
Thread: College Engineering Supplies rotary table
14/10/2021 18:11:56
Just found someone on Youtube building a geared rotary table from scrap , 3 Videos , his name is "Jeremy makes things" , films are called "rotary table from scrap"
Richard.
23/09/2021 10:57:59
I have just aquired a set of castings to build the "Bamford tulip top engine", almost identical to the engine that Ronnie Bickerton built a few years ago,
Is Ronnie still about ?
Unfortunately I have no drawings , so any dimentions would be very helpful, like bore and stroke, cam gear dimentions etc, all I know is the flywheels are 8" diameter,
Any help would be well received,
Thanks,
Richard.
Thread: Adjustable angle plate
17/09/2021 12:11:06
Here are some pictures of an adjustable angle plate I recently made from castings, 7" x 5", increased to 8" x 6" using a threaded fixture plate 5/16 UNC threads, To be used on a Tom Senior mill,
Castings were mainly machined on the Edjwick shaper.
Thread: WHERE ARE THE SHAPER USERS ?
16/03/2021 15:24:19
Posted by RICHARD GREEN 2 on 04/03/2021 17:35:13:
I've got a Klopp 34" shaper made in Germany, I would like to swap it for an open crank oil engine possibly 5 horse power or larger, what have you got ? anything consisered , e-mail me on, [email protected]
The Klopp shaper is now sold
04/03/2021 17:35:13
04/03/2021 14:09:31
BUMP...............................
Thread: Tom Senior Belt ?
22/02/2021 12:55:00
Any more suggestions ?
20/02/2021 11:47:28
Does anyone know the correct v-belt size as used in the "S" type Turret head , fitted to the Tom Senior M1 mill, It's an "M" or "Z" section belt, but I'm not sure of the proper length.
Thanks,
Richard.
27/10/2020 17:38:06
I like the idea of using two 90degree angle plates bolted together, this would give probably an unlimited combination of angles, also would be more rigid and not inclined to move during machining operations.
26/10/2020 17:43:55
Does anyone know of a supplier of a good quality (not imported) adjustable angle plate, about 6" x 4" ish, for use on a Tom Senior mill,
All I can seem to find are imported ones of varying quality,
Thread: Klopp 34" shaper
22/09/2020 17:05:59
Just seen this on Ebay , someone could use it to make a Stuart 10 v , or perhaps a clock ? Ebay No. 274503558767
Thread: Steam engines for sale website
10/09/2020 18:06:58
Does the "Steam engines for sale" website still exist ?
It had models, parts , castings, tools etc,
It seems to have disappeared.
Thread: R&B gas engine
09/09/2020 15:03:15
Can anyone give me the overall dimentions of the R&B gas engine ? length , width etc, Has anyone built it with twin 12" flywheels , what about making it hopper cooled ?
Richard.
08/05/2020 12:51:02
Posted by Alain Foote on 07/05/2020 20:45:32:
I built one years ago, I don’t recall any particular issues, I can post some pictures of it if you want.
Hello Alain, It would be nice to see some pictures of the rotary table you made,
Richard.
