Number drills
Bill Dawes13/06/2013 22:07:17
605 forum posts
I have been following the Emma Victoria series with interest.
I notice on the drawings that number drills are frequently specified.
Is it advisable to stick with these or is there a good reason not to use nearest metric equivalent.
Why are number drills still used, authenticity?
Advise from the experts would be appreciated, i am seriously considering having a go at this project so just getting my thoughts together and compiling a list of materials/tools I might need to aquire.
Regards to all
Bill D
Tony Pratt 113/06/2013 22:15:33
2319 forum posts
13 photos
I have a set of number drills but haven't used them in years, I would suggest a decent brand metric drill set will be a better bet. Generally availiable in .05mm & .1mm steps so you can pretty well cover all options.
Tony
Michael Gilligan13/06/2013 22:22:39
23121 forum posts
1360 photos
Here is a handy comparison table.
... and another, differently arranged.
Edited By Michael Gilligan on 13/06/2013 22:29:06
I.M. OUTAHERE14/06/2013 07:21:32
1468 forum posts
If you buy a set of either number or metric fractional drills buy a known brand as i have two sets that are a bit dodgy from the eastern provinces .
Can't complain really for the price as 90 % are ok but i was looking through my metric set that is .1 divisioned and stumbled upon the 9.6 and 9.8 drills that are both stamped 9.8 and measure the same !
Have the same issue with number drills from 40 up but so far the bigger drills have been fine .
Suppose you get what ya pay for !
Most you will never use so maybe just buy what you need ?
Ian
Edited By SLOTDRILLER on 14/06/2013 07:24:29
Edited By SLOTDRILLER on 14/06/2013 07:26:15
Chris Heapy14/06/2013 08:05:23
209 forum posts
144 photos
The problem with the 'buy what you need' method is that you end up not having it when you need it - so you then have to order it and wait.
Anyway, yes - some of these cheap drill sets seem to be made from high speed mild steel. Had one set that was so soft they would blunt on first use. I avoid them like the plague now. I'm still looking for a decent cobalt HSS set at something like an affordable price.
Chris
I.M. OUTAHERE14/06/2013 08:41:58
1468 forum posts
The sets i have are not too soft but rather brittle and the 5.0mm split up the middle !
If you look at a project and order what you need before hand there should be no hold up but i understand where you are coming from as everyone wants to use some wierd size drill for no rerason !
Ian
roy entwistle14/06/2013 08:51:42
1716 forum posts
Surely it doesn't matter whether you use letter, number, imperial or metric drills as long as you use the correct size or in a lot of cases near enough. You're only drilling a hole Use what youv'e got
Roy
OuBallie14/06/2013 09:26:10
1181 forum posts
669 photos
I think someone on the forum said " Buy cheap, buy twice!".
I've gone the eBay no brand cheap route, but never again!
I went through 5 x 4mm drill bits whilst fitting the roller shelves to my BH600G stand, and the remaining 5 soon after. They just snapped at the least provocation..
By comparison, I have a set of General number drill bits dating from the '70s and they are still going strong.
It's now name brand only, more expensive yes, but once only, unless I do something stupid.
Reminds me of a brand of metric sets I was selling in the '70s, from Taiwan, that I flung back at the distributor when a customer came into the shop, took a drill bit and bent it! I then did the same with another one, and everyone in the shop myself included, where goggle eyed before bursting out laughing, as this was up till then unheard off.
Nothing changes, except country of manufacture.
Geoff - Coffee time.
Ian S C14/06/2013 12:48:03
7468 forum posts
230 photos
I remember dad being most disappointed, Via his woodworking magazine he bought a set of imperial twist drill, advertised as top class English made(he thought they would be better than the NZ made drills, they were cheaper). He put a drill in the Black & Decker, and started into a bit of wood(fairly hard), things did'nt feel right, pull the drill out of the work, the twist had reversed in an area about half way up the drill!! Ian S C
KWIL14/06/2013 14:02:44
3681 forum posts
70 photos
Stick to Dormer brand A002, Greenwood Tools (usual disclaimer), just a satisfied long term user.
Nigel Bennett14/06/2013 14:21:24
500 forum posts
31 photos
Another vote for Greenwood's Dormer drills.
Going back to the OP, it's not intended that you use drills to obtain an exact size hole. Generally if you want accuracy, ream it. If you're tapping, then the tapping size drill is open to quite a bit of latitude - very often you can get away with 50% thread engagement. Usually (it depends on the material and depth of tapping) you would go for 80% - 90% thread engagement, so just choose the nerest drill you have. The 0,1mm steps between metric drills will usually geive you what you want. Charts will show you what's needed.
Number drills are often useful to open up a hole "by a few tenths" to give you a better fit with a mating part, so it's good if you have both sets.
Chris Heapy14/06/2013 14:47:16
209 forum posts
144 photos
Apart from giving you more options on size, my number set(s) are old - meaning they are much better quality drills than currently imported items. I still use them for that reason if no other. Also, I had reached the point where I had memorised the tapping/clearing sizes for all the threads I commonly used so could easily reach for the correct one without having to look it up.
Chris
magpie14/06/2013 17:24:35
508 forum posts
98 photos
Many years ago at the Harrogate show, I bought a 115 piece set from Arc Euro. 1/16"- 1/2", plus a set of number, and letter drills. When i bought mine at about 10.30 am on the friday, they had two pallets full of these sets. Having got my bargain, i went back to find my mates in the cafe to tell them. The conversation was overheard by lots of others sitting nearby all of them got to their feet and headed to the Arc Euro stand. When walking past the stand a few hours later they were down to a single layer on one pallet. Up untill that time i had never used either number or letter drills, however i now use them very often. If i need a hole to be spot-on size, i use one to drill a few thou under then ream to finish. Cheers Derek. P.S. They are still in use every day.
Stub Mandrel14/06/2013 22:08:27
4318 forum posts
291 photos
I have a full number set (very nice from Tracy Tools) and one of the 115 piece sets (cheaper but most drills OK, a few badly sharpened). Both have done sterling service. If I break a drill or sharpen one away, I replace it with a single of good quality.
That way all the ones I use a lot gradually become good quial;ity ones without the spend of buying a fuill set at top price.
magpie14/06/2013 22:36:22
508 forum posts
98 photos
I forgot to say that the reason for the big rush to buy the 115 piece set from Arc Euro **** £15.00 **** Cheers Derek.
Chris Heapy15/06/2013 00:08:02
209 forum posts
144 photos
I've seen a nice set of Cobalt HSS drills, although the point grind is a bit odd - looks like 6-facet split-point? Is this normal for these type of drills? Might be tricky to sharpen.
Chris
Metalhacker15/06/2013 08:45:40
82 forum posts
Chris,
those look good! Do you have a link? The narrowed chisel point will make them easier to start on a centre punch mark. If it wears too much they can be gashed in again from the side with a very narrow wheel or perhaps with a Dremel in a jig.
Chris Heapy15/06/2013 11:25:52
209 forum posts
144 photos
Link is here: **LINK**
Chris
Andrew Johnston15/06/2013 12:03:19
7061 forum posts
719 photos
Posted by Metalhacker on 15/06/2013 08:45:40:
Chris,
I find that quality (Dormer) 4 facet drills start quite accurately without centre pops being needed. If I need better accuracy (less than a thou or so) then I start with a carbide spot drill.
I have a set of number drills that must be at least 40 years old, but hardly use them, I rarely use threads below M3, so I don't often need small drills.
For thread engagement I normally use 60-70%, may be a bit more for fine pitches. Of course that's another reason for using quality drills, they tend to cut on size.
