Any cost-effective sources of hard (industrial) felt alternatives for wipers?
IanT | 25/05/2013 17:38:11 |
2147 forum posts 222 photos | I've just acquired a couple of old (new to me) machines that both have felt wipers that I probably will not be able to get replacements for (and they clearly need replacing - they've crumbled on removal). I've been looking for a source of "hard" felt (about 1/8" thick) sheets to make my own and although I've found several sources (e.g. British Felt etc) - it's pretty expensive stuff. Does anyone have any 'alternates' they use that are affordable? Regards, IanT |
Ian Abbott | 25/05/2013 17:46:53 |
![]() 279 forum posts 21 photos | Look up Lawrence Art Supplies online. Artists use felts to cusion the plates on printing presses. They come in different weights and in small enough sizes. Ian |
Ian Abbott | 25/05/2013 17:48:55 |
![]() 279 forum posts 21 photos | Should of course have been "cushion", but for some reason, the auto spell check isn't working. Ian |
Stub Mandrel | 25/05/2013 18:37:43 |
![]() 4318 forum posts 291 photos 1 articles | Somewhere like the Range or Hobbycraft. they probably won't have 1/8" thick, but you could laminate a four sheets. Neil |
Douglas Johnston | 25/05/2013 20:40:02 |
![]() 814 forum posts 36 photos | As an alternative to felt, I made some wipers from 1mm thick acetal sheet which I machined to an angled edge. With two layers of this it seems to be working fine and has been in place for about a year. Acetal or delrin is quite hard and slides over metal surfaces with very little friction. Mind you this stuff is'nt cheap either but you don't need much. Doug |
Les Jones 1 | 25/05/2013 20:41:40 |
2292 forum posts 159 photos |
Hi Ian, Les. |
Muzzer | 25/05/2013 21:41:10 |
![]() 2904 forum posts 448 photos | Yes, I used the adhesive felt feet sold for the bottoms of chair legs but I was able to buy rectangular sheets for cutting to your own shapes. They are typically 3"x4" or so and sold alongside the pads in hardware stores - and work out cheaper. The last piece I bought cost less than a pound ($1.25). The adhesive is basically double sided tape which peels off easily. You can use wood chisels and a block of wood to cut them out and a hole punch for the screw holes. My Bantam now sports a set of these! Muzzer |
V8Eng | 25/05/2013 22:00:45 |
1826 forum posts 1 photos | Myford fittings are available direct, any chance of using one of those? |
Ian S C | 26/05/2013 02:39:08 |
![]() 7468 forum posts 230 photos | What about an old felt hat? Ian S C |
IanT | 26/05/2013 08:07:27 |
2147 forum posts 222 photos | Thanks for the feedback guys - If I could find the 3" x 4" pads Muzzer mentions that would be a good solution I think. I may also look more closely for old hats in my local charity shops. For anyone interested in a more expensive solution - look at Britishfelt.co.uk. A 3mm hard grey felt (183cm x 1/2m) will set you back £39.14 (plus P&P). In 6mm the same money will get you a 183cm x 1/4m piece. If you want the white felt - its 150cm wide and will set you back £55.93 for 1/2m of 3mm or 1/4m of 6mm. Regards, IanT |
Les Jones 1 | 26/05/2013 09:43:47 |
Hi Ian, Les. Edited By Les Jones 1 on 26/05/2013 10:06:24 |
John Stevenson | 26/05/2013 09:46:33 |
![]() 5068 forum posts 3 photos | Jesus, Why didn't anyone ask when I worked at the piano company ? We had miles of the stuff, all colours and thickness's. If we didn't have the right thickness we had the skiving machines to par it to any size.
I used to get white felt cut 3/8" x 3/8" in foot strips for the vintage car boys for rear oil seals on the cranks. Might still have a bit of this left, I'll check later. I think I put 1/8" green felt in the bottom of my wooden toolboxes but this will be quite grubby by now. |
FMES | 26/05/2013 09:51:04 |
608 forum posts 2 photos | Ian, I have some approx 1/8" thick felt sheet kicking around in the workshop somewhere, you are welcome to a lump of that if it would be useful. |
John Stevenson | 26/05/2013 09:59:32 |
![]() 5068 forum posts 3 photos | This looks interesting.
Brian Wood | 26/05/2013 11:25:37 |
2742 forum posts 39 photos | Hello Ian, out of intertest I've just looked at ebay for hard felt fabrics, there seem to be plenty of choices in weight, colour and price to select from. You can also buy my the metre from anothe site [Anglo felt] but that is a more expensive route. They do offer different grades though. I think you will find all you need on ebay Regards Brian |
DMB | 26/05/2013 11:43:57 |
1585 forum posts 1 photos | Another possibility is a shop selling material - got some from a local shop in Kensington St or Gardens? in Brighton. I thought it was a reasonable price @ the time + no p&p. |
Nobby | 26/05/2013 18:54:25 |
![]() 587 forum posts 113 photos |
Hi Ian and guys |
Russell Eberhardt | 26/05/2013 21:38:32 |
![]() 2785 forum posts 87 photos | Buy the real thing. Genuine oil seal felt in small quantities here: **LINK** No connection but I've bought from them in the past. Russell. |
Muzzer | 26/05/2013 21:41:49 |
![]() 2904 forum posts 448 photos | When I do a search on B&Q website for "felt pad", I get loads of hits including a rectangular "felt pad cream" - 2" x 4" for a pound. Are any of those any good? Muzzer |
IanT | 26/05/2013 21:48:40 |
2147 forum posts 222 photos | I did look at eBay but only seemed to find 'art' (soft/coloured) felts - the word "pad" clearly makes quite a difference! There were several options that could have been useful but the best deal I found (that I will order tomorrow) was for Qty 2 110 x 150 x 5mm square felt pads from a company called Haldons. At £3.75 that's more like my price point! Lofty - thank you for your kind offer & Graham, I hadn't thought of leather but one of the machines (Atlas 7" shaper) uses a combination of felt and plastic wipers on the ram (felt to retain oil and plastic to keep the crud out I'd guess). I think I will try a felt/leather combination for that application (I have an old leather belt that will donate a few pieces large enough - I'm afraid it no longer seems to fit me in retirement!). Regards, Ian T |
