mick H | 01/05/2013 14:53:26 |
795 forum posts 34 photos | I have a Warco WM14 mill drill which has a tilting head facility. When I bought the machine I thought that this facility would prove to be of great use but I have subsequently found that I can achieve any "tilting" that I require much more easily with a tilting vice. I would like to accurately set and fix the column in a more stable and permanent manner than the current swivel bolt arrangement. Any ideas would be welcome. Mick |
Brian Wood | 01/05/2013 15:39:53 |
2742 forum posts 39 photos | Hello Mick, I don't know the machine in any detail, but if you are happy to do so, once it is set truly correct, I would drill, ream and dowel the head and column together to lock them in postion. Do it in two positions to avoid any risk of jacking out from vibration in subsequence use. Headed dowels will also prevent them from 'walking' in as well, rather on the lines of a gib headed taper key. It might also be a prudent precaution to provide a threaded socket end on the dowels, before fitting, to enable a subsequent owner something to extract them with if they wish. Regards Brian |
John McNamara | 01/05/2013 16:13:40 |
![]() 1377 forum posts 133 photos | Hi Mick H Threaded socket end taper or straight dowels are available. In fact my Shizuoka vhr-g Mill uses Taper pins to lock at zero the head in 2 planes. They are not a perfect fix, you still need to tweak the last couple of thou to align the head if you are doing accurate work. but the pins do get you close. Taper pins are better and easier to withdraw (some have a nut on the end to pull them out), however you will need to make a taper D reamer out of silver steel and harden it or buy one to prepare the hole. As Brian Wood mentioned two may be better than one, However there will always be a tiny error if you remove them move the head then move it back and replace them. Or maybe a little crash disturbs them Hmmm...... You could of course make your own pins. Maybe from a High tensile bolt? turn the head off and then lock two nuts on the threaded end (You will have to try a few of nuts until they lock with the flats aligned) then clamp the nuts in the three jaw and turn the taper on the lathe. With light cuts it should work without support from the tail stock, although you could use the tail stock if needed. This method makes sure the threaded end of the bolt is not damaged by the chuck. Cheers John |
mick H | 01/05/2013 17:12:35 |
795 forum posts 34 photos | Thanks, Brian and John. May I also ask you for your observations on whether a more practicable route towards ensuring accuracy might be to invest in a twin clock tramelling device. Mick |
Tony Pratt 1 | 01/05/2013 18:10:50 |
2319 forum posts 13 photos | Hi Mick, you really do not need to invest in a twin clock tramming system, learn to use a single clock and save your hard earned £'s for something more useful. There are numerous threads on the net discussing the pros and cons of various tramming methods. Tony |
Thor 🇳🇴 | 01/05/2013 18:18:50 |
![]() 1766 forum posts 46 photos | Hi Mick, several have wanted to do something with the column. I dont't know if you have found these sites?,
Regards Thor
Brian Wood | 01/05/2013 21:07:59 |
2742 forum posts 39 photos | Hello again Mick, I agree with Tony in his advice over tramming heads, I don't use one believing one DTI swung round from the spindle is much better. It saves you money and who can guarantee the two clocks on a trapping heads respond identically? An expensive gimmick in my opinion Regards Brian |
Paul Lousick | 02/05/2013 00:17:49 |
2276 forum posts 801 photos | I seldom use the swivel facility on my mill and normally use a tilting vice for angled milling but would not think of locking it in a fixed position. It is there for those odd accasions when I may need it. Does not take long to check the alignnment of the mill head by swinging a single DTI around the spindle. The twin clock gadget is a nice toy but is not needed. You still have to swing it thru 180 degrees to check that both clocks are reading the same.
John McNamara | 02/05/2013 01:01:19 |
![]() 1377 forum posts 133 photos | Tramming: I normally just swing a dial indicator mounted in the spindle on the table, you have to be careful because the probe can get damaged in the T slots. and it does jump around a bit if the table is old and has a few battle scars. not good for a precision indicator. I recently had to replace the brake discs on my car as they were out of spec. one of them is about to become a tramming aid. I plan to turn the projecting hub off just leaving the disc itself, then face both sides flat on the lathe. (That will be an interesting exercise in itself to get the sides perfectly parallel) For tramming I plan to place the disc on the bed of the mill and run the indicator in the spindle over the nice clean surface. Maybe I will get around to making a nice holder for the indicator...
This is not my Idea but it should work well. Cheers John
mick H | 02/05/2013 07:45:09 |
795 forum posts 34 photos | In retrospect, perhaps I am making something out of nothing. By the sound of it I would be best advised to perfect the tramming technique......I do like the sound of the disc though. Thanks for all your answers and interest. Mick |
Paul Lousick | 02/05/2013 08:41:17 |
2276 forum posts 801 photos | I recently used an old disc brake as a mounting plate on a lathe while boring a hole. The job was difficult to hold in a chuck or existing face plate so faced both sides of the brake disc and bolted the casting to it. (casting had 6 tapped holes on the opposite side) |
Gordon W | 02/05/2013 09:27:14 |
2011 forum posts | Buy a new brake disc, very cheap on some models, you'll have to search the net for best buy. |
Brian Wood | 02/05/2013 09:54:02 |
2742 forum posts 39 photos | John Mcnamara. I suggest facing the disc on BOTH sides in one holding if you can BEFORE you remove the hub, that way you have a sporting chance of getting them parallel. If you have a fine diamond plate run that over the turned surfaces as well to leave a nice smooth finish that is kind to the tip of a DTI. Regards Brian |
John McNamara | 02/05/2013 13:34:52 |
Thanks Brian
Hi Gordon
Hi Paul Good idea...
cheers Edited By John McNamara on 02/05/2013 13:35:43 |
Gordon W | 02/05/2013 14:24:51 |
2011 forum posts | I make almost everthing out of scrap when possible, and it usually shows. Just that I can't swing a brake disc on my lathe, not even off the 2CV. |
Russell Eberhardt | 02/05/2013 14:53:42 |
![]() 2785 forum posts 87 photos | I very rarely tilt the head on my mill but it is useful on occasions. I can get a better finish on some materials when surfacing with an endmill if I tilt the head about 1/2 degree so that the trailing edge doesn't rub. Russell. |
joegib | 02/05/2013 15:20:19 |
154 forum posts 18 photos |
With respect I don't really see the need for rings to carry out this job. The object of the exercise is to take 2 readings, East and West, to establish that the machine spindle is truly perpendicular to the plane of the table in the X axis. As long as the Dial Indicator(DI) is solidly mounted in the spindle there's no necessity for the DI to be in continuous contact with the table or a ring as it is swung through 180*. Edited By joegib on 02/05/2013 15:22:17 |
Douglas Johnston | 03/05/2013 09:19:01 |
![]() 814 forum posts 36 photos | I use a piece of plate glass on the mill table when tramming the mill. I checked out the flatness and whether both faces were parallel before use and found they were spot on. Doug |
mechman48 | 03/05/2013 10:37:56 |
![]() 2947 forum posts 468 photos | Hi Mick Cutting a long story short I fabricated two blocks & attached them to my WM column, & head,one either side, after tramming & locking everything in place, any angled work I have had to to (minimal ) I have used my tilting vice, see pics Cheers George |
Geoff Theasby | 03/05/2013 11:22:36 |
615 forum posts 21 photos | The 'granite' table mats sold by many supermarkets for a few pounds are accurate enough to be workable surface plates, and also make a good plane surface for tramming your mill. Regards Geoff |
