Free Machining Stainless Steel
Stub Mandrel12/12/2012 20:23:35
4318 forum posts
291 photos
I just proved free machining stainless really exists. I carefully turned the end of a bit of 3/16" SS down to 0.125" to fit a crank, and cut a 5BA thread on the end using the tailstock die holder and mandrel handle.
I thought the thread looked a bit undersize, then discovered I had cut a perfect 6BA thread... no damage to the die as far as I can see!
Siddley12/12/2012 20:34:05
150 forum posts
Nice work...if you know where there is any free machining titanium I'd love to buy some - all mine is of the opposite variety
Kevin F13/12/2012 23:08:08
96 forum posts
24 photos
Posted by Stub Mandrel on 12/12/2012 20:23:35:
I'm guessing that you properly machined some 302 or 304 stainless bar as its relatively soft compared too  316, the latter is horrible to machine
Edited By Kevin Fenrich on 13/12/2012 23:08:43
Edited By Kevin Fenrich on 13/12/2012 23:09:43
John Stevenson14/12/2012 09:10:39
5068 forum posts
Free machining is 303.
304 is like witches tits.
Free machining titanium is grade 2, grade 9 is like empty witches tits. Never come across grade 1, they always supply me grade 2, still tight when drilling and tapping though but with barbide turning tools and end mills it machines similar to 303 stainless.
Be aware that many grades of material are not available in certain sections unless you won't to pay setup prices. 303 isn't available in flat plate for instance, that's usually 304 or 316.
John S.
Siddley14/12/2012 16:14:44
150 forum posts
I've got quite a lot of 6AL4V - turns OK but it's nasty stuff to drill and tap. Got any tips on that score John ?
Grizzly bear14/12/2012 20:53:16
337 forum posts
8 photos
Hi John, I would like to learn more about witches tits.
Regards, Bear..
Ian P14/12/2012 21:20:14
2747 forum posts
123 photos
303 Grade SS is a pleasure to work with. I find it easier than free cutting MS, not a lot more expensive, and need no further finishing.
304 is not too bad to work, I'm surprised John S likens it to WTs, things that I've not heard of, maybe it because I dont get out often enough, or just lead a sheltered life.
Ian
Maybe WTs are a compliment, or would they have to be full then?
Ian S C15/12/2012 09:58:20
7468 forum posts
230 photos
I'v found that even 316 is not too bad, apart from great streamers of swafe, made some hot ends for Stirling Engines from it, could only get solid bar at the time, had to bore it out to 1 3/4" x 3" deep, I'll admit it took time, but it's still in use 20 years later. Ian S C
David Clark 115/12/2012 10:02:55
3357 forum posts
112 photos
10 articles
Hi There
I seem to remember there were two types of 316.
316 AM, easy to machine
316 J just turns red hot when you try to cut it.
From memory of about 35 years ago.
regards David
Stub Mandrel15/12/2012 16:38:48
4318 forum posts
291 photos
I'd guess it was 303 then, I just bought it as free machining stainless to make some piston rods.
merlin17/12/2012 00:24:10
141 forum posts
I am interested in all aspects of models; if you manage to turn a WT, does the W turn with it?
jason udall17/12/2012 00:37:35
2032 forum posts
41 photos
Posted by merlin on 17/12/2012 00:24:10:
Only after 720 degree lag
Edited By jason udall on 17/12/2012 00:46:44
jason udall17/12/2012 00:47:07
2032 forum posts
41 photos
Btw worked with 1.6mm threads in 316S11 (L)..tapped 10X dia..1mm holes internaly deburred... polished to "mirror" finish (what ever that means)..
1mm holes through 20 degree included angle cone.316 is also know as surgical stainless..all worked in hardened form........Such fun yeild as low as 1 in 4..ie 1 completed part out of 5 started!...thouse taps argh!
Philip Leith17/12/2012 11:02:32
15 forum posts
Just taken apart a water pump and found that the shaft is worn (around 12mm by 100mm). Supplier says no longer able to get replacements. He says he thinks it is "hardened 316".
Machining isn't too complecated - just two flats on one end and a channel on the other.
Not sure about hardening this though - any thoughts?
Philip
Tony Jeffree17/12/2012 11:06:53
569 forum posts
20 photos
Only if you pay close attention to the clamping disgust
Tony
Andrew Johnston17/12/2012 11:20:17
7061 forum posts
719 photos
Philip,
It is not possible to harden 316 using heat treatment. You have to use cold working methods instead, which may not be practical for a shaft. See this link:
Philip Leith17/12/2012 11:25:18
15 forum posts
I wondered if heat hardening 316 was possible - thanks for confirming it isn't.
Not really sure hardening is required anyway - there are two rubber seals and three bearings, and no other metal contact.
Philip
jason udall17/12/2012 12:20:08
2032 forum posts
41 photos
316 work hardens with great ease.. the trick is doining it as required...in any case parts of spindle that are in contact would benifit from burnishing.. which will achive that end.
hawkeyefxr15/05/2013 07:11:51
13 forum posts
Year ago i came across free cutting stainless quite by accident. I was the machinist in a heavy industry factory.
One of my smaller jobs was to make SS nuts out of 2in bar, they had a tapped hole in the moddie and were anout 3/8 thick. I used to part them off using a parting off tool.
I decided to put the cross feed on auto one day and it worked perefectly. I only got one cut out of the tool and had to touch it up with a stone after every cut but it worked. The finish was like chrome, there was no juddering or tool bits snapping.
mechman4815/05/2013 10:01:13
2947 forum posts
468 photos
Witches Tits.. can't connect the analogy dont know ??? Maybe my old grey matter is worse than I thought, enlightenment would be nice! or am I missing something?
