John Stevenson | 03/11/2012 22:53:45 |
![]() 5068 forum posts 3 photos | Been to Comet today to see if I could get any bargains related to the workshop.
Bought a chainsaw, got it home, unpacked it but having a few problems with it and wondered if the combined expertise of this forum could shed some light on how this works ?
John S. |
Martin W | 03/11/2012 23:06:56 |
940 forum posts 30 photos | John
I would have thought that the manual would have had a few useful 'links' showing how to use it Hope you sort it out. Cheers Martin
ps You have far too much time on your hands |
Trevor Drabble | 03/11/2012 23:46:16 |
![]() 339 forum posts 7 photos | John, Can spot 3 problems straight away ! One is that the wing nut is at the back rather than the front where it should be , and also, assuming one is right handed, starting will be almost impossible , because the pull cord is on the wrong side of the handle ! And finally, the pitch of the teeth is far too coarse for normal use, which may explain why it was bargain. Assume they had run out of finer pitch versions ? Trevor. |
NJH | 04/11/2012 00:56:35 |
![]() 2314 forum posts 139 photos | Hi John I think you were sold a pup there but - fear not - I've managed to fix it for you. I know it's a bit rough but I hope you don't feel too "sore" about it! I know you favour the bigger jobs so maybe it will come in useful. Cheers Norman Edited By NJH on 04/11/2012 00:57:59 |
Les Jones 1 | 04/11/2012 09:49:38 |
2292 forum posts 159 photos |
Hi John, Les. |
Gordon W | 04/11/2012 10:16:57 |
2011 forum posts | It will cut perfectly well, just needs the speed increased. |
FMES | 04/11/2012 10:38:25 |
608 forum posts 2 photos | They didn't have any left handed versions left, did they? |
Ian S C | 04/11/2012 10:42:09 |
![]() 7468 forum posts 230 photos | You sure its not an electric saw, either the battery is flat, or its a mains one, and they forgot to give you the plug, There's a bloke it Christchurch NZ who has had one for many years, his has a three pin plug (female), on a short flex. Ian S C |
Bazyle | 04/11/2012 12:05:20 |
![]() 6956 forum posts 229 photos | I prefer a brass band saw but as the tuba player is at Sandown today I'm using my small bandsaw. |
Martin W | 04/11/2012 12:16:44 |
940 forum posts 30 photos | Bazyle
Had thought about buying one of those but it was stretching my budget too far and besides the company couldn't or wouldn't supply the figures for the elastic limit of the blade Cheers ps Rymans do a good selection of blades at reasonable prices and they are colour coded as well. |
Stovepipe | 04/11/2012 12:46:27 |
196 forum posts | ...and ArcEuro part number is ??????? Dennis
NJH | 04/11/2012 13:07:14 |
![]() 2314 forum posts 139 photos | No Dennis I think the ArcEuro part No. is more likely to be *******!!! No doubt John will enlighten us when he finally gets up! N |
harold | 04/11/2012 13:30:37 |
35 forum posts | I think you may have misinterpreted the instructions. The saw will obviously fail to work in its current orientation. Turn it around so that the handle is on the right and all will be well. HTH. |
Stub Mandrel | 04/11/2012 14:47:39 |
![]() 4318 forum posts 291 photos 1 articles | You're all missing the point - it's an electric chainsaw, probably three phase, it just needs to be plugged in. The only chainsore I've got is from this one around my ankle... Neil |
speelwerk | 04/11/2012 14:52:11 |
464 forum posts 2 photos | Its a most rare model for a prison chain gang. Niko. |
Bazyle | 04/11/2012 16:01:00 |
![]() 6956 forum posts 229 photos | thanks for the tip Martin, I got the red one mail order - well the postman brought it anyway. By the way mine is not electric, it is powered by Custard Creames. |
Cyril Bonnett | 07/11/2012 22:37:37 |
250 forum posts 1 photos |
Did you remove the chain guard on your chain saw as sawing chains without it you'll have links flying every where, then you spend ages hunting for the missing links. My advice wood be to take it back to the chain store, get your money back head for the pub |
Nicholas Farr | 08/11/2012 19:25:20 |
![]() 3988 forum posts 1799 photos | Hi John, was it advertised as an engineers chainsaw? Because I reckon it's a fake if it was. It must be about 99 feet to short, and that might be why it's not working properly. If it is a surveyors one, then it's still about 65 feet to short. Regards Nick. |
