MEW 194 - Electric Motor Warning
Thank You ...
Michael Gilligan03/09/2012 17:13:45
23121 forum posts
1360 photos
I would just like to publicly thank Mike Joseph, for his timely warning about the internal wiring in old Electric Motors.
Based on Mike's advice; I have just had a look at the Hoover motor that I have been storing for years [in the hope of, one day, finding a good use for it].
Just like Mike's ... the Rubber insulation was crumbling.
I recovered the four long "holding-it-together" screws, and the brass electrical terminals ... The rest has gone to the Tip.
WALLACE03/09/2012 20:52:35
304 forum posts
17 photos
Hi Michael.
I need to look at several.motors I have which are the same type as well - but, I'd be a lot more tempted to rewire them.
I don't want to stir up the health and safety hornets nest, but I've converted a few 440 volt 3 phase motors to 240, with new cable, heatsink tubing to cover any soldered joins, tied it all down with wax string and finally coated it all with lashings of varnish.
To make sure it was all ok, I tested the insulation with a 500 volt 'megga'.
It's not just the meanness that appeals to me in rewiring a Hoover motor, I've also found that they run a lot smoother than a modern day one - and it does seem a shame to bin something that is probably repairable if you take care and have a reasonable understanding of what you're doing.
W.
Edited By WALLACE on 03/09/2012 20:54:23
Stub Mandrel03/09/2012 21:05:56
4318 forum posts
291 photos
I have a Hoover fractional and it's lovely. The wiring is intact, but I'm going to replace it with PVC covered wire soon.
I agree the quality is exception. plus it will work hard for agesw without getting more than warm.
Info plate of hoover motor
Michael Gilligan03/09/2012 21:11:38
23121 forum posts
1360 photos
Fair comment Wallace ... you obviously have the skills, time, and patience.
I was quite disappointed to let the Hoover go; they're stylish as well as smooth running.
Oh well; there's a bit more space under the bench.
john fletcher 104/09/2012 08:16:08
893 forum posts
What a shame to discard a motor for such a simple fault, as Wallace says, its very easy to fix a motor. Just work with care,after all that is all the rewind people do. Also those motors are very silent running as they used sleeve bearings, modern ones use ball bearings.Ted
Ady104/09/2012 08:28:37
6137 forum posts
893 photos
The old stuff is good quality gear made to last a lifetime
Needs fixed/refurbished every 20-30 years though
Michael Gilligan04/09/2012 09:26:55
23121 forum posts
1360 photos
O.K. Guys ... Don't rub it in !
[Always happens when I finally throw something away]
Ian S C04/09/2012 15:36:07
7468 forum posts
230 photos
We'v just replaced the air pump in the church pipe organ, the 1hp motor on the old pump was dated 1917, the bearings (two at each end with a ring oiler), 1" long X 1" dia. The wiring was replaced about 15/20yrs ago, the field coils double cotton covered over enamal, and the cotton was still OK, I wonder if the new motor will last as long? Ian S C
Ian P04/09/2012 16:16:33
2747 forum posts
123 photos
Have you replaced the motor or the pump, or both? I know the guarantee had probably run out but what actually failed?
Ian
Stub Mandrel04/09/2012 19:39:19
4318 forum posts
291 photos
If Ian was in the UK it would read "We've just replaced the air pump in the church pipe organ. the old pump was dated 1917 and the lad who works it just got a telegram from the queen and says he's retiring."
Ian S C05/09/2012 13:58:58
7468 forum posts
230 photos
Nothing wrong with either the blower, or the motor, someone decided to modernise, the old blower was at the opposite end of the building, with a long length of ducting(leaky) to the organ at the front of the Church, the new one is inside the Organ. The old blower would be great for a forge.
Ian S C
jason udall05/09/2012 14:27:30
2032 forum posts
41 photos
"with a long length of ducting(leaky) to the organ at the front of the Church"...
might not been better to replace DUCTING?.. odds is the fan etc was probalby mounter remotely for a reason...
BTW Ian , one of the successful (commercially) uses for stirling engins (C19) was to drive church organ pumps...quiet and easier to "use" than steam .... at least until electric motors...
Stub Mandrel09/09/2012 21:26:19
4318 forum posts
291 photos
I was merrily machining away today when phut! the motor stopped and lights went out - the workshop box had tripped. Tried rpelacing the (5A) fuse still pop - right back to the house box!
Much mulit-metering which showed motor coils and insulation OK (>20Megohms) and also took the inside plate off - to show my motor is all PVC wiring in good condition, just the capacitor is rubber covered (but still good - and being external is visible). Didn't solve the problem though
Motor ran OK with NVR/filter box bypassed - it turned out the rectifier for the relays had gone dead short across the AC terminal. replaced and now OK.
I was surprised this blew, as it was out of the old mini-lathe control box, passing 300W for the motor, whereas I was only using it to provide enough for two.tiny relays - about 20ma.
Sam Stones10/09/2012 04:37:07
922 forum posts
332 photos
Gentlemen,
Every since our well-known brand of washing machine packed up some years ago, I have been suspicious about certain applications where PVC covered wiring had been installed.
After removing the cover of said machine, I found that spade terminals had been used to connect the mains supply to the built-in water heater. (I can't recall the heater Wattage.)
That’s fair enough, but on closer inspection, I discovered that a couple of cm's of PVC insulation leading away from both terminals had largely disappeared, exposing the solid copper wire, or what was left of it. The single strand copper wire was much thinner at the spade terminals, tapering to almost nothing. In fact, one of the copper leads was so thin it had failed and gone open circuit.
I contemplated the possibility that either the spade terminals or more likely the heater itself had been overheating. This would initiate a degradation process in the PVC insulation sufficient to produce hydrochloric acid. In turn, the acid would then attack the copper, thinning it even more, and thus accelerating failure.
I realise that there must be vast quantities of PVC cable in use, so is this an isolated case?
What do you think?
Sam
Michael Gilligan10/09/2012 09:05:15
23121 forum posts
1360 photos
Footnote:
I just found this useful PDF document on Induction Motors in the Home Workshop.
ALAN EARL25/11/2014 16:17:56
5 forum posts
JUST NOTICED THIS ON MOTORS DOES ANYONE KNOW HOW TO REVERSE ONE OF THESE HOOVER SINGLE PHSE MOTORS MINE DOES NOT HAVE AN EXTERNAL CAPACITOR AND LOOKING INSIDE I WAS UNABLE TO IDENTIFEY WHICH WIRES TO CHANGE OR IF IT CAN BE REVERSED A.EARL
norman valentine25/11/2014 16:28:18
280 forum posts
40 photos
Alan, I am not an expert, so can't be relied on but I have one of those lovely Hoover motors. I wanted to fit it on a machine that needed to run in either direction. I identified the pairs of wires that fed each coil and after that it was quite easy following one of the diagrams in Tubal Cains "Model Engineers Handbook". I have to admit that I melted the capacitor at the first attempt but now it works fine.
Edited By norman valentine on 25/11/2014 16:28:39
colin hawes25/11/2014 17:26:35
570 forum posts
18 photos
My ancient 7" Drummond came with a lineshaft and an equally ancient Brooks motor with a contact starter. The motor failed twice through metal fatigue in the very visible windings. After I soldered the breaks twice, without having to dismantle anything, I decided I couldn't win and scrapped the motor. Colin
