New blocks on the kid ?
John Stevenson22/03/2012 22:02:17
5068 forum posts
Or is that new blocks on the block ?
Not an advert because I'm not selling them but coming to a store near you shortly.
5C collet blocks in hex and square, been around for years, very handy for dropping in the vise and doing to odd quick and dirty hex or square by just turning the block over with the part in the 5 C collet.
Ideal for laying down but not so handy stood up.
Soooooooo..........
Allow me to present the same style of block but in ER32 format.
Advantages are shorter, can stand upright on the ground to a gnats left bollock rear face, no gaps from 0.5mm to 20mm with the ER 32 series collets. That's 20 thou to just over 3/4" for the unwashed.
Added bonus is when used in the horizontal mode because the nut is larger than the body the back surface of the nut can be used as a dead stop in the vise.
Very precise macro photo reworked in photoshop to give the impression of a blured image [ not easy I can assure you ]
PS, The floor has also been done in Photoshop.
John S.
__________________
NJH22/03/2012 22:07:38
2314 forum posts
139 photos
Nice idea John - but photography - maybe stick with metalwork?wink
N
JasonB22/03/2012 22:31:32
The backstop facility must be governed by how much you tighten the nut. So you could get bit of a different setting each time you change a part.
J
John Stevenson22/03/2012 22:55:20
5068 forum posts
Yes but they will be consistantly wrong if you don't measure the first cut wink
John S.
Flying Fifer22/03/2012 23:55:41
180 forum posts
John,
Just when I was going to buy a set of ER20 collets you come up with this ! Looks like I`ll have to save up a few more pennies for an ER32 set.
Like your 1-2-3 blocks another brilliant idea. Whats next???
Alan
chris stephens23/03/2012 00:19:16
1049 forum posts
Hi John,
Nice idea but I have one slight quibble, don't ER32 collets only go down to 1.5mm (if you buy Arc's 2.0-1.5 special) or 2mm (3-2mm) if you buy the usual ones.
chriStephens
John C23/03/2012 07:12:26
273 forum posts
95 photos
Hi John,
Are there any plans to do the same in ER25 size?
Thanks,
Stewart Hart23/03/2012 08:27:35
674 forum posts
357 photos
Great inovation.
I can see quite a few uses for then.
They are going on my shopping list
Stew
Ian P23/03/2012 08:44:44
2747 forum posts
123 photos
Posted by John Corden on 23/03/2012 07:12:26:
Hi John,
Thanks,
This is another request for ER25
Or, what about a ER25 ID to ER32 OD adapter sleeve (and 'washer' for front of collet?)
Ian P
Ian P23/03/2012 08:47:27
2747 forum posts
123 photos
Are the blocks through drilled to accept work longer than the collet?
Ian
Edited By Ian Phillips on 23/03/2012 08:48:00
Russell Eberhardt23/03/2012 09:50:24
2785 forum posts
87 photos
On my shopping list. Much easier than winding the handle on my dividing head 22.5 turns between each face to cut squares!
Russell.
Les Jones 123/03/2012 10:16:38
2292 forum posts
159 photos
They also look useful for holding milling cutters for sharpening on one of Harold Hall's grinding rests. I too would like them in ER25 size.
Les.
John Haine23/03/2012 12:01:16
5563 forum posts
322 photos
Er40 for me - I bought a set for my big bore super7.
Ketan Swali23/03/2012 12:28:57
1481 forum posts
149 photos
Link here:
http://www.arceurotrade.co.uk/Catalogue/Collets/ER-Collet-Fixtures
Ketan at ARC.
Another JohnS23/03/2012 12:29:33
842 forum posts
56 photos
JohnS - For the marketing types:
With expensive sets (top quality??) of ER-16, ER-25 and ER-40, I doubt I'll pick up a set of ER-32 collets just to use with these blocks... Funny that they only come in 1 size...
Another JohnS.
David Clark 123/03/2012 12:44:52
3357 forum posts
112 photos
10 articles
Hi there
No need to spend a fortune.
Buy a parallel shank ER holder, drill and bore hexagon and/or square blocks to suit and grubsrew and Loctite the shank in the block. Dirt cheap from Honk Kong and Ebay.
Job done and very cheap, you could use a smaller ER system as well.
regards David
John Stevenson23/03/2012 13:02:20
5068 forum posts
Posted by David Clark 1 on 23/03/2012 12:44:52:.
regards David
Bit of a smack in the eye for your advertisers David ?
John S.
peter walton23/03/2012 13:47:14
84 forum posts
I think the real benefit David is if you already have ER32 collets and nothing gained on the price that I can see!
peter
john jennings 123/03/2012 14:23:59
69 forum posts
These are very similar to some lower tech items I made some years ago.
The start point was a number of spare chucks (5/16 capacity) for some brand or other of handrill (the sort with a geared handwheel disc driving pinions) bought after a local store had a flood. The chuck screws on to the main arbor and is closed as the arbor screws home and therefore has a 0 to max capacity.
After cleaning and derusting the initial addition was a T handle to use primarily as a tap wrench.
This was followed by a 1" square and 1" hexagon bars (3" long ) turned and screw cut one end to receive the chuck. The required thread was some odd diameter 19 t.p.i. but needed screwcutting anyway to ensure concentricity.
Not precision kit but a useful trio of extra hands.
modeng200023/03/2012 15:19:50
340 forum posts
That is just what I'm thinking of doing David since Arc Eurotrade do not have the ER25 size.
