Member postings for peter walton
Here is a list of all the postings peter walton has made in our forums. Click on a thread name to jump to the thread.
Thread: Chester DB10g drive belt
03/10/2020 17:44:35
Well glad to say I'm now back up and running!
Got 2 belts from Arceurotrade the belts are for a Sieg C6 (a lot of parts are the same)
part number C6-944 Timing belt 1.5*124*15
Fits perfect!
Peter
30/09/2020 23:06:48
After 15 years the drive belt on my Chester DB10g lathe has bit the dust.
Has anyone found a replacement belt - it seems from the web a rare beast.
Best I could find was that it was a module 1.5 which gives it a 4.7 mm spacing.
These I have not found on searches.
Peter
Thread: John Stevenson
20/10/2017 15:12:30
Get well soon John
Peter Walton
Thread: Looking for a 1/4" ratchet
08/02/2017 23:28:41
Hi John,
Try this **LINK**
Good quality and small in size.
peter
Thread: Air casters
30/10/2016 09:07:38
Use rollers instead of wheels or even lots of ball bearings on a rod.
peter
Thread: silver soldering-not getting burnt
12/10/2016 23:06:42
If you are worried about the heat get a pair of Kevlar gloves not cheap but good for the job
peter
https://www.cromwell.co.uk/shop/personal-protection-and-clothing/cut-protection/product/p/PLY9611313D
Like these
Edited By peter walton on 12/10/2016 23:14:26
Thread: Delivery Problems
02/10/2016 23:57:02
We had a Hermes delivery that 'was delivered to a safe place', so far we haven't found the place but we did get the replacement!
Or Parcel Post where we got the note through the door, the driver must have had running shoes on as no sight of him when I got to the door!
Peter
Thread: Windows 10 Anniversary Edition - Any Experience Yet?
23/09/2016 23:08:05
Ran the upgrade this afternoon all appeared to go well but for one thing - MS Network Monitor now no longer works.
Said to try version 3.4 but that refuses to load!
Apart from that loss seen no real difference yet - apart from log on screen has changed.
peter
Thread: Who supplies Stellite no 6 bar
15/09/2016 23:15:40
You can get stellite welding rods to hardface the surface of your project.
peter
Thread: What email client
09/03/2016 11:21:24
The 'Cloud' is all well and good until as last week our router said it had a good connection but no response from the web - so what do you do then.
I have tried to find out what happens when you have software that runs from the 'Cloud' and you loose connection, anyone know!
peter
Thread: Any spot welder experts about?
16/12/2015 22:28:18
The tabs on NiCad batteries are spot welded using a capacitive discharge welder.
Do a search on google!
Plenty of info for self build
peter
Thread: Cleaning alloy castings
04/05/2014 10:18:42
Best thing I have found to clean aluminium is boiled rhubarb is also fairly gentle on the ally.
Rhubarb contains some oxalic acid, even more in the leaves, use warm and it will clean off the oxide layer! wash well afterwards.
peter
Thread: Working phosphor bronze sheet.
13/04/2014 14:09:18
I think I would be very wary about attaching anything to the camera lens as the lens motor may be damaged by the extra load imposed.
Cannot you make the filter holder cover the entire lens allowing for the full movement of the lens.
peter
Thread: Do aliens make this stuff?
24/02/2014 09:20:15
When I first started work, I was a spectrographer and was asked to identify a lump of white very light metal, luckily I shaved a few slivers off it and arced them - magnesium!!
So glad I didn't just run an arc on it!! What a firework display that would have made!
Peter
Thread: Flood protection
15/12/2013 16:06:02
Your biggest problem is any air bricks and then the waste water system. If the surge is of ant depth it will come up the loo.
To my mind you will need a motorised water pump to remove any water that does get in. The next problem is how quickly the water level will go down.
Personally I would just hope the next surge is 100 year's away.
Peter
Thread: Should I get a boiler certificate?
27/10/2013 10:12:03
You should also check your household insurance details, as if the boiler does fail the insurance company will not pay out!!
peter
Thread: Is it just me?
15/09/2013 13:01:06
Sometimes I just wonder what people are expecting in a magzine.
Are they expecting to learn something new and exciting every time, they will always then be disapointed.
For myself I read the magazine always with a'pinch of salt' in that I may not realy be interested in the subject but subconsciously will have stored snippets of information which hopefully will surface when needed.
As to CNC, I like to read items on this subject as I am still learning about the subject, I have even CNC'd my small mill, not that I have done all that much with it. I still have to conquor the art of material holding( good subject fot the mag) as I find that my knowledge is lacking in this respect as the amount of trashed jobs will testify.
Perhaps its time for the detractors to offer their services and actuall y produce some articles they would like.
Peter
Thread: Tig Welding
22/07/2013 08:48:46
Have a look at this John
Dosent seem all that cheap though!
peter
Thread: Silver solder ?
08/07/2013 15:04:22
Just been in the garage and noticed my pack of 'Sil-Phos' brazing rod, ok for car or gap filling jobs not sure it is of any use for boilers etc but the bees knees on the body work!
peter
08/07/2013 11:44:40
The use of brazing rod on boilers is a no no as it will dezincify over time and could blow up!
I suppose you could use a bronze brazing rod!
Peter
