Does This Impress You?
Alan Worland03/03/2012 22:55:50
247 forum posts
21 photos
I am always amazed at the amount people who are impressed with the alignment of screw heads in various items - the most obvious of which would be hinges/handles fittedto doors by a 'carpenter.
This indicates to me that either the screws have been over tightened or under tightened to achieve alignment!
Doesn't impress me, in fact it does the opposite!
I feel better for that
What do you all think?
Alan
MAC03/03/2012 23:01:52
68 forum posts
Not impressed, I just think it looks better - and will continue to do it (on door fittings that is).
I'm sure there are better things to worry about .
Springbok03/03/2012 23:17:16
879 forum posts
34 photos
Try and get a "carpenter" who would go to that sort of detail these days they are like hens teeth whilst fitting a door, you will be lucky if he beds the hinges in properly. Though must say when I open a door do not inspect the hinges am I missing out on one of life’s experiences.
Have a fun nice day in the workshop
Bob
_Paul_03/03/2012 23:19:07
543 forum posts
31 photos
I must be the obsessive type as I do make them all line up, always slightly tighter never loose.
How does one know when a screw is overtightened when tightening by hand? unless of course you use a torque wrench on them....but that would make you more obsessive than I cheeky
Paul
John Stevenson03/03/2012 23:38:14
5068 forum posts
Is this a freeking wind up ?
John S.
Sam Stones04/03/2012 02:17:05
922 forum posts
332 photos
Don't get the wind up John S, but here's another story.embarrassed
A couple of years before he retired back in the late 60's, my father changed jobs leaving a fairly large factory to continue being an electrician in the maintenance shop of a smaller establishment. The only other maintenance man was a (mechanical) fitter.
Not long after he started this new job, my father began to notice and to admire the very precise way in which the fitter went about any job he did, especially new installations. One task the fitter undertook was replacing existing factory wiring with fire-resistant pyrotenax cables. Every radius had to be perfect, every straight run had to be perfectly straight, and all the screw heads had to be at the same angle.
While making absolutely no difference to the performance of the factory, the fitter was obviously one of a dying breed, taking pride in the work he did.
Sam
Ed Duffner04/03/2012 03:38:23
863 forum posts
104 photos
When you work in a factory you tend to have more time to complete jobs. Cable radii are, or rather were determined by the IEEE reg's when I used to work to the 15th Edition and although I'd take my time getting cables straight and set a correct radius where required, I doubt I'd aline screw heads for pyro clips. I think that practice might border on an excessive compulsive behavior. smiley Time is money as the say, when you're a tradseman.
Donhe704/03/2012 05:14:21
37 forum posts
Posted by John Stevenson on 03/03/2012 23:38:14:
John S.
No, just Screwing with your mind ..........
donhe7
JasonB04/03/2012 07:50:18
You will be hard pushed to find chippies these days aligning slots in hinges because We now use pozi headed screws, very rare to have slotted screws in hinges.
I will line up screws in door furniture/ironmongery if they are slotted and if brass & there is a risk of overtightening then try another screw until you get one that lines up without risk of snapping.
What anoys me more is the poor quality of a lot of screws supplied with even quite expensive fittings.
J
Tel04/03/2012 08:18:10
157 forum posts
28 photos
To take a leaf out of the olde gunsmiths' book - to do it properly the screws should be regulated so the slots fall to the right position at the right tension.
John Coates04/03/2012 08:21:03
558 forum posts
28 photos
Just goes to show how the passage of time interprets the message differently!
When I read Alan's first post I had no idea what he was talking about
It was only when I got to Sam and finally Jason's posts that I understood we were on about aligning slotted screw heads
Mind you I am a young 'un of only 47 years old !
John Coates04/03/2012 08:22:23
558 forum posts
28 photos
Oh I've also just had to look up the definition of "tyro" having bumped into it frequently in early editions of MEW I am reading at the moment
embarrassed
JasonB04/03/2012 08:50:20
You are still older than me Johnwink 2
Clive Hartland04/03/2012 08:54:02
2929 forum posts
41 photos
Is this not called, 'Finesse' doing a job to, the highest degree of excellence and finish?
Stewart Hart04/03/2012 09:09:57
674 forum posts
357 photos
But how did they do it question
I've pondered this one for some time having seen it on Mill Engines,
My only conclusion is that they first made the slotted screws with over thick head, tightened them upon the engine, marked the heads somehow, then thined the heads down with new slots that would line up.
Any advances on this.
Stew
blowlamp04/03/2012 09:14:44
1885 forum posts
111 photos
Seeing the screwdriver slot thing would bug me because I'd know that he'd have had to over tighten the screws to get them to align.
Like to have seen him do it with tapped holes into metal crying
Martin.
Clive Hartland04/03/2012 09:28:28
2929 forum posts
41 photos
All old hat now as we use Skt/drive screws but years back I would have a job rejected if my slots were not all inline on an instrument side plates.
It did slowly die out but the habit lingers on still to this day.
I did it by screw selection as the slots were not all oriented the same to the thread. The screws were also sealed with wax to stop water entry.
Now with various types of finish on the screws we have a lot of trouble removing them due to corrosion, interaction between the plating and the castings being the problem.
Another problem with Cupro nickel screws was the heads popping off under tension.
John Haine04/03/2012 09:52:55
5563 forum posts
322 photos
"How does one know when a screw is overtightened when tightening by hand? unless of course you use a torque wrench on them?"
Easy - tighten 'til it shears then back off half a turn...
Michael Gilligan04/03/2012 10:06:50
23121 forum posts
1360 photos
Posted by JasonB on 04/03/2012 07:50:18:
J
When my new Workshop door was fitted, by a "Professional", I noticed that most of the nice Brass screws in the Hinges were badly damaged. ... The screws are Phillips cross-point, but he had managed to drive them with a Pozidriv bit in a powerful electric Drill/Screwdriver.
... You can imagine the mess that makes.
It took me twenty minutes to explain that there is a difference !!
Russell Eberhardt04/03/2012 10:09:02
2785 forum posts
87 photos
Lining the screws up was always done on high quality small boats. It was also done on guns, the purpose being safety - you could see at a glance if a screw was working loose.
Russell.
Edited By russell eberhardt on 04/03/2012 10:09:39
