repairing machine table
alan knight25/02/2012 13:33:45
39 forum posts
Hi all, previous owner of my small milling machine had managed to machine a few digs into the table. (which is beyond me how they managed that as Im a religious believe in packing work off the bed). Anyway I would like to repair these bits as they drive me nuts. I was wondering if it was possable to fill any defect with silver solder and then file and polish it level with the rest of the bed. If so what would be the best grade. I dont really want to go down the road of miging the bed up as having to start grinding a super hard weld crust off a bed which trammed to withing a thou doesent sit well with me.
Alan
JasonB25/02/2012 13:39:34
I doubt you will be able to get sufficient heat into the table to silver solder with most heat sources, brazing with oxy-ace may do it but you would want to pre heat the whole thing.
I'd leave it alone.
wheeltapper25/02/2012 13:44:10
424 forum posts
98 photos
Hi
I drilled a hole in my new mill table.
what I did was to mix some cast iron dust with araldite and fill the hole.
rubbed it down when it was hard and it hardly shows now.
use the regular araldite not the quick setting stuff.
Roy
KWIL25/02/2012 14:12:39
3681 forum posts
70 photos
As Jason says you would have to heat the whole item first . Silver solder is not the best thing, a "proper" welder would use a high nickel electrode.I have seen an example of such use, but why bother.?
Edited By KWIL on 25/02/2012 14:13:26
David Littlewood25/02/2012 14:40:11
533 forum posts
Alan,
I suspect you would risk distorting the table if you heat it locally. Personally I would not bother - as long as the dings are small, and you carefully stone off the inevitable raised bits around the edges, there will be no detriment to the function. If you really can't live with it, I'd go with Wheeltapper's suggestion.
David
Edited By David Littlewood on 25/02/2012 14:40:52
_Paul_25/02/2012 14:43:43
543 forum posts
31 photos
Your'e talking about using a lot of heat on a nicely seasoned/machined/scraped and probably well bedded in piece of tooling what do you think a probably quite localised patch of high heat will do to it?
The Araldite and cast iron dust method does work my old Taylor mill is testament to that and you can buy proprietry compunds which do the same thing but better.
Plugging with similar material works well on round holes.
If you are determined to do something serious with it why not have it ground on a surface grinder if there is enough meat to grind out your marks, again though removing metal may have unwanted distortion effects.
My 2 pennorth
Paul
alan knight25/02/2012 16:28:49
39 forum posts
Thanks for your input lads saved me from wrecking a valueable tool. I will have a go over her and see what i can fix with epoxy is there any reccomended brands for a better result?
JasonB25/02/2012 16:56:20
JB Weld is good and "chemical metal"  by the people who do plastic padding is a bit thicker, There is probably something in the Devcon range as well.
J
Edited By JasonB on 25/02/2012 16:56:59
Peter G. Shaw25/02/2012 21:19:28
1531 forum posts
44 photos
Can I ask a simple question?
Is it still possible to get regular, ie long curing time, Araldite? I see plenty of Rapid and other variations on a theme, but the standard 24 hour stuff appears to have disappeared.
Peter G. Shaw
ps. I know Araldite is a trade name, and that there are other epoxy resins available, but I have been using Araldite standard since about 1965 - until it ran out, that is. But I find that when all else fails, even Araldite Rapid seems to be willing to try and do the job, whatever it is. And so, I would like to stay with Araldite.
wheeltapper25/02/2012 21:38:19
424 forum posts
98 photos
I got some regular araldite in Buy and Queue. I won't use the rapid stuff, it doesn't get as hard.
Roy.
Keith Long25/02/2012 21:49:21
883 forum posts
11 photos
Roy
Don't be too dismissive of the rapid version, I've found that the very fact that it doesn't set as hard as the slow version makes it MORE resistant to fracture under shock loads - can be a useful property at times.
Keith
Nicholas Farr26/02/2012 01:11:34
3988 forum posts
1799 photos
Hi Alan, I have to agree with all that has been said about silver soldering or welding your milling table. Even if you could get enough preheat into it to start with, it's unlikely you will be able to control the distortion of the welding process. The filling idea's are a much safer way.
Regards Nick.
Ian S C26/02/2012 08:46:46
7468 forum posts
230 photos
I filled a hole I put in my mill with some stuff I found at the local dump years ago, its a small tin of dark grey powder that mixes with water, can't remember what its called but it said something about filling hols in castings at foundries, so I gave it a go. Looking at it today, apart from the fact that it is shinier than the rest of the table, it looks good after 10yrs or so. Ian S C
Stub Mandrel26/02/2012 20:22:32
4318 forum posts
291 photos
I understand JB weld knocks spots off chemical metal. Can't wait to try it.
JasonB26/02/2012 20:27:54
The only thing to watch with JB weld is that its quite a bit runnier so will slump on anything but a horizontal surface, also takes a lot longer to set.
Oh and make sure you get the right one, red & black tubes are what you want.
J
Edited By JasonB on 26/02/2012 20:28:24
_Paul_26/02/2012 20:32:54
543 forum posts
31 photos
In our local motor factors some 20 years ago the JB Weld display had chained to it two old valves stuck together at the head end the test was to try and part them...no-one did.
AFAIK it was a bit dark in colour.
Chemical Metal is still holding the oil cooler pipe onto the radiator of one of my Kawasaki's surprised me as the leak was fairly bad, not used it on a machine yet.
Last repair I did was with pound shop "araldite" and cast iron dust went a bit dark and took ages to harden right off.
Paul
Brian26/02/2012 21:05:22
40 forum posts
Depends where and how big the damage is, but have you considered drilling or end milling the damage area and machining a steel plug and setting in with Loctite 603 its oil tolerant, then machine the surface and scrape to finish.
It worked for me on a milling vice.
Mike Poole26/02/2012 21:11:57
3676 forum posts
82 photos
Devcon make a range of metal repair materials, eye watering prices though!!
Peter G. Shaw27/02/2012 11:29:21
1531 forum posts
44 photos
Well, went to "Buy and Queue" (like that, I do) only they didn't have any of the regular. Lots of other stuff, but not the genuine Araldite.
Went next door to Halfords (aren't they the same chain these days?) and found some Araldite Standard Professional or some such. Anyway, didn't buy - thought I'd look elsewhere first.
But thanks for the idea Roy.
Peter G. Shaw
Terryd27/02/2012 12:02:53
1946 forum posts
179 photos
Posted by Peter G. Shaw on 27/02/2012 11:29:21:
Well, went to "Buy and Queue" (like that, I do) only they didn't have any of the regular. Lots of other stuff, but not the genuine Araldite.........................
Peter G. Shaw
Hi Peter,
It is available, try here for example. A simple google search found lots of places selling it.
Terry
Edited By Terryd on 27/02/2012 12:04:02
