Member postings for Brian
Here is a list of all the postings Brian has made in our forums. Click on a thread name to jump to the thread.
Thread: Drilling
20/02/2021 15:58:12
Gentlemen, thank you for you help and direction.
20/02/2021 14:46:24
Thanks Bill, Its an age thing, the diameter should read 0.3mm.
20/02/2021 14:14:49
I need to drill a very small 0.03mm diameter hole in steel to form a pilot hole light for a propane gas burner. Can it be drilled and what sort of equipment would be required.
Thread: Dore Westbury Milling Machine
01/10/2019 16:47:55
I'm nearing completion of a DW Mk 2 and looking for input with regard to the oil grade in the gearbox. The build manual indicates a light machine oil to be used, help from others would be useful, what was used?
Please no groundnut, sunflower or olive responses or the thread could just go on and on.
Edited By Brian on 01/10/2019 16:49:01
Thread: Super 7 countershaft
18/07/2017 20:22:25
Maurice, take alook at the work Steve Jordan has covered on You Tube it deals withe the work you are doing. click this link hoping it works https://www.youtube.com/watch?v=u9UuUctxy4k. oops sorry cut and paste.
Thread: Lost wax casting advice needed
01/03/2017 22:40:56
How much shrinkage did you get, outside diameter and height?
Thread: foundry castings
11/08/2016 10:11:00
Did you get the enterprise off the ground? If you did, I need three small patterns cast in three different materials SG iron, Ally and Bronze, the job is yours.
Thread: Cleaning internal MT's
27/06/2016 22:29:27
No Connection, Gloster Tooling have Internal Morse Taper wiper on Ebay.
Thread: Stainless seamless tube
05/07/2015 15:59:16
No connection at all but try Metal Supermarket you may be lucky.
15/05/2015 23:01:23
Very interested, really depends on location in the UK, types and grade of metals, most of all cost. Good luck with your enterprise keep us posted.
If its SG iron and you have a job.
Thread: Waterproofing a Roof?
19/01/2015 15:59:42
I had a very good result with Acrypol+ on a flat roof same problem you are having. Would recommend scrape off all the loose detritus, if you feel inclined flood cote the surface with a week grout, then coat. The product can be applied in any weather its fibre filled and will cover cracks if there are any it lasts a lifetime, old overalls to be worn.
www.acrypolproducts.co.uk/ no link with the company just a satisfied customer.
Thread: Free Plastic
15/11/2014 13:37:31
Graham, not sure if you received my message but would like to be included in this fantastic offer, please put me on the list.
Kind regards
Thread: dore westbury problem
27/07/2014 11:13:37
Kevin
Message me I may be able to help. I have recently cast and machined a new Dore Westbury base ready for a bottom end rebuild.
Thread: #209 - new look
19/10/2013 22:46:30
If it aint broke dont fix it, sorry
Thread: Arc Euro Trade ML7 cross slide leadscrew modification
08/10/2013 20:07:16
I would recommend doing it. I did my Ml7 and think its the best mod one could do, I would also change the nut at the same time cheep as chips but makes a world of difference.
Thread: Parting Tool Feedback
07/08/2013 11:58:37
Has anybody used the Eccentric Engineering paring tool. I'm thinking of going for it but would appreciate any feedback, its not cheep. I have been using their tangential tool for some time and have no problem with the quality of their products, but would like to know if this parting tool performs compared with other tools on the market.
Thread: Morse Taper Cleaner
20/07/2013 09:31:01
I use a 12 bore chamber brush for M2 taper, they are not steel brushes but do the job, not sure if they would do for M3.
Thread: 3D printing Harold Hall's Grinding Rest
30/05/2013 12:07:07
Had to press the compatibility button to reveal all, you waved your wand, thanks Jason.
30/05/2013 09:48:37
This thread would be great if I could read it. The same old problem text and attachments being hidden by the addverts. Stand by for more comments like this.
Thread: HAROLD halls TOOL REST
05/05/2013 10:05:40
Thining washers? now thats another subject to be explored.
