How not to snap drill bits
RobC | 30/01/2012 21:28:45 |
54 forum posts 3 photos | Hello fellow clock makers and assorted engineers!
I am in the process of building my first clock and am having a lot of difficulty drilling small holes in plates with my pillar drill. Tonight I have managed to break four different types of drill, all less than 1.5mm diameter.
I do have an Eclipse pin chuck, but it doesn't seem to hold the shanks of the drills quite vertically, which is no use at all. I also have some micro drills with larger diameter shanks, which did go into the main drill chuck better, but I broke them too.
It seems that whatever I do in the drill press, I either have too much or too little movement in the work to drill relationship.
I am currently drilling through three 3mm plates of aluminium, which I don't think should be causing me this much trouble, but I guess there is either a technique or device that I do not know about. Once I have drilled these holes I am going to have to taper ream them and I really don't want to bust the reamer too...
Any advice would be gratefully received!
Rob
JohnF | 30/01/2012 22:08:38 |
![]() 1243 forum posts 202 photos | Rob, seems to me that your pillar drill is maybe to large and thus not sesitive enough for small drills? What type and size is it?
The Eclipse pin chucks I have found are not very accurate I would look for something better quality e.g. Albrecht or simmilar, I did buy a small Jacobs style chuck from Arc Euro and for the price very acceptable.
A smaller drill press might be best but an alternative would be a sensitive drilling attachment to use in you existing machine but be aware that you need much higher speeds for small drills.
Regards John |
Bazyle | 30/01/2012 22:45:22 |
![]() 6956 forum posts 229 photos | Is the table firm and the work clamped to it? Is the quill when extended able to move sideways? Are you clearing swarf every mm?
Do you need to drill all 3 together? After drilling one spot through to the next and drill separately. 3mm is not a deep hole but 9 mm is in proportion to diameter so more risk of friction & heating.
Do you need to apply pressure or is the weight of the head enough to penetrate? The huge play in the feed mechanism of most pillar drills can cause snatching and sudden stress. |
KWIL | 30/01/2012 23:02:21 |
3681 forum posts 70 photos | No mention of a lubricant here either, paraffin is good on aluminium. |
Terryd | 31/01/2012 05:15:58 |
![]() 1946 forum posts 179 photos | Hi Rob, Drill speed? You should be drilling at the highest speed that your machine is capable of with such small drills and as Kwil says, paraffin as a lubricant on aluminium is almost essential. I would also take Bazyle's advice on drilling one plate and spotting through. A sensitive drilling attachment is also a good idea if you foresee having to do lots of holes. You should also peck drill, a little at a time and withdraw to clear swarf regularly especially with aluminium, not so much with brass. Be as gentle as you can and let the drill cut but do not force it. Good luck, Terry |
NJH | 31/01/2012 10:08:05 |
![]() 2314 forum posts 139 photos | Hi Rob I agree with all the above advice but clock plates in aluminium? - I've not come across that before. What is the clock? Regards Norman |
Ian S C | 31/01/2012 13:12:58 |
![]() 7468 forum posts 230 photos | Maybe a dremel tool in a stand? Ian S C |
RobC | 31/01/2012 17:01:46 |
54 forum posts 3 photos | Thanks to all the commenters. I will try to summarise and answer what I can.
My answers to your questions
JohnF: Is the drill too large and un-sensitive - Yes Fobco Star 1/2" chuck with a bit of a wobble to it.
Bazyle: The table is firm but the work was not clamped to it, although it was weighted down fairly well.
Quill extension was minimal, so no lateral movement.
No, I was not clearing the swarf every mm.
No, I was not using the highest speed on the drill (second highest)
I probably don't need to drill all three together, although the job at hand is to drill, taper ream (1/16") and pin the three plates together, so any tips here are appreciated.
I do need to apply pressure, since the return spring is fairly robust on the drill.
KWIL: No, I was not using sufficient lubricant (Trefulex)
Terryd: Peck drilling sounds sensible, I was probably being far too ham-fisted!
NJH: Aah, you spotted it! I am making a 'trial' clock in aluminium to make these types of mistakes, then a proper one from brass. This way I am scrapping chunks of aluminum and not being as unhappy with myself as I would be if I messed up with all the nice shiny brass. This way I get to practice the techniques and make the tooling/jigs I need before I get into the real thing.
Ian S C: Yes, I have thought about that. I do have a Dremel although I don't have the stand for it. It may be simplest to source one of them.
My summary of the guidance so far:
Get a decent pin chuck
High speed on the drill
Peck drill into the work slowly, clearing the swarf frequently
Lots of lubricant - paraffin would be best
One plate at a time
Clamp the work to the drill table
Use a smaller, more sensitive drill for this sort of work (recommendations please)
Look at using Dremel mounted in vertical drilling stand as temporary solution
Phew, that's a fair bit for a few hours of your time. Thanks guys
Rob |
NJH | 31/01/2012 18:20:18 |
![]() 2314 forum posts 139 photos | Hi Rob I'm a bit concerned about the " bit of a wobble" on the chuck of your Fobco star - try a piece of (say) 1/4 in silver steel in the chuck - is this wobbling? If so are you able to measure how much wobble and discover why? As far as sensitive drilling goes (and if the silver steel is not wobbling) you might like to invest in one of these along with a suitable chuck That way you lock the quill of your Fobco and use fingertip pressure on the micro drill adapter so you will be able to " feel it in" Regards Norman |
Richard Parsons | 31/01/2012 18:22:24 |
![]() 645 forum posts 33 photos | Rob. Why not do as the old’uns (Graham, Harrison, Mudd, Breguet and the rest would have done. Do it by hand. Use a little Archmeanian drill and take your time. If you are drilling by machine lock both plates together and clamp them down well. Use a high speed and take it slow. Pin chucks are not accurate they are for hand use. Get an eclipse 160 Pin Chuck this is what I use. Do not get too worried about deadly accuracy on the hole size. You will have to broach it out to get the clock to run. Old clock makers have a saying it “If rattles it will run”. Rdgs Dick |
Stephen Benson | 31/01/2012 18:38:28 |
![]() 203 forum posts 69 photos |
You could actually use ally and fit brass bushes then broach the holes to size or even use ball bearings as a growing band of modern clockmakers are Edited By Stephen Benson on 31/01/2012 18:39:22 |
blowlamp | 31/01/2012 19:16:53 |
![]() 1885 forum posts 111 photos | With a good chuck on your Fobco you should be OK, I think.
I use a Union pillar drill that's about the same size as yours and I don't get any problems with drills around 1mm diameter.
As has been pointed out already, a 9mm deep hole into aluminum with a 1.5mm drill is begging for trouble if it's not cleared and lubed frequently.
Don't make the mistake of believing you'll have covered yourself by practising with aluminium for these movement plates, 'cos brass is bad for snatching when the drill breaks through, so try on some scrap brass to before commiting to the real thing.
When it does snatch, the drill bit lifts the plate off the table at an angle and continues to cut a (now) slanted hole.
![]() Have a look on Google for ideas to avoid the above snatching of drill bits.
Martin. |
Stub Mandrel | 31/01/2012 19:42:13 |
![]() 4318 forum posts 291 photos 1 articles | I have a cheap-as-chips Machine Mart pillar drill (I think it was £35!) and it quite happily drills PCBs using number 70 drills which are much less than 1mm in the standard chuck. Neil |
Sam Stones | 31/01/2012 21:56:53 |
![]() 922 forum posts 332 photos |
Hi Rob, Although I’ve only made one clock (in brass), here is my six penn’orth. With regards to the quill and the spring arrangement in the drill head, a situation can arise (especially with small drills) where, as the weight of the quill becomes transferred onto the drill tip, feedback and sensitivity is reduced. In other words, the quill starts to `float’. At the point when the drill begins to break through, the quill can drop a short distance, depending upon how much clearance there is in the rack and pinion, and/or how the spring mechanism is arranged. The risk of breaking a drill is reduced by having a (scrap) backing plate of the same material being drilled, or when you are spotting through to your next plate. When drilling brass, carefully stone the two cutting edges of the drill to produce a negative (as opposed to a positive) edge. Not all that easy with tiny drills. Although brass can be machined dry, aluminium needs lots of cutting fluid to minimise swarf build-up on the cutting edges etc. Regards, Sam Edited By Sam Stones on 31/01/2012 22:06:38 |
RobC | 01/02/2012 08:22:58 |
More great responses guys, I will answer a few of the questions too.
For clarity, I am drilling and taper reaming (1/16” ) locating holes to hold the three plates together with pins during the build process, so the fit is important in this bit.
NJH: Micro drill stuff looks good, I will probably go down that route if I can get to the bottom of the wobble on my drill. I have measured it in the past and it is not very pronounced at the taper above the chuck, but from the chuck it can be fairly large (I will measure again tonight). This leads me to think that the chuck may be knackered, although the bearings on the drill itself may also be past their best. I am not entirely sure where to go with this one, although I may just try replacing the chuck and seeing if that changes anything.
Richard: I did consider an Archimedes drill, but for the particular task I am performing, I thought it was not particularly suitable. It may be the simplest answer though, but I can’t imagine I will get a very perpendicular hole if I do. For regular clock elements, it would probably be ok, but probably not for the task at hand which is accurate location of the plates for the manufacturing process.
Stephen: At this point I am not making holes for pivots, although knowing that I could bush them in brass makes for interesting possibilities.
Blowlamp: Thank you for the vote of confidence in using a big lump of a drill to achieve this, I thought I should be able to, if I go carefully enough. I also appreciate that switching to brass will bring a whole new set of challenges, but at least this way I have tried a few before I embark on the more costly material. This is my very first project, so I am learning everything from scratch.
Stub: It sounds like the Machine Mart/Clark drills can be very good if you get hold of a decent one. I was warned off them by a fellow engineer, but maybe he was a bit hasty.
Sam: Thanks for the tips, I was definitely not using enough lubricant when cutting and was going too deep.
Thanks again guys, this is all a great help to a novice!
Rob
Edited By RobC on 01/02/2012 08:23:29 |
Richard Parsons | 01/02/2012 10:03:41 |
![]() 645 forum posts 33 photos | Taper reaming, are you using ‘Clock Makers Broaches’? These are normally hand tools. I have two sets. The 6-sided type for getting the hole close to size. I then use round smooth burnishing reamers to finish the hole.
Yes you can use ball bearings especially on those parts of the ‘Going Train’ where the ‘power levels’ are high. As the gearing ratio’s increase then ball/needle roller races are not advisable. You can get very low friction inserts, but in have never used them on clocks. I was using them on my tide computer where they worked well. That was until I received a ‘tribal visit’. The ‘Skilled Man’ dumped a large lump of a tractor engine on my instrument bench. As a result of my protest –he had crushed my multi-meter and the mechanical tide computer and other odds and ends. He then threw all the broken stuff into the barley field opposite –enough! I normally drill my plates with my Startrite Mercuary pillar drill for the pivots or in my milling machine (using co-ordinate drilling) for the support pillars. I always use a slab of block board to drill on. This stuff is reasonably accurate. Using the Archimedian drill you will find that with very small drills they will automatically become very close to the vertical. I have read that Cherry Hill uses them to spot the centres of holes to be drilled. If you are drilling deep holes I have a rule of pecking which seems to work it is that the peck should be no deeper than 1 ½ time the drill diameter. I have drilled 1/16” holes 3.2” deep. It was slow work but successful. Rdgs
Dick |
Cornish Jack | 01/02/2012 11:35:42 |
1228 forum posts 172 photos | Hi Rob I also have a Fobco Star - superb bit of 'old style' quality engineering (and, surprisingly, still offering spares!). One of its problems is its sheer rigidity - with the table and column locked, if the drill isn't EXACTLY on the mark, the drill will bend. Additionally, the chuck jaws are of a size to make central location difficult - I have lost count of the times I have got a small drill trapped between two chuck jaws , close to, but not on centre. On the clockmaking side, I was lucky enough a few years ago, to be invited to John Wilding's home and workshop (before his move). I was contemplating clockmaking and asked him about the need for, and method of drilling, taper pin holes. His reply was that he no longer used taper pins for plate location, preferring (IIRC) small BA bolts or screws. If that is good enough for 'The Master' who am I to argue? Rgds Bill |
RobC | 01/02/2012 14:47:09 |
54 forum posts 3 photos | Update - I have measured the 'wobble' on the drill chuck.
With a piece of round tool steel held in the chuck, I have movement of 0.30mm (0.012") measured with a DTI at about 1" below the chuck.
Removing the chuck and cleaning the scuffs off the taper itself, I have about 0.06mm (0.002").
All of this assumes that I am reading my DTI correctly, that is to say that the overall swing covers the values I mentioned.
Is this amount of movement acceptable or do I need to try to sort it out?
Rob
Andrew Johnston | 01/02/2012 14:58:46 |
![]() 7061 forum posts 719 photos | Hi Rob,
I would have expected the taper itself to be rather better than 2 thou, should be half a thou or better. I suspect that the 12 thou wobble is the main cause of your problems; I'd say it was unacceptable. If I get a chance later this evening I'll measure my drill press and vertical mill and see what values I get.
As an aside I find that WD40 is pretty good when drilling aluminium alloys. You're not really looking for lubrication, more to stop the swarf sticking to the tool.
Andrew |
Stub Mandrel | 01/02/2012 21:53:25 |
![]() 4318 forum posts 291 photos 1 articles | > If that is good enough for 'The Master' who am I to argue? Funny how model engineers chase spurious precision. I have seen so much about setting tool heights. George H Thomas described a precision height gauge, to be constructed with extreme accuracy. Then near the end of the peice he says that if it is to be used for tool height setting, just set the gauge using a pip in the end of the work or a centre in the tailstock! ![]() Neil |
