Eric Cox | 27/03/2011 10:56:28 |
![]() 557 forum posts 38 photos | I recently acquired a far eastern lathe that came with 8mm tooling. When I put the lathe tool in the tool post it was above centre height. Surely it should be below or on centre height so that I don't have to reduce the thickness of the lathe tool. |
Chris Trice | 27/03/2011 11:21:51 |
![]() 1376 forum posts 10 photos | Correct. How high above centreline is it? 1/4" or 6mm tools are the next ones down.
John Stevenson | 27/03/2011 15:56:13 |
![]() 5068 forum posts 3 photos | I have the same trouble on my TOS lathe, it will hold 1 1/2" tools but they are also over centre and I'm limited to only use 1 1/4" shank tools. John S. |
Terryd | 27/03/2011 16:14:14 |
![]() 1946 forum posts 179 photos | Hi Eric, Just another possibility, has the correct toolpost been fitted? Could you check the size with someone else who has the same lathe? It's difficult to comment without knowing the make, model and supplier. Regards Terry Edited By Terryd on 27/03/2011 16:16:15 |
Eric Cox | 28/03/2011 08:57:02 |
![]() 557 forum posts 38 photos | The lathe is a conquest super from Chester UK and the tools were supplied with the lathe |
Les Jones 1 | 28/03/2011 09:42:49 |
2292 forum posts 159 photos | Hi Eric, I have just had a look at Chester's website to see if it specifies the size of the tools included with the lathe. It does not state the size of the tools but shows a quick change tool post. Normally the height of the tool holder can be adjusted on a quick change tool post so I would have thought there would be enough adjustment. If this is not the case try phoning or emailing Chester. I found that when I had a question about my lathe they tried to be helpful but not all of their people seem to be technical. Les. |
Jon | 29/03/2011 15:04:26 |
1001 forum posts 49 photos | Its not the QR tool post that one, ideally you will want the 6 or 1/4" tools which it will run out of power with much the same. No mention of size here either http://www.machinemart.co.uk/shop/product/details/cht568-38pce-carbide-tipped-lathe-tool but look 8mm. The only one that mentions size is here. http://www.axminster.co.uk/axminster-6mm-tungsten-carbide-lathe-boring-tool-set-of-6-prod784598/ Useless any way. These are 8mm and used on a bigger lathe with no top slide, click on piccy with lathe! http://www.axminster.co.uk/axminster-high-speed-steel-tool-bit-set-prod784600/ |
Eric Cox | 30/03/2011 09:26:36 |
![]() 557 forum posts 38 photos | It looks like a case of far east cheap tooling. Using the adage "you get what you pay for" this set was free with the lathe. The boring bar was on centre height and the parting off tool instead of the shank being 8x8 was made from 10x8 subsequently 2mm too high. |
Ian S C | 30/03/2011 11:00:43 |
![]() 7468 forum posts 230 photos | Is the tooling HSS, or carbide, if the former easily cured by grinding, if the latter, you should be able to take a bit of the bottom of the shank/ tool holder.
won\t the supplier change them? If not thats a bit poor, a direct swap would be to his advantage, because the smaller tools are proberbly cheaper. Ian S C |
Martin W | 30/03/2011 19:08:58 |
940 forum posts 30 photos | Eric
Have you tried posting on the forum at the Chester UK website and raised the question there? If not it is worth a go as they normally try to sort things out pretty fast. Usual disclaimer re interests.
Cheers
Martin |
Eric Cox | 31/03/2011 09:29:25 |
![]() 557 forum posts 38 photos | I'll try the forum and see what happens. |
larry Phelan | 27/08/2017 12:03:07 |
![]() 544 forum posts 17 photos | Dealing with Chester ----------? I wish you luck !! |
NJH | 27/08/2017 12:54:03 |
![]() 2314 forum posts 139 photos | Larry - this thread is 6 years old ! If the original poster hasn't sorted it by now I doubt that he will. What is you reason for bad mouthing Chester ? I've not heard bad reports of them and they do support the forum. Norman |
JasonB | 27/08/2017 13:10:15 |
![]() 25215 forum posts 3105 photos 1 articles | Larry, you have been asked twice to stop dragging up old threads and making pointless posts, we will be sending JS around to give you a slap.
J |
John Stevenson | 27/08/2017 13:25:09 |
![]() 5068 forum posts 3 photos | No slap needed, just a full ban - you have been warned |
Neil Wyatt | 27/08/2017 14:47:27 |
![]() 19226 forum posts 749 photos 86 articles | I have sent a message to Larry, if this continues I will suspend his account. Neil |
