Douglas Johnston | 29/06/2009 19:25:06 |
![]() 814 forum posts 36 photos | I have been hunting ebay and google to find a supplier of the two part plastic containers that a lot of new milling cutters etc come in, but I can't find any. Does anybody know of a supplier of empty containers of this type and do these containers have any special name? |
JasonB | 29/06/2009 20:35:29 |
![]() 25215 forum posts 3105 photos 1 articles | Have a look for "telescopic plastic boxes" I assume thats the type you mean rather than the hinged top ones the likes of Dormer use.
like this supplier
Jason
Edited By JasonB on 29/06/2009 20:36:14 |
Douglas Johnston | 30/06/2009 11:06:29 |
![]() 814 forum posts 36 photos | Thanks for the reply, these boxes are indeed what I have been looking for but there do not seem to be any suppliers of small quantities of these boxes. All the references seem to be about manufacturers making the boxes or trade suppliers with huge minimum orders. I will keep hunting! |
David Clark 1 | 30/06/2009 12:32:29 |
![]() 3357 forum posts 112 photos 10 articles | Hi There
Allendale electronics have started doing trays to store cutters on.
Basically plastic with semicircular grooves in.
They are properly moulded, not blow moulded.
They are just over £1 a piece +P&P.
They are excellent value for money.
regards David
Ian S C | 30/06/2009 12:42:25 |
![]() 7468 forum posts 230 photos | I don't know where you are but is there not an engineering/machine shop someware near by.Have a wee word with someone there,you may at least get a look in the rubbish,because they must use slot-drills and end mills,and the boxes have got to go someware,and you never know what else you'll find! Happy hunting Ian s c. |
Colin Reed | 30/06/2009 14:45:44 |
14 forum posts | Are these the Allendale trays David?
Colin |
Douglas Johnston | 01/07/2009 22:03:06 |
![]() 814 forum posts 36 photos | I have just ordered the allendale trays which look ideal for storing cutters, so thanks for pointing me in their direction David, but I still can't find a supplier of telescopic boxes for other applications.
Douglas
David Clark 1 | 02/07/2009 08:00:40 |
![]() 3357 forum posts 112 photos 10 articles | HI There
Yes, that is them.
£4.99 for 5 can't be bad.
They are good quality mouldings, not cheap blow mouldings as you would expect.
regards David
Douglas Johnston | 03/07/2009 09:07:28 |
![]() 814 forum posts 36 photos | I have just received a set of 5 trays from Allendale (only took 1 day in the post- very quick service). A couple of them were a bit twisted which is not unusual with this type of plastic moulding but they sit flat with the weight of cutters in them. They are not the greatest bargain in the world but will serve the purpose well.
Douglas
Frank Dolman | 01/09/2009 17:31:25 |
106 forum posts | I bought a few telescopic plastic boxes from Tilgear a few months back . They were a special offer, so they may have all gone . Worth trying
Regards Edited By David Clark 1 on 24/09/2010 08:06:13 |
Axel | 23/09/2010 17:32:48 |
126 forum posts 1 photos |
thats a CD organizer sold at IKEA here in Sweden, can´t find it on the UK site though! Ask for it locally if you like it, its dirt cheap way to sort small stuff like drill bits and taps! |
WALLACE | 23/09/2010 20:57:11 |
304 forum posts 17 photos | I used the tip given in MEW to use the DVD 'cakeboxes' to store lose screws, nuts etc etc. The black plastic spindle bit I stick in the 3 jaw (the long bit that is) and shove a milling cutter up it about 1/4" so the bottom comes away clean (it's very soft plastic so I just grip the milling cutter in a bog standard chuck in the tail stock - cue lots of 'that isn't safe and you should be shot for even suggesting it' replies. .
![]() That way, you end up with a clear plastic 'cakebox ' with a small hole in the top - ideal for quickly dropping items in when you're clearing up (obviously need to be stored upside down) AND a plastic tube just the right length for storing tapes and milling cutters in - allbeit without a top !
w. Edited By WALLACE on 23/09/2010 20:57:53 |
Keith Long | 23/09/2010 23:15:24 |
883 forum posts 11 photos | Hi Following up Axel's lead the Ikea cd rack is available in the UK. It goes under the title of INREDA CD RACK - priced at £5 HERE. Not sure if it'll be in your local stores but should be available for on-line ordering. Keith
Bogstandard | 24/09/2010 00:08:36 |
263 forum posts | I can't actually see exactly what you are after because the ad bar on the right is running right thru the middle of all the posts. But if you require tap and die boxes, whenever I place an order with the Tap&Die Co. they always ask if I want my bits packing with tap and die plastic boxes (brand new and clean). I usually get a few hundred of all mixed sizes FOC. Fishing friends are always asking when I am going to place another order. Bogs |
Stub Mandrel | 24/09/2010 19:32:00 |
![]() 4318 forum posts 291 photos 1 articles | I store my collets and milling cutters in simple stand made of two layers of mdf, the top one with lots of holes drilled in it. In a fit of shed-pride I even painted a couple blue. Neil |
oilcan | 25/09/2010 01:46:09 |
34 forum posts | not quite off topic , but my teenage son being an avid muncher of tic-tacs, i've persuaded him not to throw away the empty containers and now nearly all my small rivets and BA screws live in them. take up virtual no room and easily sorted/identified for use. Also, bless that teenage appetite for a take-away at weekends, those empty microwaveabe take-away cartons make superb storage containers for almost everything else. In an unheated garage workshop they help keep the rust menace down during damp winters. And they're free. I'm dreading the time he adopts a healthy lifestyle. may have to start buying stuff! |
Stub Mandrel | 25/09/2010 20:59:37 |
![]() 4318 forum posts 291 photos 1 articles | microwaveabe take-away cartons make superb storage containers Excellent for keeping together bits of small projects and etching small circuit boards. Neil |
Ian S C | 26/09/2010 09:42:22 |
![]() 7468 forum posts 230 photos | Found some little tin boxes, they contained Eclipse mints, size 40mm X 20mm X 75mm, with a hinged lid at the end, My other containers are, tobacco tins, and Kodak 35mm slide boxes. Our local cabinet maker puts the off cuts in a bin outside the factory (for fire wood), and I'v been using that stuff to make my own boxes, also boxes for my hot air engines and other bits and pieces. Ian S C |
Axel | 26/09/2010 11:24:08 |
126 forum posts 1 photos | Befriend a pipesmoker, although they are a dying breed, they can be found. I smoke myself and all the tins are great for storage! |
Bill Pudney | 27/09/2010 01:14:02 |
622 forum posts 24 photos | Posted by Axel on 26/09/2010 11:24:08: Befriend a pipesmoker, although they are a dying breed, they can be found. I smoke myself and all the tins are great for storage! Not in Australia!! I smoke roll ups and haven't seen a tobacco tin for about 20 years. Really sad as they are an ideal storage method. I also fly model aircraft (Free Flight....F1B) and have a need for storing small sizes of (typically) nuts and bolts, M1 up to M2 screws for instance. I asked the local chemists if they could save me some 35mm film canisters which they were happy to do. Even these day when film has been superceded by digital they still collected about 50 for me in a week!! My wife has a bottle of "Yakult" yoghurt every day, I'm trying to think of a use for them, we have about 60, any ideas?? cheers Bill Pudney |
