Andrew Tinsley | 01/10/2023 12:19:15 | ||||||||||||
1817 forum posts 2 photos | I have a billet of EN58 and apart from knowing that it is a magnetic stainless steel, I am totally ignorant. Googling throws up lots of hits on its properties, but not what it is used for! It probably needs to be weighed in! Andrew. | ||||||||||||
Tony Pratt 1 | 01/10/2023 12:23:36 | ||||||||||||
2319 forum posts 13 photos | Domestic, dairy and decorative purposes. Can be formed and welded, most widely used grade relatively low cost, this was from a Google search not my personal experience. Tony Edited By Tony Pratt 1 on 01/10/2023 12:23:56 Edited By Tony Pratt 1 on 01/10/2023 12:27:36 | ||||||||||||
Clive Brown 1 | 01/10/2023 12:28:33 | ||||||||||||
1050 forum posts 56 photos | En58 is an !8/8 stainless steel. Being austenitic, it's not normally regarded as magnetic. Can be tough to machine, it work-hardens. | ||||||||||||
Circlip | 01/10/2023 12:41:20 | ||||||||||||
1723 forum posts | EN58??? Whats the suffix? modern classifications are 304 316 and 321 303/304 General use, 316 Hygenic use, 321 heat applications All 3 also come with an 'L' suffix which denotes low carbon. Regards Ian. | ||||||||||||
Martin Johnson 1 | 01/10/2023 13:08:40 | ||||||||||||
320 forum posts 1 photos | Try machining it before you weigh it in. EN58 can be quite variable ranging from unmachinium to whats all the fuss about. Drilling will probably show up any problems. Sharp drill, slow revs (less than 1/2 mild steel) and keep feeding. Martin | ||||||||||||
Bo'sun | 01/10/2023 13:41:29 | ||||||||||||
754 forum posts 2 photos | When I worked in the foundry industry some while ago, we used magnetic stainless steel for items like conveyor drums in the sand reclaim area, to catch cast iron fragments before the sand went to the mullers (drum mixers). | ||||||||||||
duncan webster | 01/10/2023 13:43:28 | ||||||||||||
5307 forum posts 83 photos | Posted by Andrew Tinsley on 01/10/2023 12:19:15:
I have a billet of EN58 and apart from knowing that it is a magnetic stainless steel, I am totally ignorant. Googling throws up lots of hits on its properties, but not what it is used for! It probably needs to be weighed in! Andrew. If it's EN58 it is austenitic (as others have said) so it shouldn't be magnetic. I have a lump of 304 from which I've sawn bits to make superheater return bends, but it's not easy Edited By duncan webster on 01/10/2023 13:43:50 | ||||||||||||
Andrew Tinsley | 01/10/2023 15:01:06 | ||||||||||||
1817 forum posts 2 photos | One end of the billet is stamped EN58 Magnetic. The stamping is circular in pattern and looks to be professionally done. So no suffix such as EN58B. I will give it a go and see if it machines acceptably, if not, then the scrap bin! Thanks everyone, Andrew. | ||||||||||||
Michael Gilligan | 01/10/2023 15:14:08 | ||||||||||||
![]() 23121 forum posts 1360 photos | Is this any help ? http://www.engineerstudent.co.uk/steel_selection_2.html . Possibly the link that Tony Pratt found [?] MichaelG. Edited By Michael Gilligan on 01/10/2023 15:15:42 | ||||||||||||
Mick B1 | 01/10/2023 17:51:11 | ||||||||||||
2444 forum posts 139 photos | I have seen it specified as material on a drawing for a revolver cylinder in .38 Special/.357 Magnum calibre. I think it was EN58M or AM, and there my have been alternative specs also listed. This was probably 40+ years ago. I can remember feeling rather surprised at the time. Edited By Mick B1 on 01/10/2023 17:53:06 | ||||||||||||
duncan webster | 01/10/2023 18:39:24 | ||||||||||||
5307 forum posts 83 photos | According to my very old little book provided by United Steel Companies, EN58M is Austenitic Cr-Ni, so should be non magnetic. The M doesn't mean magnetic | ||||||||||||
bernard towers | 01/10/2023 19:04:42 | ||||||||||||
1221 forum posts 161 photos | Is the "M" for machinable grade? | ||||||||||||
Paul Rhodes | 01/10/2023 20:06:23 | ||||||||||||
81 forum posts | Are we not getting ourselves confused? Andrew did not post “M” but records a stamping “magnetic” What I am unclear on is whether the metal has been tested as magnetic. | ||||||||||||
Andrew Tinsley | 01/10/2023 20:15:24 | ||||||||||||
1817 forum posts 2 photos | I am suffering from the after effects of a Covid injection from yesterday. In a bit of a state right now and don' t fancy a trip to the workshop. Very dizzy and would probably fall. Should be much improved tomorrow and I will check if it is magnetic or not. Didn't occur to me to check it before as the professional looking stamping said magnetic and I believed it. I should not be so trusting! Andrew. | ||||||||||||
Chris Pearson 1 | 01/10/2023 20:22:16 | ||||||||||||
189 forum posts 3 photos | You are not the only one! I had a dreadful night last night. It started with being cold, and ended with incredible thirst and drenching the sheets. Better now! | ||||||||||||
Gary Yeadon | 01/10/2023 20:37:05 | ||||||||||||
![]() 7 forum posts | I have used 2 grades years ago EN58 A & B. You can check if they are Austenitic by trying to add a Magnet. to the work piece
En58A and En58B are wrought steels used for mechanical and allied engineering purposes 1. They have similar chemical compositions, but the difference lies in their mechanical propertiesEn58B has a higher tensile strength than En58A, but lower ductility 23. Here are some of the mechanical properties of both steels:
Both steels are commonly used in the manufacture of shafts, gears, and axles 1. Due to their high tensile strength and good ductility, they are also used in the production of fasteners, springs, and hand tools 1. You can find more information about their chemical composition, mechanical properties, and cross-references in the datasheet available at 23.
Pero | 02/10/2023 03:46:59 | ||||||||||||
193 forum posts | My only experience is with the 3xx grades so I can't provide any direct comment. However you will find in some descriptions that 304 is graded as weakly magnetic and becomes more so as it is worked. I have found this to be correct in practice and you can test it with a strong, e.g. neodymium, magnet. It is possible that it may not be observed with a weak magnet. Pero | ||||||||||||
Andrew Tinsley | 02/10/2023 10:01:24 | ||||||||||||
1817 forum posts 2 photos | I checked the EN58 billet this morning and found it was definitely magnetic. So that seems to throw a big spanner in the works!. I still think that the stamped label is of a professional nature. It is done on a circular pattern and spacing of letters and numbers is very precise. Can't see an amateur going to that length.. I will have a go at machining it later today. Andrew.
