Follow on from recent discussions about different types of steel
File Handle | 01/01/2023 15:33:20 |
250 forum posts | During recent discussions on different steels, repurposing steel bolts was mentioned. |
John Haine | 01/01/2023 15:43:24 |
5563 forum posts 322 photos | I don't know about steel bolts but brass ones I have found are not generally free machining. I think the threads are rolled so a different grade is used - I think CZ121 is best for machining, the stuff used in bolts etc is more sticky. |
old mart | 01/01/2023 16:18:40 |
4655 forum posts 304 photos | I cannot comment on the strength of brass bolts, but I was impressed with woodscrews when I modified some for a particular job, much stronger than expected, close to mild steel. The spec for bolts is for the finished bolts, so the materials may differ from make to make slightly. Edited By old mart on 01/01/2023 16:21:04 |
SillyOldDuffer | 01/01/2023 16:41:57 |
10668 forum posts 2415 photos | Posted by Keith Wyles on 01/01/2023 15:33:20:
Bolts are made to a specification, and any metal that does the job can be used to make them. The steels found in different bolts is likely to be similar, but there are no guarantees. Might machine OK or be difficult. An obvious example is 8.8 stainless steel bolts aren't made from the same alloy as ordinary 8.8 steel bolts. Brass is different again. Main advantage is low corrosion with good heat and electrical conductivity. Brass isn't first choice for strength. There are a multitude of different brasses. Common 60:40 has a yield strength of 95MPa, compared with steels which range between 200 and 1200MPa. I'd expect a Brass bolt to be only half as strong as steel at best, and considerably weaker than a 8.8 or better bolt. Dave
Dave Halford | 01/01/2023 16:50:27 |
2536 forum posts 24 photos | The trick for putting brass screws into oak without them breaking was make the hole with a steel one first |
David George 1 | 01/01/2023 17:06:50 |
![]() 2110 forum posts 565 photos | When making jigs and fixtures for RR we had to use unbrako made socket screws where required and proof was supplied. We found other makes had slightly different head sizes and somtimes the socket was a diferent size for the Allen key. We didn't have any tests for materials. David |
Robert Atkinson 2 | 01/01/2023 17:31:27 |
![]() 1891 forum posts 37 photos | "8.8 stainless steel bolts" is an oxymoron. Robert. |
Thor 🇳🇴 | 01/01/2023 17:44:00 |
![]() 1766 forum posts 46 photos | Hi Keith, Ordinary 8.8 bolts are often made from (unalloyed) steel with 0.35 to 0.45% C, the 10.9 and 12.9 bolts are usually made from steels alloyed with Chromium or Chromium and Molybdenum. Thor |
Michael Gilligan | 01/01/2023 17:58:13 |
![]() 23121 forum posts 1360 photos | Posted by Robert Atkinson 2 on 01/01/2023 17:31:27:
"8.8 stainless steel bolts" is an oxymoron. Robert. . Oh dear … that’s unfortunate: . https://www.navstarsteel.com/grade-8-8-bolts.html#sizes . MichaelG. Edited By Michael Gilligan on 01/01/2023 17:58:52 |
JA | 01/01/2023 18:03:26 |
![]() 1605 forum posts 83 photos | Years ago I tried turning down some shanked M10 bolts from the local DIY supermarket. The material was horrible. It was not a substitute for mild steel bar (free cutting or not). One could say "What was I to expect". JA |
bernard towers | 01/01/2023 18:46:51 |
1221 forum posts 161 photos | A friend of mine who is a lifetime boatbuilder says that brass and bronze wood screws should be screwed in with a waterproof grease or fat to make them easier to fit and protect them from internal corrosion. I have tried the grease bit and it seems to work but don't know about the corrosion bit although it sounds logical if you are screwing into something like oak. |
File Handle | 01/01/2023 18:49:12 |
250 forum posts | Posted by Dave Halford on 01/01/2023 16:50:27:
The trick for putting brass screws into oak without them breaking was make the hole with a steel one first This was to avoid the blue stains from steel ones that react with the tannin in oak creating a blue stain. |
File Handle | 01/01/2023 18:55:16 |
250 forum posts | Posted by bernard towers on 01/01/2023 18:46:51:
A friend of mine who is a lifetime boatbuilder says that brass and bronze wood screws should be screwed in with a waterproof grease or fat to make them easier to fit and protect them from internal corrosion. I have tried the grease bit and it seems to work but don't know about the corrosion bit although it sounds logical if you are screwing into something like oak. Lubricating any wood screw makes insertion easier. Wax is another lubricant, some do come prewaxed. |
Robert Atkinson 2 | 01/01/2023 22:10:55 |
![]() 1891 forum posts 37 photos | Posted by Michael Gilligan on 01/01/2023 17:58:13:
"8.8 stainless steel bolts" is an oxymoron. Robert. . Oh dear … that’s unfortunate: . . MichaelG. Edited By Michael Gilligan on 01/01/2023 17:58:52 Come back to me when you have a tracable source. That table is titled "stainless steel" but the content says "carbon steel". ASME SA324 does not exist. It is a supplier website of dubious veracity.
Robert. |
Hopper | 02/01/2023 03:42:45 |
![]() 7881 forum posts 397 photos | Posted by Keith Wyles on 01/01/2023 18:55:16:
A friend of mine who is a lifetime boatbuilder says that brass and bronze wood screws should be screwed in with a waterproof grease or fat to make them easier to fit and protect them from internal corrosion. I have tried the grease bit and it seems to work but don't know about the corrosion bit although it sounds logical if you are screwing into something like oak. Lubricating any wood screw makes insertion easier. Wax is another lubricant, some do come prewaxed. My grandfather and my uncle, both master cabinetmakers/carpenters, swore by Brylcreem hair grease back in the 60s. Run the screw through your hair before screwing it in and all was well, apparently. |
Hopper | 02/01/2023 03:45:54 |
![]() 7881 forum posts 397 photos | As for using bolts as stock to turn things out of, seems like they are frequently lousy material to machine. Part of the problem is the thread has been rolled on there, so it is work hardened and not easy to machine. The head has been cold formed out of the original round bar the size of the shank, so it is well work hardened too. The plain shank in between the thread and the head is sometimes OK. I suspect the effect would be worse on brass bolts and screws. |
Michael Gilligan | 02/01/2023 09:14:47 |
![]() 23121 forum posts 1360 photos | Posted by Robert Atkinson 2 on 01/01/2023 22:10:55: . Come back to me when you have a tracable source. That table is titled "stainless steel" but the content says "carbon steel". ASME SA324 does not exist. It is a supplier website of dubious veracity.
Robert. . Hence my comment, Robert I have no intention of ‘coming back to you’ … I was simply quoting something unfortunate. MichaelG. . P.S. __ You might find further entertainment on this page: https://www.steelmetind.com/high-tensile-grade-8-8-bolts.html#chemical Edited By Michael Gilligan on 02/01/2023 09:23:15 |
vic newey | 02/01/2023 10:10:29 |
![]() 347 forum posts 173 photos | In the 1960's the chippies who worked alongside me at a shop fitting company always kept a bar of hard soap to lubricate screws, it something I've continued doing myself, My father was taught this in the RAF as well |
Circlip | 02/01/2023 11:18:35 |
1723 forum posts | 'Dubbin' was the lubricant of choice for woodscrews by my Grandfather. Regards Ian. Edited By Circlip on 02/01/2023 11:39:23 |
Martin Connelly | 02/01/2023 12:35:06 |
![]() 2549 forum posts 235 photos | Hand soap is likely to cause corrosion in some combinations of wood and metal due to it not being PH7 (neutral) and including water in it. I have seen this myself so I would avoid soap and stick with wax or some other plain lubricant. Martin C |
