need some way to do this easily
Simon0362 | 04/11/2022 10:26:26 |
279 forum posts 91 photos | Earlier this year, we had a large fir tree chopped down and the trunk was sliced into a number of "cheeses", some of which were scattered across the garden on request from Madame. The subsequent request is to excavate the cheeses to provide a plant holder The wood is reasonably dry but my attempts with a drill and the largest spade bit I could find are slow and not effective. A router doesn't reach down far enough. My chain saw is only using (dangerously) the tip. I have contelplated a mini tct wood saw blade in an angle grinder but not proceeded any further. Faced with a similar problem to similar dimensions (roughly 0.5m across, depth to say 30cm), how would "YOU" proceed.....? All ideas welcomed! Simon |
Robert Atkinson 2 | 04/11/2022 10:54:09 |
![]() 1891 forum posts 37 photos | You can get wood caring disks for angle grinders. Might be worth a try. Radom example from web: https://www.rutlands.com/sp+more-carving-carving-discs-wood-carving-discs-convex-and-concave-100mm-set-of-2-rutlands%C2%AE+r4200 No idea if the product or seller is any good.... Robert. |
Ady1 | 04/11/2022 11:00:03 |
![]() 6137 forum posts 893 photos | A multi tool would get you in there but it would be a long job Weaken the hole with a long drill bit making x50 holes then carve it out with the chainsaw? Edited By Ady1 on 04/11/2022 11:02:44 |
Michael Gilligan | 04/11/2022 11:00:45 |
![]() 23121 forum posts 1360 photos | A home-brewed ‘core drill ‘ might do the job. MichaelG. |
ega | 04/11/2022 11:03:01 |
2805 forum posts 219 photos | Find someone with a really big wood lathe. |
Ady1 | 04/11/2022 11:05:33 |
![]() 6137 forum posts 893 photos | I would do the job sideways, not vertically btw |
blowlamp | 04/11/2022 11:11:14 |
![]() 1885 forum posts 111 photos | I think a large auger bit would chomp its way through. Use a chain drilling strategy to clear the area and then chisel or burn out what's left.
Martin. |
JasonB | 04/11/2022 11:14:42 |
![]() 25215 forum posts 3105 photos 1 articles | 25mm SDS+ Auger bit and stitch drill a ring around the diameter hole you want. I would go right through probably coming in from each end as it will be quicker and easier than trying to pig out the waste in the middle. If that is not an option then lots of auger holes to remove as much as possible Even with an decent size SDS+ drill you will need to apply a reasonable pressure as the screw point will not draw the bit in to end grain as well as it would side grain. |
Michael Gilligan | 04/11/2022 11:31:31 |
![]() 23121 forum posts 1360 photos | Posted by Michael Gilligan on 04/11/2022 11:00:45:
A home-brewed ‘core drill ‘ might do the job. . By which I mean : a suitably large diameter steel tube, with slices cut from a TCT circular saw blade welded onto the end. It doesn’t need to be very accurately, or prettily, made MichaelG. |
Clive Hartland | 04/11/2022 11:32:50 |
![]() 2929 forum posts 41 photos | Cut the log in half lengthways and proceed from there with the chain saw. Join up the 2 halves with a few stainless steel screws from the ship chandler. |
Tris | 04/11/2022 11:35:02 |
20 forum posts | Perfect job for an adze, or an arbortech carving disc in an angle grinder. |
not done it yet | 04/11/2022 11:37:31 |
7517 forum posts 20 photos | Cut it all the way through and screw on a perforated sheet as the bottom of the “excavation”? |
Bazyle | 04/11/2022 11:48:04 |
![]() 6956 forum posts 229 photos | Wood is more difficult to drill into end grain than sideways. Another approach is a circular saw with a small blade. Tack a stop block over to one edge so the saw is controlled and hold it onto the work at 45 degrees, then lower it into the wood, keep moving round and eventually you get a shallow circular bowl, This gives you a better surface to start drilling outwards at 45 degrees, finally chiselling down wards around the rim. If you can make a starter hole and dry the wood a bit you might be able to start a little fire in the middle and control the burn. |
Paul Lousick | 04/11/2022 11:55:23 |
2276 forum posts 801 photos | Lots of wood carving disks for angle grinders are available on ebay which are made for jobs like that. But use with caution as they are very dangerous |
Jeff Dayman | 04/11/2022 12:22:20 |
2356 forum posts 47 photos | Chainsaw, used carefully. a smaller one will be safer than say a 20" one for this job. |
Lindsay Donaldson | 04/11/2022 13:41:22 |
![]() 8 forum posts | Start a small fire in the centre. Extinguish when it reaches the desired dimensions |
Simon0362 | 04/11/2022 14:08:20 |
279 forum posts 91 photos | Thanks all for your thoughts and ideas. I think I will proceed with the wood carving route. My afforts to date using drilling methods have proved laborious and slow, hopefully this will allow some more speed. Unfortunately lighting open fires around here is strictly forbidden - and whilst I tend to treat such instructions with a certain 'flexibility', our experiences a few years back have encouraged me to follow the rules...this took 4 days to extinguish with 9 water bombers and helicopters plus ground based firefighters and came to around 200m of our house. Concentrates the mind! Wood carving results will be relayed back to the forum! |
Martin Kyte | 04/11/2022 15:19:17 |
![]() 3445 forum posts 62 photos | Bore a 1” hole and enlarge with a chisel. regards Martin |
File Handle | 04/11/2022 15:48:54 |
250 forum posts | I made a nesting box from a log by removing a vertical section, then used a chain saw to hollow out a U shape, then reattached the removed section and added a new bottom piece. But in this case I would tend towards chain drilling with a smaller bit, then use a chisel / gouge to complete the job. Then readd a base with drainage. I have drilled tree stumps to aid rotting, twist drills are best, with a powerful drill.. Perforated metal or plastic would make a good free draining base.. |
Dalboy | 04/11/2022 16:20:28 |
![]() 1009 forum posts 305 photos | Not the best way to dish out a log as it is more likely split very easily and you will end up with two halves. The only wood ideal for end grain turning is something like Yew. But if you know a friendly woodturner who has hollowing tools then that would be ideal it could also be done with a sturdy bowl gouge |
