Clock lubrication
What oil to use
Michael Brett 131/10/2022 19:27:07
59 forum posts
6 photos
Hello all
Just delving into the world of clocks. Can anyone recommend a good general oil for clock lubrication with a uk stockist.
Many thanks.
Bizibilder31/10/2022 19:36:32
173 forum posts
8 photos
If you google "clock oil" you will find several. Cousins, Meadows and Passmore (closed at the moment apparently) John Wardle clocks
JasonB31/10/2022 19:38:59
I use this one on my smaller engines for minimal drag, not tried it on a clock though
Bazyle31/10/2022 19:45:20
6956 forum posts
229 photos
Some time ago when people still used mechanical clocks a repairer told me he loved '3in1' oil. Not because he used it for clocks but other people did so then a little later he got the job of cleaning it and oiling it properly. Modern equivalent is probably WD40, again do not use on clocks.
Fowlers Fury31/10/2022 20:09:53
446 forum posts
88 photos
Generally recognised as the top clock oil is "Moebius 8030" - a Swiss oil which doesn't oxidise leaving a sticky residue as would 3-In-1 and the like.
Not cheap I'm afraid but worth it if you want the best:-
Andrew Tinsley31/10/2022 20:12:27
1817 forum posts
I use silicone oil. The type used in vacuum diffusion pumps. It has a very low vapour pressure and this means that it lasts a long time after application.. It also doesn't oxidise readily, so it doesn't degenerate like a normal oil.
Andrew.
Edited By Andrew Tinsley on 31/10/2022 20:35:43
Martin Kyte31/10/2022 20:25:57
3445 forum posts
62 photos
Cousins offerings
https://www.cousinsuk.com/category/natural-oils
regards Martin
roy entwistle31/10/2022 22:09:21
1716 forum posts
Depends on the clock. A carriage clock will need watch oils on the platform. A French clock possibly likewise. Long case will need something heavier. Suppliers like Cousins, Walsh, Meadow & Passmore or A G Thomas
Huub31/10/2022 23:21:00
220 forum posts
20 photos
When the clock maker stopped maintaining my fathers clock on a yearly base, he gave me some oil and showed me how to oil the clock. I have used this oil for 30 years to oil my fathers clock (and others) and it is still running.
Today it is the first time I looked what type it is. It shows "Shimano selected by Koga". Some kind of bicycle oil?
Michael Gilligan01/11/2022 07:22:55
23121 forum posts
1360 photos
Posted by Huub on 31/10/2022 23:21:00:
Very likely …
https://www.koga.com/en/about-koga/history
… and probably none-the-worse for that.
Nigel Bennett01/11/2022 09:36:02
500 forum posts
31 photos
What you want is this stuff; Proops were selling it a few years ago but I'm not sure if it's still available.
Mark Rand01/11/2022 09:49:04
1505 forum posts
56 photos
Don't use anchor oil. It goes gummy in less than 25 years!
Fowlers Fury01/11/2022 11:00:36
446 forum posts
88 photos
Re: "PROOPS" image above......... was it any good for hens as well?
Samsaranda01/11/2022 11:32:07
1688 forum posts
16 photos
The Moebius clock oil recommended by Fowlers Fury works out at £1,200 per litre when purchased in 20 ml bottle from Amazon, certainly a tad more expensive than 3in1 oil, expensive hobby clocks. Dave W
Fowlers Fury01/11/2022 12:10:18
446 forum posts
88 photos
Re " The Moebius clock oil recommended by Fowlers Fury works out at £1,200 per litre"
Over-oiling is a known cause of clock problems, more so of course with inappropriate oil.
Oil should be applied from a needle just carrying a minute amount to the spindle or oil pit.
In the early 90s I purchased 3 x 1ml of Moebius oil from M & P and after servicing many clocks since then, I have used less than 0.75ml. That part-used bottle shows no crystallisation or gum around the cap after 30 years.
The link I provided earlier to the Fleabay stockist was only to provide information. Other stockists on that site sell Moebius in 1ml bottles for about £8. Scale that up to one litre ............
bernard towers01/11/2022 14:58:33
1221 forum posts
161 photos
you don't have a Ferrari and put Duckams 20/50 in it why would you use inferior oil on something that's taken a good portion of your leisure time making
Mike Poole01/11/2022 15:04:01
3676 forum posts
82 photos
Posted by Nigel Bennett on 01/11/2022 09:36:02:
I thought the original poster wanted something for his timekeeping equipment, this is a more specialist lubrication area.
Michael Brett 101/11/2022 15:20:32
59 forum posts
6 photos
No its certainly CLOCK oil I need. Got some on order now, and yes you are right , its not cheap.
Cheers Mike
DMB01/11/2022 17:53:56
1585 forum posts
Proops "Cock" Oil?
Really?
Seems rather sexist!
Wot about the hens?
duncan webster01/11/2022 18:22:06
5307 forum posts
83 photos
£1200/litre, similar price to printer ink. Sounds like a similar rip off as well. It would be interesting to know what's in it that makes it so expensive. Mermaids tears?
