Jointing/sealing compounds
jon hill 329/10/2022 17:27:33
166 forum posts
40 photos
Is there a sealing compound for plastic parts? I was given a vax carpet cleaner with issues and found the motor shaft was rusty indicating a possible leak from one of the water tanks. Perhaps a defective o-ring seal? Anyway I wondered if anyone new of a jointing compound which might make a better seal with the old ring. I have no idea where to source a replacement o-ring seal and from past experience with oem dealers they can be very expensive for a what should be a penny part. Hence suggestions with sealing/jointing compounds...
noel shelley29/10/2022 17:54:18
2308 forum posts
33 photos
CT1 ! Not cheap but has a long shelf life EVEN AFTER being opened ! less flrxible/stronger than silicon and has 101 uses! Noel.
duncan webster29/10/2022 22:57:58
5307 forum posts
83 photos
It's unlikely to be a non standard o ring. You can get standard rings from a variety of sources, I use simply bearings in leigh.
Howard Lewis30/10/2022 13:12:19
7227 forum posts
21 photos
As long as the solvent (Methyl Chloride ) doesn't affect the plastic, Hylomar will provide a non setting seal, if you can't find a replacement for the O ring..
Wellseal used to be good, but required Trichlorethylene as a solvent, so definitely non preferred!
Bezzer30/10/2022 16:09:40
203 forum posts
16 photos
Easy enough to make your own O ring, just buy a larger diameter ring of the same cross section, cut it down to the right length and a drop of superglue will join the ends it'll save messing with a sealant. It's a none critical use so any difference in hardness shouldn't affect the outcome. Done it plenty of times using larger rings and/or proper O ring nitrile "cord".
Neil A30/10/2022 16:20:42
160 forum posts
Our experience at work with Hylomar was that the solvent would affect the O rings causing them at first to swell then, as the solvent dissipated, they would shrink to a smaller than original diameter and leak. You can try letting the solvent evaporate, but it is a bit of a hit and miss method. Mostly miss in my view and probably best avoided.
A new O ring without any sealing compound is really the way I would go. The old O ring has most likely taken on a permanent set over the years and so has lost all of its nip. I would measure the O ring groove to try and determine what the original size was rather than the old O ring.
Mark Rand30/10/2022 20:43:56
1505 forum posts
56 photos
With Hylomar, it does no harm to allow the solvent to evaporate before closing the joint. Maybe not so good if you're on the clock, but that's how it was meant to be used.
Hopper31/10/2022 03:27:38
7881 forum posts
397 photos
Posted by Mark Rand on 30/10/2022 20:43:56:
I've never used Hylomar on o rings but it definitely works better on the few gaskets I have tried it on if it is allowed to dry out before assembly. Then it works very well on usually problematic gaskets.
Michael Gilligan31/10/2022 06:36:48
23121 forum posts
1360 photos
Posted by jon hill 3 on 29/10/2022 17:27:33:
Predictably enough, Vac appears not to list spares down to o-ring level, but I was curious to know what their pricing might be like … and was reasonably impressed:
https://www.vax.co.uk/spares-and-solutions?product_list_dir=asc&product_list_order=price
David George 131/10/2022 07:13:44
2110 forum posts
565 photos
I would use silicone grease on O rings involved in water sealing especialy if difficult access to replace.
David
Pero31/10/2022 08:27:10
193 forum posts
I agree with David on the use of silicone grease. We always used it on the seals of underwater cameras with great success, but there is one proviso. More is definitely not better. A little on the fingers and run the o ring through to just 'wet' the entire surface and then install. Too much and leaks occur. I am not entirely sure why but in the case of underwater use I think it has something to do with the changes in pressure forcing the excess silicone out of the joint leading to voids and very expensive leaks.
Pero
Bazyle31/10/2022 09:08:37
6956 forum posts
229 photos
Vaseline is perfectly adequate for O-rings where their function is sealing due to their rubbery property. In fact most rubber seals benefit from appropriate liquid or grease application. For example a car oil filter rubber gasket is not a reliable seal if puton nice and clean and dry and the pressurised oil will somehow target one point and push through. However slight wetting of all the sealing faces with oil makes it seal
SillyOldDuffer31/10/2022 09:15:44
10668 forum posts
2415 photos
Posted by Pero on 31/10/2022 08:27:10:
Pero
O-rings seal by squashing into a supportive groove, the shape, size and finish of which is important. I guess the grease, being mobile, provides a seal at low-pressure before the O-ring is fully squeezed into place by the camera going deep, especially if the groove is imperfectly machined or is worn. I believe a wipe of Silicone oil also helps keep O-ring rubber supple. However, I think too much grease in the groove stops the O-ring from deforming correctly under high pressure.
Vic31/10/2022 16:22:50
3453 forum posts
23 photos
I’ve used LS-X on leaks before. Sold at plumbers merchants.
Russell Eberhardt31/10/2022 18:13:49
2785 forum posts
87 photos
Do a search for the size o-ring you need on ebay. That has not let me down.
Russell
Alan Donovan31/10/2022 20:05:22
81 forum posts
41 photos
+1 for ebay.
