Solvent for epoxy adhesive
Andrew Tinsley18/09/2022 12:27:03
1817 forum posts
I mean a solvent that will dissolve STILL RUNNY epoxy, as I doubt there are any for set epoxy!
I need to repair several broken china items. The professionals recommend epoxy adhesives over cyanoacrylate types. I have now obtained some of the recommended specific adhesives, all of which are the slow setting variety. When assembling the broken pieces, I shall definitely find that some epoxy will squeeze out of the joints. I have yet to find any solvent that will remove this. so any help would be much appreciated.
I find that the drawback to model engineering is that family seem to think you can fix anything. I get lumbered with some very difficult repairs. I should really practice the art of telling people NO WAY! But I guess I am too soft!
Andrew.
Martin W18/09/2022 12:46:49
940 forum posts
30 photos
I have in the past used acetone to remove epoxy resins from objects, see this web page.
Hope this helps.
Martin
Peter G. Shaw18/09/2022 12:47:46
1531 forum posts
44 photos
The recommended procedure would appear to be to allow the epoxy to partially set and then use something like a razor blade to carefully cut away the excess adhesive. Methylated Spirits appears to be a solvent when freshly mixed, at least that's what I use to clean spatulas etc.
I quite agree with being lumbered with all sorts of repair jobs. I suppose that's the penalty for being practical! All you can do, I think, is to pretend that your expertise doesn't extend to such matters. Alternatively, start talking vaguely about insurance, ie you don't want to be responsible if it, whatever 'it' may be, fails again.
Good luck,
Peter G. Shaw
John P18/09/2022 13:26:21
451 forum posts
268 photos
You could try on here look in section for "resins"
down the page 2 products for cleaning and thinning resin.
https://www.bucks-composites.com/categories/resins
Martin W18/09/2022 13:30:44
940 forum posts
30 photos
Like Peter I have used methylated spirit to clean epoxy resin from tools before it sets, currently I tend to use IPA, not the beer, isopropyl alcohol as I have a couple of litres to hand.
Cheers
Martin
martin haysom18/09/2022 13:35:03
165 forum posts
it will depend on what glue you are using. read the manufacture paperwork. one i use at work is cleaned off with water. would do you job very well except the colour is a bit off putting, its green
Martin W18/09/2022 13:54:25
940 forum posts
30 photos
One lives and learns, I did not know until reading the the pages you linked to that epoxy resins could be thinned using IPA.
Thanks for that.
Martin
Andrew Tinsley18/09/2022 14:07:58
1817 forum posts
Thanks gentlemen! I do have meths, acetone and IPA to hand so I shall see which is best! I should have tried these solvents before I posted, but I hate unhardened epoxy (I seem to get it everywhere!) So I was put off experimenting.
Thanks again,
Andrew.
1817 forum posts
Thanks again,
Andrew.
pgk pgk18/09/2022 14:36:10
2661 forum posts
294 photos
How about carefully masking the edges of the breaks.. perhaps with a paintable product. Then it's (hopefully) just a matter of trimming down any proud excesses.
old mart18/09/2022 15:25:39
4655 forum posts
304 photos
I have used spray carburettor cleaner to get still sticky epoxy from my fingers. The brake cleaner is not so good.
Norfolk Boy18/09/2022 20:53:30
74 forum posts
18 photos
In Model Radio controlled aircraft I have used Methanol successfully for thinning epoxy and cleaning up.
Richard Marks18/09/2022 21:16:49
218 forum posts
8 photos
I used a thin superglue to repair a broken cup, I put some on each side of the join and let it soak in for a moment before putting it together, it has stayed together and been washed with no problem.
Macolm18/09/2022 21:53:41
185 forum posts
33 photos
Not quite relevant to the present requirement, but many years ago we used a chemical disintegrant for cured epoxy resin. It was Ardrox branded, and various products are still available. I recall that it had a protective liquid floating on top, and the article was hung by a wire through into the active fluid. No doubt something as useful will long since be banned!
Khefin18/09/2022 23:18:40
4 forum posts
Andrew,
A timely request methinks! I can say that after getting that d%mn poxy epoxy on my hands yesterday, surprisingly a vinegar soaked rag removed it swiftly from my mitts, tools and the box the epoxy came in.... I blamed on the wind, as I applied it to the objects outside....
Not really a solvent, but useful stuff!
Seems to have plenty of uses and I recall rather good on the deep fried comestibles laugh In moderation, of course!
Kevin
Jelly18/09/2022 23:19:46
474 forum posts
103 photos
Posted by Macolm on 18/09/2022 21:53:41:
You can still get Epoxy Resin Strippers, not sure if that particular one (Chemset AP 1105) is the one you used, but it seems like it does the same job.
Looking up an SDS it's just 10% Methanol and 90% Dichloromethane, not particularly exotic but definitely the kind of thing which companies have been discouraged from selling to "Joe Public" over time.
Roderick Jenkins19/09/2022 09:16:22
2376 forum posts
800 photos
40+ years ago I was regularly stripping stainless steel mesh from aluminium screen printing frames, glued with a Devcon epoxy. I used a proprietary liquid whose name escapes me but I do remember that it smelt strongly of oil of wintergreen.
Rod
Dick H19/09/2022 11:35:44
141 forum posts
Before it has set much acetone should do the trick. Restorers used to like epoxy for repairing ceramics because it could be removed once set by soaking in pineapple juice. I thought this was an old wives tale or something I half heard on the telly but have a look at < Link >.
Dick
Michael Gilligan19/09/2022 21:07:16
23121 forum posts
1360 photos
Very interesting, and nicely documented, Dick
Funny stuff, pineapple juice … it has some unexpected properties.
Andrew Tinsley19/09/2022 21:37:08
1817 forum posts
Hello Richard,
I too have used thin cyanoacrylate to repair ceramics in the past. Some are still in one piece, but others have failed, washing in hot water seems to destroy the bond overtime.
This is why I did a search for how the professional restorers do repairs to ceramics. They all recommend various two part epoxies for a permanent job, they mostly agree that cyano is more of a temporary repair. My experiences seems to confirm that.
Andrew.
