Here is a list of all the postings Jelly has made in our forums. Click on a thread name to jump to the thread.
Thread: Why do modern car engines have different types of bolt type heads like Torx etc? |
27/07/2023 13:09:15 |
Posted by Ady1 on 27/07/2023 10:01:54:
When I worked the black cabs we got 100,000 out the first clutch with 90% town work then decided to change it so decent drivers do make a difference Brand new car factory stuff also tends to be better quality and more longevitous than the garage OEM stuff you get at repairs time. Even the "branded" stuff can be not really that great When it comes to brakes, clutches, and tyres, the driver's care/skill will always make a far bigger difference than the parts... I have to agree I have found a marked difference in quality between true OEM parts and aftermarket "pattern-parts", but by god do some manufacturers make it awkward to interact with their parts departments and the service offered is dire compared to using a decent auto-factors. |
27/07/2023 12:57:47 |
Posted by JA on 27/07/2023 11:37:06:
Posted by martin perman on 26/07/2023 19:09:37:
My thoughts are its the car makers way of trying to stop the average man fix his own car by making the cost of specialist tools to expensive.
Martin P Agreed. If the car is modern the owner has to be dissuaded from trying to fix his car. All are far too complex for even the service monkeys (I cannot call them anything else) at the dealers to fix. Looking under the bonnet of my 16 month old petrol engined I can recognise the battery. I think there is an engine under a lot of plastic ducting. As for finding and getting at the sparking plugs, forget it. JA
Maybe it's because I started driving when modern engines were already a thing, and started repairing my own vehicles out of economic necessity in a way that pushed me to try things that felt out of my comfort zone... But honestly, it's not nearly as hard as you might be deceived into thinking by appearances! . Sure there's a handful of tasks that need you to plug in a computer (and I do mean a handful), and some emissions system sensor faults which are easier to diagnose if you at least have a cheap code reader box from the auto factors. But even on a modern, ECU controlled engine which is packaged very tightly indeed, there's nothing to stop a mechanically literate person making their own repairs, especially if they have reference to a good workshop manual (ideally the OEM's one), other than having the confidence to try. |
27/07/2023 08:15:35 |
Posted by duncan webster on 26/07/2023 23:15:34:
However, my last 3 cars all were still going strong on the original clutch at over 150,000 miles, so it's a bit academic. I think that's more testimony to you having developed a very measured driving style (and possibly doing the kind of journey that are kindest to clutches); than it is to the quality of modern vehicle clutches. Average clutch lifespan is reported at between 30,000 for drivers in very congested cities, to 100,000 for drivers who drive predominantly outside urban areas, the OEM's target design life is usually for 60,000 miles. |
26/07/2023 22:28:15 |
Posted by Nigel Graham 2 on 26/07/2023 21:49:05:
Vehicles are not only cramped by having to pack more and more stuff in less and less space, (like my workshop but at least that is not hampered by the stylists and "value-engineers"
Not just for assembly but for manufacturing in a more general sense. With a FWD vehicle it would be very possible to put the clutch and housing outboard of the gearbox (rather than between gearbox and engine) using a hollow shaft, this would hugely reduce the expense and difficulty of the most significant wear-part replacement most cars ever receive, without much increase in mechanical complexity. But, you couldn't use that design on a RWD/AWD/4WD vehicle, so suddenly you have to produce two variants of that particular engine if you want to offer those as options... So it's No Bueno, because you're giving up a significant efficiency saving in being able to reuse the same engine in as many models as possible. |
26/07/2023 22:13:36 |
My personal bugbear is not different styles of heads, because as SOD says they're usually selected to serve a functional purpose... It's the fact that many manufacturers seem to mix standards. On pretty much every modern vehicle I have worked on, there has been a nonsensical mix of ISO and DIN, or DIN and JIS preferred sizes, with a few vehicles using all three, sometimes on the same sub-assembly. Which defeats the point of preferred sizes altogether and forces you to have (and if working away from your workshop, carry) significantly more tools than should be required. . Having worked on lots of industrial projects where maintaining standards and designing for maintainability was a big deal, it really feels like sloppy engineering to mix and match like that, especially as there have been no instances I have seen where the size difference between a 12 or 13mm headed M8 bolt (JIS or ISO/DIN), or a 16 or 17mm M10 bolt (ISO or DIN) would make a blind bit of difference to the packaging of the overall assembly. . And don't get me started on reduced head sizes on bleed screws... When you put a 9mm AF external hex on an M12×1 thread with about 20mm of engagement you're just asking for that head to get rounded off the second there's a whiff of corrosion... Also, despite it being a part which is both essential to vehicle functioning and an obvious failure point, you've made it so bizzare that it's nearly unobtainable to the extent that as the vehicle manufacturer you're air-freighting them from the OEM in the far east whenever one is ordered. Not that I'm bitter or anything, honest. |
Thread: Need help with late Stepfathers workshop please |
17/07/2023 12:20:43 |
There have been a number of threads about this over the years, and if you can recruit someone "in the know" to help you it will make things a lot easier. . If your stepfather was a member of any model engineering clubs, I would absolutely start by asking them for help... If not, if you can contact local clubs they will also be quite helpful. . If it is all too much to deal with in the time you have, don't go to a house clearance firm. There are specialist dealers/firms who will take on workshop clearances, who will be both better equipped to move things, and more likely to preserve and re-home the equipment with people who value it. "Home and Workshop Machinery" is the one which jumps out at me, but there are others, they will obviously only pay you a proportion of the full value of the equipment, but that might still be the right choice for you and your family. . If I can find it with the search function I did post some advice on how to advertise equipment to sell, and what to expect when people come to collect, so you're at least mentally prepared for what can (depending on the size and location of the item) be a bit of a palava, and I'll repost here. |
Thread: Boiler makers in 2023 |
13/07/2023 20:11:05 |
Funny Iain mentioned Statfold Barn... A friend of mine contracted with Statfold Engineering to complete part of the overhaul works on his Hunslet, and has been very happy with the workmanship (although also knew them and chose them for that reason). Their "Steam Road Vehicles" page lists boiler work, including new-builds as a service they provide. . More generally there are far more firms who have the capability than who will advertise what you're looking for specifically... It depends what you want exactly mind:
I'd be happy to dig up the names of some firms I've worked with previously if you wanted to approach commercial Pressure Vessel fabricators for comparison quotes. But you would need to be absolutely sure to:
because unlike a specialist they won't catch anything or match your assumptions and will build exactly what you request without querying. |
Thread: What did you do today? 2023 |
13/07/2023 14:53:17 |
I received a nice letter from the IChemE confirming that I have now justified that between my HND, 13 years experience and MSc, I do indeed meet the knowledge and understanding requirements for Chartered Chemical Engineer...
So I can now submit them a new form showing my mentoring program which developed me to an appropriate level to submit the next form.
I really don't think the Engineering Council ever considered that people would apply at different career stages, or how painful they were making it for applicants when they standardised the CEng requirements between institutions. |
06/07/2023 10:58:17 |
Changed the clutch in a Toyota Celica for a friend who was in a real bind. As per every clutch change job ever, changing the clutch was the easy bit... Unlike most clutch jobs, the hard part was releasing what might be a candidate for the "worst designed engine mount bracket ever" nearly 3 hours to get it out of the ridiculously tight gap and release the middle engine support after unbolting it in 10 seconds flat. . There were also a number of bolts that could only be accessed using a 12" extension on a universal joint, on another 12" extension, on the impact gun... Not the best design for maintainability I have ever seen. Really feeling it today at work. |
Thread: Moving my new mill into place |
27/06/2023 14:37:41 |
Posted by Bazyle on 26/06/2023 23:16:24:
If things are too congested for an engine crane it is rather unsafe for multiple people. One option if you have a straight run from the door to the bench is two scaffold planks to make a ramp. Using two makes balancing less risky. Use a hoist or jack to pull the lathe up the ramp. Have the lathe on a sheet of ply not rollers so it can't just roll down if you need to adjust the hoist. The extra friction is of no consequence if you have a good ratio on he hoist or jack. I think there are ways one could do a manual lift safely. Slinging the mill from beneath with a pair of short slings connected with a d-shackle and passing a stout bar or scaffold pole through allows you to get as many people as will fit in the space round it and for them all to have a good grip with no pinch hazards. Assuming the bench isn't too high, and the slings are short, four people lifting and a fifth person controlling the load to prevent swinging would be pretty safe, better still if that fifth person can have some blocks to hand they can slide under allowing the people lifting to reposition between the floor and full height to maximise lifting with their legs and avoid putting their core muscles under too much stress. . If going a manual route the important thing is that everyone knows their limits, knows proper lifting form, and keeps well within both. I remember having ergonomics training where they drilled into us that the oft quoted HSE guideline of 25Kg for a man and 20kg for a woman is based on average people of working age, and that it is perfectly acceptable for someone to lift more if they have a demonstrated ability to do so safely and it's been assessed, but it is also wholly unacceptable to ask someone to lift something they were uncomfortable with just because it was under the guideline number. If in doubt add more people. . Ramps do work really well, but setup is everything because there's a lot of inherent instability in using them. I would personally be inclined to use rollers or a thin sheet of metal to minimise the static friction, having had experiences where a load jerked violently on a ramp when it overcame friction and became unstable. But that then means you do need a progress capture mechanism or a winch/pulley system which can do the whole move in one go, and allows safe lowering. Hiring a Tirfor for the day would give all of that very nicely, and is usually pretty cheap. |
Thread: Cure for Tight Nuts |
26/06/2023 14:48:21 |
Posted by not done it yet on 26/06/2023 08:50:34:
It would be the $20K (note upper case ‘k&rsquo I assume you haven't had to buy spare parts for any large plant equipment recently... The combination of OEM markup (because service is how they make a lot of their money), with logistics costs layered on top if you're not in N. America or W. Europe is a big part of what makes remanufacturing and third-party manufacturing a viable enterprise. That said, the price of an equivalent piece of steel stock to make the rod would be £15 per 25mm (from M-Machine) so even before the hard-chrome, induction hardening, and grinding which could double to treble the price, a 3m long rod is in the region of £1800 (3500 AUD), so even making a replacement rod would start at $7k-$10.5k australian before machining and welding.
This is before accounting for the fact that you might be losing $2k-$4k per day in depreciation alone every day the machine is stood idle, plus the loss of production and/or short term hire-cost which could easily reach tens of thousands of dollars... Edited By Jelly on 26/06/2023 14:57:53 |
26/06/2023 14:26:37 |
Posted by Baz on 26/06/2023 09:14:24:
I have some reservations about turning all the thread off and presumably screwcutting a smaller diameter thread. The original thread was made that diameter for a reason, is it safe to reduce the diameter? As a craft-trained engineering technician with 20 years experience working on that kind of heavy plant, a strong relationship with various OEM's and OEM dealers (to the point of re-manufacturing parts for OEM's prior to delivery to the customer, when machines arrive in Australia with damage from transit) and consent from the owner of a multi-million pound quarrying excavator... I think it's probably reasonable to assume that his decision is rooted in sound engineering practice. If the rod was designed so close to the yield strength that going from 128mm to 125mm on such a long and large thread would be problematic, then I'd say the OEM's design was negligent to begin with Edited By Jelly on 26/06/2023 14:51:42 |
25/06/2023 15:22:07 |
Bottled up a substantial quantity of Sloe Port, and started the last batch of Sloe Gin from last year's haul... That should mature in time to do one final batch of Sloe Port before we get started on the Crabapple Gin which will finish in time for starting the Plum wine before this year's Sloe harvest... I am less clear when or how we're going consume the sheer volume of port, gin and wine being produced, but we can work on that. |
Thread: Hot Weather Workshop Issues |
17/06/2023 22:28:22 |
Posted by DMB on 17/06/2023 20:11:02:
Years ago, I had a hot workshop problem, my nosey cat kept trying to get in the open door, so I had to make a screen to keep him out. Sharp steel swarf on floor and moggie barefoot! My neighbours cat is all too frequently interested in getting close to recently welded or cut steel outside the workshop, he's a very sweet cat and I'd hate for him to get burned in pursuit of a warm place to curl up, so I am forced to sit in a deck chair and distract him with cat toys... The hardship! . As far as keeping workshop temperatures down goes, I bought a pallet of spares and repairs air-con units at an auction some years ago, and managed to assemble 3 working ones from about nine, one lives in my office, one lives in the workshop, and one failed catastrophically during the day that reached 40°C last year. It's probably a luxury, but one I would fully endorse if you have the space. If anyone is tempted:
Thread: 30 Int to Morse No. 2 adaptor |
16/06/2023 00:06:35 |
Posted by Bazyle on 15/06/2023 23:37:34:
Arceuro had int30 adaptors a few years back. |
Thread: Google's Graffitti on 'lathes.co' |
15/06/2023 23:54:32 |
Posted by Nigel Graham 2 on 15/06/2023 23:34:18:
The impression I had was that Google has basically high-jacked it though, and many of the third-party ads seemed to have little or connection with engineering.. That's likely down to your browsing profile (or lack thereof)... Almost every Google ad I see on the site when browsing on my phone or personal laptop is engineering related. However, the adverts are random and a little bizzare if I visit on my work laptop. The difference being that my personal devices are connected to my Google account where I have given them limited permission to collect profiling data to serve relevant adverts (If I'm going to be subjected to them either way, then they might as well at least occasionally show me a thing I might actually want), whilst my work laptop isn't logged in to a google account and has advertising trackers blocked by the security settings, |
Thread: New Toy - Migatronic KME 550 |
15/06/2023 12:39:58 |
Posted by noel shelley on 15/06/2023 12:20:46:
For ali it all depends on the wire thickness as to what type of torch you use. I used 1.2mm with a teflon liner, I think 3m torch. Thinner wire may well need a short feeder or gun feeder. For ali I would go for TIG, unless heavy section. Good luck. Noel. If it's too thin to MIG I'd probably OA weld it, TIG is a skill I have consistently failed to master... And I'm well aware that to most people it sounds crazy to find gas welding aluminium easier, but my fine motor control isn't up to holding a consistent arc length without dipping the tungsten or moving so slowly I blow through.
15/06/2023 12:12:16 |
Posted by SillyOldDuffer on 15/06/2023 11:31:22:
Posted by Jelly on 14/06/2023 23:01:37:
Always extra-satisfying to use a machine to mend itself! Dave
Yeah it is! Although I'm not sure quite what the implications are in this case, I suspect that I probably don't want to put the generator enclosure and chassis into the welding circuit of a machine which is protectively earthed to that self-same chassis... My gut feeling is that it could go badly wrong. A lot of the patching is on panels which I can lift off and do in my booth with the MIG (Halleluja!), but some of the bits of the chassis proper, I may need to do with the stick welder instead. |
15/06/2023 12:00:31 |
Posted by Stueeee on 15/06/2023 11:42:05:
That's an interesting find. Never seen a Migatronic welder in anything other than dull green -my 1980's 180A set- or slightly brighter green, their newer stuff. If you are going to be welding Aluminium, are you going to hope that you don't get a birds nest with the 4 roller setup, or are you going to use a spool gun? I converted my welder for such. The first owner was clearly HSS Hire (it's been blacked out in some places but not well) and it's in HSS's corporate shade of blue, so presumably if you order enough welders at once, Migatronic will paint them a custom colour from the factory... I'm wondering if it's a unit that was on-hire for so long that when the time came to return it at the end of a contract, HSS just sold it to the customer for whatever the remaining book value was to avoid having to deal with collecting and servicing something they no longer wanted on the books... Which would explain how it ended up in storage and being sold for peanuts to me. . For the Alu Welding I'm hoping to be able to get set up with a water-cooled push-pull gun, a friend of a friend has one going spare so I need to go over and see them about it at some point. If that doesn't work out a spool gun like your setup is my fall-back, but I'd have to make a bypass loop for the coolant circuit and use manual settings rather than the synergic mode to avoid the power-source unexpectedly frying the gun with more current than it's rated for. Depending how long it takes, I might get a small spool of Alu wire to give it a go through the wire-feeder, but I'm not holding out hope that it will cope well, with the torch lead itself being 4m and all. |
14/06/2023 23:22:53 |
Posted by Taf_Pembs on 14/06/2023 23:15:27:
Not sounding too bad.. but like me (and most others here I expect) you now need a bigger workshop..!! Be interesting to see how she goes.. Tell me about it, I swear workshop equipment is a hitherto undiscovered type of gas, expanding to fil the space available. An extension is something that I have been working on plans for (there's an additional 4m×3.2m of space I can claim going backwards towards the house before it negatively effects the garden)... But to justify the expense, it will really need to accommodate a dedicated office space as well so I can have my guest room back. Edited By Jelly on 14/06/2023 23:25:04 |
