Member postings for martin haysom
Here is a list of all the postings martin haysom has made in our forums. Click on a thread name to jump to the thread.
Thread: Winter Storage Of Locomotives
04/10/2023 12:06:41
google air line dryers easy and cheap to make. made mine out of "junk" i already had.
Thread: digi phase converter for 10 machines.....
04/10/2023 11:54:55
Posted by Clive Steer on 04/10/2023 10:48:18:
Adding a motor to turn it into a rotary converter improves the phase balance and provides a degree of energy storage beneficial for starting machines with direct on line motors. The downside is that the motor adds a level of noise and inefficiency. Static converters are reasonably tolerant of supply issues that some countries power distribution systems may provide.
could this be done by letting a machine not being used run.
Thread: Speedo gear size
29/09/2023 21:07:39
don't know if this helps, i had the same problem with a ford fix was simple. just changed the gear on the cable. found a calculator on line which told me which gear to use .
Thread: Locktite allowance
22/08/2023 17:15:37
read the spec ,do what it says ,work's every time. must remember to do this myself. used a Loktite recently [ not at home so can't check which one] spec says sets in 1/2 hour but full strength one week
Thread: 24V rectifier for lighting.
21/08/2023 21:15:31
my machine lights are 12v domestic downlights in a bean tin. never had a problem after all i switched the machine on so i know its running and it makes a noise so cannot forget its running. however if it was a problem i would use a 12 volt battery
Thread: Warco WM250V : Tray Cleaning Questions
21/08/2023 20:59:03
only tray i use on my lathe is the one the manufacture put there only get cleaned when it full with my home made scraper which is a mini version of one i have seen at work long L shape bar ,file handle on one end and a bit of flat plate welded on the other. could that thread be 1/2 NPT
Thread: Oceangate structural failure
09/07/2023 13:52:46
the more i hear about this the more i am convinced its was a peise of junk built by a fool
Thread: Soluble cutting oil just floating on water
08/07/2023 18:17:26
as others have said its unlikely to be what it says on the tin. could be previous owner used it as neat cutting oil, got decanted into any available container to get it home wink
Thread: Repair a small cast bell
03/07/2023 10:27:10
just glue it the old crack ment it did dot ring before it got dropped
Thread: Putting on a fine cut..
25/06/2023 15:08:20
working to those limits you will also need a tempture controlled workshop and some very high end machine's. as for measuring equipment i don't know. but i do know it will need calibrating professionally. i have never worked to those limits, however i do work in the aerospace industry where such equipment is the norm.
Thread: Accurate sheet metal cutting
21/06/2023 18:08:42
Posted by R Smith 1 on 21/06/2023 07:44:39:
Hello All.
. It seems that bog standard tin snips are unable to make such cuts without severely bending & deforming the blank.
Thank you.
if used correctly all the distortion will be on the off cut and the job remains flat
Thread: Father's Day
04/06/2023 20:21:01
laughlaughlaugh
Thread: Help Please: Top-Slide Angle Setting.
30/05/2023 10:16:47
i had this problem. your first attempt is on the right track, i my case as the DTI is not turning on the centre line of the top slide i was getting confused adjusting the angle correctly.
Thread: Long span shelving - support material
30/05/2023 09:58:15
Posted by Hopper on 30/05/2023 06:43:52:
Posted by Puddleglum on 29/05/2023 20:54:58:
Posted by martin haysom on 29/05/2023 20:39:22:
could put more than one beam from side to side to increase load capacity
Yes, minimum of 2, maybe 3 or 4. Working out what the minimum needed would be.
Depends entirely on what you plan to store on the shelf. A row of motorbike petrol tanks would be ok with one beam and a sheet of plywood attached to the wall of the shed. A row of truck gearboxes would need a lot more.
the OP did specify the weight .
Thread: New boiler design?
30/05/2023 09:48:05
could not watch all the video." corporate cow poo" we get it all the time at work .good fun to point out to young managers "that's not new we tried that years ago"
29/05/2023 20:39:22
Thread: [Project] Over-Engineered Workshop drawers
29/05/2023 20:26:36
if i read this right you are going to buy a welder to learn to weld to make a hoist to move one lathe. a hoist you most likely will hardly ever use.i hardly ever used my hoist when i was repairing cars its just a waste of space now. i would recommend renting one.
Thread: Which Loctite?
09/05/2023 09:53:43
lots of cheep "loctite" in the bay of fleece its fake. a problem to the aerospace industry but properly OK for ME
Thread: Myford cross slide leadscrew info needed
07/05/2023 20:20:17
Posted by Peter Greene 🇨🇦 on 07/05/2023 19:34:04:
Posted by old mart on 07/05/2023 18:58:06:
. I generally avoid ebay USA sellers because of the postage and possible duty payable. I suppose the duty would not be payable on the carriage rates.
.... but taxes might.
its charged on the total and a admin charge
Thread: Propane regulator needle won't zero
07/05/2023 16:42:31
Posted by Bill Phinn on 07/05/2023 14:38:30:
It's proved difficult finding a replacement gauge as the thread on mine is M9x1.0.
could you make an adaptor
