Chris Murphy | 15/07/2022 10:05:51 |
76 forum posts 63 photos | Hi all, I seem to have a little problem drilling on the lathe. sometimes when I try to drill with the tailstock the drill doesn’t seem to go anywhere and the tailstock starts moving back slightly, even though it’s lock in place. I take it that you drill a pilot hole and then use smaller drill bits until you can use the drill bit for the job in hand. Am I right in thinking this. live got a couple of dormer centre drill bits for the pilot holes. just wondering what the technique is. thanks chris m…… |
Ady1 | 15/07/2022 10:11:48 |
![]() 6137 forum posts 893 photos | Posted by Chris Murphy on 15/07/2022 10:05:51:
sometimes when I try to drill with the tailstock the drill doesn’t seem to go anywhere and the tailstock starts moving back slightly, even though it’s lock in place. chris m…… Means your tailstock isn't locking properly and needs adjusting |
Chris Murphy | 15/07/2022 10:13:20 |
76 forum posts 63 photos | Hi, how do you adjust the tailstock to keep it from moving. chris m…. |
Ady1 | 15/07/2022 10:20:05 |
![]() 6137 forum posts 893 photos | Depends upon your particular machine As a lone hand you have to "know your machine" and learn what they need to function properly Best place tends to be a dedicated website for that machine, in here you will need to tell people details like what lathe it is, pictures etc Edited By Ady1 on 15/07/2022 10:21:35 |
Paul Lousick | 15/07/2022 10:20:36 |
2276 forum posts 801 photos | That's how I drill on a lathe. Centre drill first, then use smaller drills first for big holes. But it takes a lot of force to push the drill, especially if not sharp, more force than is needed when turning between centres. The tailstock on my lathe also slips back sometimes and has to be tightly locked down. Slippery lathe ways do not help but have to be oiled to prevent rust and wear. |
Oldiron | 15/07/2022 10:23:51 |
1193 forum posts 59 photos | Posted by Chris Murphy on 15/07/2022 10:13:20:
Hi, how do you adjust the tailstock to keep it from moving. chris m…. Could be the cam on the lock is worn and needs adjusting. regards |
Ady1 | 15/07/2022 10:25:09 |
![]() 6137 forum posts 893 photos | You also need to learn to sharpen drills properly, look at a drill and know its going to be ok, feel a drill trying to work and know it's not ok, yet more skills only learnt with time and effort Edited By Ady1 on 15/07/2022 10:26:24 |
Thor 🇳🇴 | 15/07/2022 10:33:45 |
![]() 1766 forum posts 46 photos | Posted by Chris Murphy on 15/07/2022 10:13:20:
Hi, how do you adjust the tailstock to keep it from moving. chris m…. If not the cam, check underneath the tailstock. There is probably a nut that you could try tightening 1/6 of a turn and see if that helps. Thor Edited By Thor 🇳🇴 on 15/07/2022 10:34:18 |
Rex Hanman | 15/07/2022 10:35:51 |
121 forum posts 3 photos | Posted by Chris Murphy on 15/07/2022 10:13:20:
Chris, There's usually a plate that sits under the bed, with a threaded bar or bolt passing through it from the tailstock above. Locking the leaver (or tightening the bolt on some lathes) raises the plate to lock the tailstock in position. There's usually a nut to tighten to adjust the locking force, It doesn't take much of a turn to set it correctly. You may have to slide the the tailstock off the bed (or at least partially) to get to the nut. All lathes differ but the principle is basically the same. Good luck!
Y C Lui | 15/07/2022 10:38:47 |
84 forum posts 35 photos | What is the drill size and the material of the workpiece ? If the material is not very hard and the diameter of the drill is not too large then the only explanation is that the drill bit is dull or the tailstock is not properly locked. |
ega | 15/07/2022 10:56:40 |
2805 forum posts 219 photos | Have you checked that the spindle and tailstock centres are in alignment? |
Dave Halford | 15/07/2022 11:53:02 |
2536 forum posts 24 photos | When you've done the bed clamp properly As ega suggests, trap a steel rule between two mt2 centres in tail and headstock and check the alignment. You can't trust the alignment marks as tailstocks on common lathes can get swapped. Make sure the ram clamp is not loose as sometimes they are quite floppy after a lot of use and that lets the drill wander. Lastly if you have the lathe tool height set low the pip left from facing will push the drill off centre. |
Mick B1 | 15/07/2022 12:03:22 |
2444 forum posts 139 photos | Posted by ega on 15/07/2022 10:56:40:
Have you checked that the spindle and tailstock centres are in alignment? Turn a 60 degree included point with the compound slide, stick a dead centre in the tailstock, and bring the points to near-touching. Lock the tailstock and its barrel. Examine the alignment with a jeweller's eyeglass. Adjust with the tailstock side screws - as with the locking levers, designs vary slightly. You can get very close with this method and patience. If you've got a dial gauge plus a test bar that's known to be round, straight and parallel, you can get closer still - but that decision's on balance of time/cost/requirement. |
Nick Clarke 3 | 15/07/2022 12:08:03 |
![]() 1607 forum posts 69 photos | Possibly linked with the issues mentioned above - what material are you trying to drill? Some steels can be difficult! |
Dalboy | 15/07/2022 12:44:20 |
![]() 1009 forum posts 305 photos | I had to do the same as Rex described but found after a while it became loose again but a very small amount of thread lock has now sorted out the problem |
not done it yet | 15/07/2022 12:58:12 |
7517 forum posts 20 photos | [Sigh] When we know what you are actually doing, a sensible response can be made - more info needed! Material, drill size, speed, condition of drill. You are not going to be drilling a 22mm hole in hardened steel at 1000rpm with a blunted drill.
SillyOldDuffer | 15/07/2022 14:17:59 |
10668 forum posts 2415 photos | Posted by Chris Murphy on 15/07/2022 10:05:51: ... sometimes when I try to drill with the tailstock the drill doesn’t seem to go anywhere and the tailstock starts moving back slightly, even though it’s lock in place. I take it that you drill a pilot hole and then use smaller drill bits until you can use the drill bit for the job in hand. Am I right in thinking this. ...Blunt drill and/or difficult metal can cause a properly adjusted tailstock to slip. It can be helped by the operator pushing as he turns the handle, but if the drill is sharp and material cooperative, it's time to look to adjusting the tailstock clamp. It may also require cleaning - a clamp soaked in oil and running on swarf is likely to slide. Run a clean cloth along the underside of the bed where the clamp grips: if it comes out plastered in oil or dirt, consider removing the tailstock and so the clamp can also be cleaned. If that doesn't fix it, check the adjustment. Some tailstock clamps are just pulled tight by a nut on a stud; not much to go wrong. However, because having to spanner the tailstock is a time-waster, it's more usual for a lever on the tailstock to cam the clamp tight. Much faster but can come out of adjustment and be fiddly to reset because the mechanism is often on the crude side. The nuts are adjusted until the cam-lever operates correctly. Loose enough for the tailstock to slide without binding when the lever is off, and tight enough to pull the clamp hard enough to brake the tailstock firmly when the lever is on. Sounds simple but it may take a few attempts to get right especially at first. The cam may allow the stud to slop from side to side, so be prepared to experiment with the angle as well as how the nuts are positioned. With luck simply tightening the nut a little will be enough, but expect fun and games if the tailstock is removed or the adjustment is way off. Opinion on the best way to drill larger holes varies. Everyone agrees always start with a good pilot hole, because they reduce wandering. (Twist drills love to wander). My feeling is it's best to drill the hole full-size in one go because it shares the cutting load across the full edge and big diameter drills are less likely to wander than small ones. But the lathe may not be powerful or stiff enough for this, in which case stepping up is the answer. On the downside, stepping up concentrates wear on the outside of drill tips, and I think using a progression of small drills gives each a chance to decentralise the hole. Twist drills are bendy creatures. There's always a risk the hole won't be straight, and I've had a few dreadful curves! Boring is best when it's important for holes to be straight or diametrically accurate. A twist drill is used to make a hole big enough to take a boring bar, which then opens up the hole as required. Slower, but boring cuts on the rotating axis, doesn't wander, and will cut to any diameter. Tailstock not used! Dave
Edited By SillyOldDuffer on 15/07/2022 14:23:45 |
Y C Lui | 15/07/2022 15:35:51 |
84 forum posts 35 photos | From your other posts it seems that your lathe is a Myford ML7. The tailstock locking mechanism is a bit different from that of my Emco Compact 8 which has got just one nut on the top that need be tightened to lock the tailstock. There is not any adjustment mechanism. On the Myford, it seems that you need to adjust the nut at the bottom : Edited By Y C Lui on 15/07/2022 15:37:05 |
old mart | 15/07/2022 21:16:39 |
4655 forum posts 304 photos | The nut illustrated has to be carefully adjusted as the eccentric turned by the locking lever has a limited throw. It is easy to get it too tight or too slack, Smart & Brown is similar design. |
Nigel Graham 2 | 15/07/2022 23:05:17 |
3293 forum posts 112 photos | As all above really but I'd put Dave Halford's "lastly" , (a pip or tiny dome on the faced end of the work) "firstly" ! It can throw even a good, sharp centre-drill off-course. |
