jiggered lathe
bricky19/04/2022 20:23:34
627 forum posts
72 photos
After making a acme lead screw I decided to make a tap.I chose some silver steel and started to cut the thread ,the silver steel was a big mistake as nearing the end of the first pass there was a horrid noise.I have nackered the tumbler gears,fortunately they are made from a composite material and are designed to destruct under stress to save the lathes gears.Not only have I got to buy new gears but a 5/8" 8Tpi L/h tap too.Don't you just love making a fool of yourself.I hope RDG stock replacement Myford gears.
Frank
Michael Gilligan19/04/2022 20:53:27
23121 forum posts
1360 photos
Do make sure that the gears are cut properly ... from sheet material, NOT rod
There were some dodgy ones on the market a few years back.
[ Tufnol 'Whale Brand' was the original spec, I think ]
https://tufnol.com/tufnol-gears/
Edited By Michael Gilligan on 19/04/2022 20:55:27
peak419/04/2022 21:42:42
2207 forum posts
210 photos
If you have a Facebook account, there's a chap on the Myford group who sells them, cut to the correct pressure angle.
https://www.facebook.com/groups/917590484920210/posts/4730948193584401
He also trades on eBay at a higher price, but make sure you get the correct vendor, as some of the eBay ones are the wrong angle. Not sure he has any listed at the moment though.
Bill
bricky19/04/2022 21:59:06
627 forum posts
72 photos
Thank you both for that info.
frank
Mark Rand19/04/2022 22:00:48
1505 forum posts
56 photos
A few thoughts:-
  • You don't have to buy the tap. Just the replacement gears and then cut another tap.
  • You need to relieve most of the thread behind the cutting edges or it'll rub and take enormous effort (DAMHIKT)*
  • Either take a smaller depth of cut or:-
  • Ease the load by cutting the thread initially with a V (55°/60° etc.) tool first and then finish to the ACME form.
  • The tumbler gears might have been on their last legs anyway. See Michaels comment.
  • Assuming that it's a short bed ML7, then just get the iron tumbler gears and try not to crash the carriage into the chuck laugh.
*Unless you've got a Balzer hob relieving attachment (I need to make one of them).
David George 119/04/2022 22:49:29
2110 forum posts
565 photos
Hi Bricky you should have no problems cutting silver steel. I made a tap for my cross slide bush from silver steel. Turned the thread to depth first then cut the cutting edges followed by hardening and tempering.
David
Hopper19/04/2022 23:49:58
7881 forum posts
397 photos
I wouldn't blame the silver steel. Those Tufnol gears had a limited life by nature. They used them in some GM and Holden car engines in the late 1950s for a while also, to quieten cam drive gear noise. They always failed later in life. Simply not up to it in the long term.
I am not convinced Myford fitted them as a deliberate weak point. I believe they were fitted to the Super 7 so they would run quietly at the S7's higher top rpm of 2,000 vs the old ML7 plugging along at 800rpm. The metal ML7 gears are noisy at that speed already. But new good quality Tufnol gears should keep you going for another 50 years.
Paul Lousick20/04/2022 02:46:21
2276 forum posts
801 photos
When turning an ACME thread DO NOT plunge cut the tool into the work in a square cut by using the cross slide.
Instead turn the compound to a 14.5 degree angle (half of the 29 degrees for an ACME thread) and only use the compound screw to advance the cutter. This reduces the load on the tool as it is only cutting on the leading edge and 1 side, instead of 2 sides.
Lots of Youtube videos showing this method
not done it yet20/04/2022 14:42:39
7517 forum posts
20 photos
Posted by Hopper on 19/04/2022 23:49:58:
Ford used tufnol for the oil pump drive gear, in the 50/60s for their Zephyr/Zodiac V engines. Some failed, but mostly seemed to work OK.
My Raglan has tufnol tumblers. Original ones, AFAiK. One got slightly damaged while in transit but has not deteriorated since. I might blame the silver steel if it was not in the fully annealed state - but that would really be down to operator.🙂
Not particularly added as a weak link (may have been - but why fit two of them?). Much more likely to simply quieten the gear train.
john halfpenny20/04/2022 19:03:44
314 forum posts
28 photos
Ford and Vauxhall used tufnol camshaft gears in the 1920s. Still good in both of mine. A good long lasting solution to quietening gear drives if engineered correctly.
Dave Halford20/04/2022 21:37:13
2536 forum posts
24 photos
Ford used tufnol for the big cam gear in all the essex pattern V4 and V6 till they were superseded by the Cologne V6.
The oil pump drive came off the base of the distributor via a hex rod, which had a nasty habit rounding off the flats.
bricky20/04/2022 22:28:37
627 forum posts
72 photos
Thats good to know David,I checked the set up and as it is a left hand thread I tried the tailstock centre and it was not tight in the centre hole anymore and I think that the thread was forceing the work into the collet causing the work to ocilate and the tool to jam breaking the gears.I have sourced one gear from RDG but they say they are out of stock of the other and won't have another order for two months.
Frank
Michael Gilligan20/04/2022 23:02:09
23121 forum posts
1360 photos
Posted by bricky on 20/04/2022 22:28:37:
Frank
Please forgive what might be seen by some as gratuitous pedantry, Frank
I have just been looking at the RDG website, and cannot find a single reference to Myford [or even ‘Myford-compatible’] tumbler-gears … Can you please confirm what you have sourced, and from whom ?
https://www.rdgtools.co.uk/acatalog/Change-Gears-for-Myford-Lathes.html
Edit: __ corrected typo
Edited By Michael Gilligan on 20/04/2022 23:07:09
peak420/04/2022 23:17:44
2207 forum posts
210 photos
Michael, try the Myford site instead.
They come under headstock, rather than change gears
https://www.myford.co.uk/acatalog/Headstock-Assembly.html
Parts A2006 & A2007. @ £21.22 each.
The chap I linked to earlier on Facebook, was doing them at £25 a pair direct from him, or @ £27 via ebay
https://www.ebay.co.uk/itm/324815202954
Bill
Edited By peak4 on 20/04/2022 23:21:05
Michael Gilligan20/04/2022 23:30:23
23121 forum posts
1360 photos
Posted by peak4 on 20/04/2022 23:17:44:
That is precisely my point, Bill … for which I risk being branded a pedant.
RDG and Myford are two separate limited companies.
Yes, Mr Gregory is involved in both … but they are separate entities.
Edit: __ and yes, they would correctly be listed under ‘headstock’ not under ‘change-gears’ … but, so far as I can see, RDG doesn’t list them anywhere.
Edited By Michael Gilligan on 20/04/2022 23:34:59
Hopper21/04/2022 06:06:14
7881 forum posts
397 photos
On paper they may be two separately listed companies, owned by the same person/s.
But in practice, whenever I order genuine Myford parts from Myford Ltd's own website or Myford's eBay shop, those genuine Myford parts from Myford themselves arrive in a box all clearly labelled and packaged as genuine Myford parts, BUT with the sender clearly listed as RDG Tools Ltd of the very same Mytholmroyd address that Myford operates out of ie Unit 7/8 White Lee / Burnley Road, Mytholmroyd.
They are for all practical purposes the same company operating out of the same premises under the same owner/s, with RDG being the dominant half or parent company according to their customs declaration as the sender of genuine Myford parts.
So if the RDG/Myford industrial complex megacorporation conglomerate or its subsidiary components at Mytholmroyd do not have any more gears in stock on either of their websites or eBay stores, Bricky's option is aftermarket or used parts on eBay and take a chance on the quality. Or use a steel gear if available and keep revs below what sounds safe. If it's an ML7, won't be a problem at its top speed. And one fibre gear will still act as a weak point if that is a concern.
It is worth checking both their company websites and their eBay stores. I have found items in the past listed on one but not the other. So you can get lucky. Usually it is the eBay store that has things that are listed as out of stock on the Myford.co.uk or RDG.co.uk sites, but it can be the other way round too.
Edited By Hopper on 21/04/2022 06:14:25
David George 121/04/2022 06:54:06
2110 forum posts
565 photos
Have a look on here for some spares as well.
https://www.homeandworkshop.co.uk/browse-stock/myford-parts-new/22/
David
Michael Gilligan21/04/2022 07:29:58
23121 forum posts
1360 photos
Posted by Hopper on 21/04/2022 06:06:14:
That’s very interesting, thanks Hopper … and something of which I would obviously have no personal experience.
When I looked at Companies House [a while back], it seemed very clear that there were two distinct Limited Companies: and I have always assumed that this was to the advantage of both.
Michael Gilligan21/04/2022 08:42:10
23121 forum posts
1360 photos
Posted by Michael Gilligan on 20/04/2022 23:30:23:
APOLOGIES
Dyslexia appears to have struck me blush
I think I should have written Dickinson, not Gregory !
Hopper21/04/2022 10:32:57
7881 forum posts
397 photos
Not that I know much about business, but I would assume they were kept as two separate limited companies for administrative reasons. If one went bust it would not take the other down with it. And it would keep the valuable Myford brand intact and reputedly independent. It wouldn't do to have it sharing a website etc with a supplier of import mid-range gear, tainting the image so to speak. Plus I suppose would make it easier to sell the Myford brand/business on in the future if ever required.
