Here is a list of all the postings john halfpenny has made in our forums. Click on a thread name to jump to the thread.
Thread: Cost effective DROs for mills |
27/09/2023 15:25:41 |
Thread: Clarke CL500M Machine Block |
22/09/2023 18:22:05 |
PM sent. |
22/09/2023 16:42:34 |
Where are you Danni. I have one near Coventry. |
Thread: Gib Adjusters and the English Language! |
21/09/2023 07:22:29 |
The questioner asked which we used - dictionaries are collections of all possible words/meanings, and in my opinion an unreliable guide to common use. I have always used jib.
Thread: clarke CL430 lathe |
18/09/2023 17:50:48 |
I think all the lathe threads are metric, so are you sure the pitch of the nut is threads per inch? |
Thread: Calculating valve spring sizes |
01/09/2023 18:44:18 |
Why not look at similar vintage engines?
Thread: I need custard. |
13/08/2023 21:35:15 |
Pearce Duffs custard powder was the best, but it probably contained lots of E numbers which are now banned. I believe the factory in east London burned down, but a version is still available in the Canary islands, of all places. |
Thread: Kennedy Hexacut machine hacksaw |
11/08/2023 16:08:31 |
How about using a poly vee belt inside out, ie driving on the flat side. I've seen this done on slightly larger machines, but the motor pulley of the Hexacut may be a problem because of the small radius? |
Thread: Grinding wheel bores? |
11/08/2023 15:14:00 |
Yes, I've known a few (well, someone had to say it) |
Thread: UKCA and CE Marking of Boilers |
04/08/2023 15:22:03 |
And because of Brexit, we no longer have a say in the CE regulations - another great leap forward for an independant UK. |
Thread: Why do modern car engines have different types of bolt type heads like Torx etc? |
27/07/2023 18:12:24 |
I'm afraid that 'why o why' threads always end this way. |
Thread: Do you need an oil change with less than 10,000 miles in 10 years? |
14/07/2023 22:19:50 |
You are right Duncan. I have a modern V8 petrol that takes fully synthetic oil. At 6000 miles, it looks, smells and feels like new - but I change it for peace of mind and to demonstrate a sevice history. |
14/07/2023 21:25:53 |
I think a lot of the opinions on this thread are based on old experiences back from the seventies or earlier. I would have agreed with them, but for seeing a torn down 100,000 mile petrol engine at Jaguar engineering 10 years ago. I found it hard to comprehend the absolute cleanliness and lack of visible wear on component parts - no carbon build up, and no sludge. Modern oils, fuels and filtration, and tight manufacturing tolerances, make an enormous difference. However, old habits die hard, so I continue with all the good practice mentioned here, and change oil at half the manufacturers recommendation on my current modern. I wonder if it is in fact necessary.
Edited By john halfpenny on 14/07/2023 21:31:34 |
14/07/2023 13:53:13 |
It may surprise you Bruce that many new cars do not have a sump plug. |
Thread: Herringbone Gear |
08/07/2023 11:09:58 |
Citroen (and I think David Brown) made a big thing of this kind of gear, but I havn't seen one on the flank before. They are typically on the circumference to cancel axial thrust forces. |
Thread: Workshop Clock |
05/07/2023 16:31:24 |
Try to get an old Smiths electric (240v). Mine ( a wedding present!) is over 45 years old - never missed a beat, nor has it lost or gained any time. It must be very over-engineered. |
Thread: Identify imperial bolt size |
27/06/2023 16:31:37 |
I keep my metric and imperial electrical socket screws in separate tins since first encountering this 25 years ago. They are not interchangeable. |
Thread: How did early Automatic gear boxes on cars work? |
09/06/2023 17:29:21 |
The AP (Mini) box allowed lower gears 123 to be held and changed manually, or be fully automatic in D. Regrettably never fitted to sports cars, but I did often have an Alfa 2 litre prototype with 4 speed auto transaxle at weekends. Canned by Fiat, but a fabulous machine for visiting my girlfriend, instead of my more mundane transport. My best Preston to Warwick was 1 hour 42 min on a Sunday evening in 1976. |
09/06/2023 11:10:31 |
The beauty of DSG is(was) that 95% of the gearbox is identical to a manual. All that is needed is a quill shaft through the mainshaft cluster and a small wet clutch at the opposite end to the main clutch. So it fitted in the same space as a manual and coukd have the same number of ratios, but of course manuals are no longer required by most users. DSG itself is a very old idea -used by Citroen and others more than 100 years ago. It can give a power on shift - very useful for tractors Edited By john halfpenny on 09/06/2023 11:13:33 |
09/06/2023 09:44:09 |
When I was a development engineer on hydraulic auto gearboxes, the two significant problems were starting from rest, and getting a smooth gear change without flare or tying up (for all oil temperatures and throttle openings). The first was typically solved with torque converter, maybe also fitted with lock-up clutch for the last 5-7% of slip. The latter was addressed by ever more complex valve blocks, but by the early 80's we saw the early use of electronic position control for a manual type clutch, and electronic maps to account for the shift variables. Our prototype DSG on a Ford Fiesta never reached production, but VW did make a big success of it a few years later. I have a modern hydraulic 8 speed auto, and am very impressed with the shift quality under all conditions. It's very difficult to catch out the logic, and the packaging is very impressive.
