Dalboy | 06/02/2022 14:20:34 |
![]() 1009 forum posts 305 photos | I notice that some parts on the Rob Roy need case hardening, I have found some powder in various sizes/weights. Can anyone give me an idea how much it would need to case harden a piece about 2" x 1" X 3/8" not solid, this is to just give an idea how much I will need to order they start from 100g upwards to 1kg from what I have found. If I brought too much how well does it keep or is it something that will keep for a lifetime, what I don't want to do is not order enough at the same time not order way over the top. I should imagine for smaller parts than what I described above I could do multiple items at the same time. This is what I have found from HERE as well as other suppliers, where has anyone brought some from in the past and is that brand any good for home hardening |
Baz | 06/02/2022 15:05:51 |
1033 forum posts 2 photos | I will start off by saying that it keeps for years, mine is 35 years old and still working fine. I used to do a lot of case hardening back then and bought the stuff in I think 10 kilo tins, For Rob Roy bits a tobacco tin full will do, heat the part up until dull red and dip it into the powder, if powder doesn’t stick it’s not hot enough, heat the component for about five minutes, dipping into powder as necessary and then quench in cold water and jobs done, when all the crud is removed you should have a matt grey surface left which hopefully will be glass hard. The longer the job is heated the deeper the case, if you can put it in a furnace that would be ideal but dip and heat method works well, just depends how long you want to stand there twiddling bits around in the flame, don’t do too much of it indoors as the fumes aren’t particularly good for you. |
Clive Hartland | 06/02/2022 15:15:31 |
![]() 2929 forum posts 41 photos | The part to case harden will only get a very thin hard zone. The way to do it is to heat to a red heat and dip into the compound and then back into the flame. A dip in salty water will lso remove most of the compound. Need it harder and deeper, repeat the process. The question of how much you need is a container that it comes in! A more rigourus method for even depth is to put the item in a metal box filled with the compound, sealing if possible. Cook in a flame for a while at above red heat, maybe 15 to 20 minutes, a full quench in cold water will give the best result. The one I use is Kasenit, it is available and comes in 3 or 4 size tins. Varying in price from £9 to £20. Edited By Clive Hartland on 06/02/2022 15:18:58 |
roy entwistle | 06/02/2022 16:06:53 |
1716 forum posts | Clive. I understood that Kasenit is no longer available. I think Blackgates do one Roy |
Baz | 06/02/2022 17:24:53 |
1033 forum posts 2 photos | Kasenit has not been available for years, the modern stuff works equally as well and doesn’t seem to give off such overpowering fumes. I think that wherever you buy from nowadays you are getting the same thing. There used to be two versions of Kasenit, numbers one and two, I don’t know what the difference was, I always used number two, I am sure someone will enlighten me before the day is out. |
Dalboy | 06/02/2022 20:52:59 |
![]() 1009 forum posts 305 photos | Thank you everyone looks like I will buy one a little larger than needed at least I now know it will last |
DMB | 06/02/2022 22:05:23 |
1585 forum posts 1 photos | Ground up bone used to be used - bonemeal from garden centre?? Could be cheaper. I have also seen a recommendation for sugar as that is mainly carbon and it is the carbon that's needed. Don't understand why someone recommended that as it's flammable! |
Clive Hartland | 06/02/2022 22:07:17 |
![]() 2929 forum posts 41 photos | Knighton tools.co.uk seem to have kasenit. |
vic newey | 06/02/2022 22:54:37 |
![]() 347 forum posts 173 photos | Posted by DMB on 06/02/2022 22:05:23:
Ground up bone used to be used - bonemeal from garden centre?? Could be cheaper. I have also seen a recommendation for sugar as that is mainly carbon and it is the carbon that's needed. Don't understand why someone recommended that as it's flammable! ----------------------------------------------------------------- Bonemeal, old leather and other organic stuff was used for case hardening gun parts, however it was not just heating the metal and dipping it like we are talking about above. The parts had to be buried in a tray of bonemeal etc and then had to be kept at red heat for several hours, this not only made a good depth of hardening but also gave the gun parts a nice colour depending on what was used. |
Adrian Nicolson | 06/02/2022 23:08:21 |
13 forum posts | Hi Baz & All, For Info: There were three variants of Kasenit, summarised below: Kasenit No.1 was: "A specially refined Compound recommended for high-class work" Kasenit No.2 was: "For ordinary shop use" Kasenit No.3 was: "For Case Hardening in closed boxes" All the above information was taken directly from my 1971/2 Copy of the: Buck & Hickman Tool Buyers Guide. ...thats back in the days when Tool Catalogs were crammed full of useful and pertinent information... Regards, Adrian
vic newey | 07/02/2022 08:54:53 |
![]() 347 forum posts 173 photos | I've still got some Kasenit from way back in the 1980's, it's not in it's original container which was a yellow tin, it just corroded away so it's been in a plastic container for years. |
SillyOldDuffer | 07/02/2022 10:30:00 |
10668 forum posts 2415 photos | Posted by Baz on 06/02/2022 17:24:53:
... There used to be two versions of Kasenit, numbers one and two, I don’t know what the difference was, I always used number two, I am sure someone will enlighten me before the day is out. I found Safety Data Sheets for №1 and №2. №1 was for fine work and is Potassium Ferrocyanide. №2 was for ordinary work and is Sodium Ferrocyanide. There was a №3 too: heated in closed containers so I guess it was dangerous, and withdrawn many years ago. I couldn't find an SDS for it. Potassium and Sodium Ferrocyanides have similar properties. They're not poisonous, but avoid breathing the hot fumes. Potassium is more expensive than Sodium. Both work by breaking down when heated in contact with Steel to release Carbon and Nitrogen, some of which dissolves into the surface of the steel and hardens it. Carbon and Nitrogen harden in different ways, which is good. Presumably the Potassium salt performs better than Sodium, perhaps because the reaction occurs at a lower temperature. I found an explanation as to why Kasenit disappeared on the Hobby-Machinist forum with the ring of truth. Ferrocyanides are cheaply made from Hydrogen Cyanide, which is extremely poisonous. Suggested that the source of Ferrocyanides dried up when the chemical industry decided shipping Hydrogen Cyanide was too risky and switched to consuming it at the point of production. Unfortunately, there's not much call for Ferrocyanides, so firms like Kasenit couldn't buy cheap Ferrocyanides or make their own. Things may have changed but I couldn't find a supplier of Technical Grade Sodium Ferrocyanide on the web. High purity Food/Lab Grade is available, but at about £5 for 25g it's far too expensive to use as a hardener. I don't know what alternatives to Ferrocyanides are used in case hardening compounds, but there's a wide choice - anything with Carbon or Carbon and Nitrogen in it, like charcoal and leather. Dave
Clive Hartland | 07/02/2022 11:15:13 |
![]() 2929 forum posts 41 photos | As mentioned before I have used a made up hardening compound using old leather cut up into small pieces, heating part and dipping into the mix. It burned well and with two sessions gave a good surface hardness. This part was the indexing lever for a pistol and worked fine for the time I had the pistol. |
KWIL | 07/02/2022 11:39:57 |
3681 forum posts 70 photos | Knighton Tools do not list Kasenit, but BETA, which is what is now generally available. It works OK. EPK and others, Blackgate etc. |
bernard towers | 07/02/2022 11:45:02 |
1221 forum posts 161 photos | As my case hardening is all small parts sub 3 mm I have always had great success with box hardening. The parts come out pristine and a beautiful grey all over |
JA | 07/02/2022 12:05:38 |
![]() 1605 forum posts 83 photos | Dave Thanks for pointing out that Ferrocyanides (and Ferriccyanides) are not poisonous. The Ironcyanide radicals are very strong and can only be broken by high temperatures. They are less toxic than Sodium Chloride and are used to coat table salt to make it free running! I don't think the chemical industry is really worried about moving extreme poisons around the country. They do risk assessments etc. and things like nasty cyanides are destroyed by nature quite rapidly (the bacteria that breaks down cow shit love cyanides). I have seen a railway tanker of HF parked up at Temple Meads, Bristol. It was about 30 years ago but ..... I suspect Kasenit stopped making case hardening compound because there was no demand. I still have my tin of Kasenit, some used, bought about 15 years ago. And it works. JA |
Rick Hann | 07/02/2022 17:09:39 |
21 forum posts | Posted by DMB on 06/02/2022 22:05:23:
Ground up bone used to be used - bonemeal from garden centre?? Could be cheaper. I have also seen a recommendation for sugar as that is mainly carbon and it is the carbon that's needed. Don't understand why someone recommended that as it's flammable! If you decide use bone meal from a garden center, make sure you are well away from civilization. I tried bone meal in a failed attempt at color case hardening. My workshop is in the basement. Before i realized it, the stench was terrible. It took a couple days for the smell to go away and as an aside my wife was pissed. If you use it outside you are likely to hear from the downwind neighbors! Just saying! Rick |
Clive Farrar | 07/02/2022 17:44:47 |
![]() 125 forum posts 41 photos | I am surprised that no one has mentioned charcoal or fire briquettes. As I have a coal fire there is lots of the latter in the coal bunker. Put a piece in some folded over old jeans, whack it plenty of times with a lump hammer. Use the ensuing dust for either dipping or packing.. I tried the dipping method with 3 repeats and it worked for me.
Regards Clive |
Mark Rand | 07/02/2022 18:57:56 |
1505 forum posts 56 photos | Adding barium carbonate to the charcoal wil make it work more rapidly. |
Mike Waldron | 22/12/2022 09:26:54 |
51 forum posts | So - if one is making collets out of mild steel, and then case hardens them …. Is there any need to temper them? after all BMS isn’t brittle, is it?
Mike Edited By Mike Waldron on 22/12/2022 09:27:11 |
