Is this a dog?
AJAX29/01/2022 19:43:37
433 forum posts
42 photos
I'm trying to figure out what this thing is. It's on a Morse taper (obviously) and the two outermost points have a spacing that lacks adjustment. I'm not sure what it could be used for other than maybe a drive dog of some sort. Perhaps it was made for a specific task? If anyone knows, I'd be interested to learn something new.
20220123-211744 20220123-211750 20220123-211804 20220123-211810 20220124-202529 20220124-202538 20220124-202548 20220124-202735 20220124-202745
Chris Gunn29/01/2022 19:47:16
459 forum posts
28 photos
Could it be a trepanning tool?
AJAX29/01/2022 19:49:19
433 forum posts
42 photos
Posted by Chris Gunn on 29/01/2022 19:47:16:
I wondered that at first, but it seems to lack any useful adjustment. And those two points are not ground for cutting.
Clive Foster29/01/2022 19:53:05
3630 forum posts
128 photos
Given the different spacing of the two "points" from the centre I'd guess its for either:-
marking out two concentric rings as a guide to further machining
or
cutting a large diameter but narrow washer from thin sheet material
The points present don't look like cutting edges so making seems more likely.
But its the sort of thing that could be a modification of a no longer needed device to do another job.
Dalboy29/01/2022 21:03:49
1009 forum posts
305 photos
I have seen something similar but the two outer points do not have the sides ground away and also they are on the same plane not offset like your one.
The one I had seen was designed for wood turning and gave a positive grip as a drive centre
MikeK29/01/2022 21:16:28
226 forum posts
17 photos
Posted by AJAX on 29/01/2022 19:49:19:
Remove one of the "cutters" so that the cross bar can adjusted farther out? As mentioned, the "cutters" don't have any cutting geometry, though.
Martin Kyte29/01/2022 22:23:30
3445 forum posts
62 photos
Yes, I'd vote for woodturning driving dog too.
regards Martin
Ady129/01/2022 22:54:43
6137 forum posts
893 photos
Yup. Wood.
Hopper30/01/2022 09:42:10
7881 forum posts
397 photos
Whistle and see if its ears prick up.
Mike Hurley30/01/2022 09:48:42
530 forum posts
89 photos
I agree with Clive. Don't think they are woodturning dog - as he says they are not equidistant from the centre and appear to be adjustable - all wood dogs I've ever used are just on piece. These would appear more suitable for sticking in the tailstock and marking out rings or washers to be cut from stock held in the chuck etc.
regards Mike
Tony Pratt 130/01/2022 10:20:54
2319 forum posts
13 photos
Don't think it's a woodturning dog but as to what it is I'm not sure, the outer points are not very pointy or shaped for cutting.
Tony
Mark Rand30/01/2022 10:24:33
1505 forum posts
56 photos
It's also possible that it was used as an offset centre for taper turning.
Tony Pratt 130/01/2022 10:30:45
2319 forum posts
13 photos
Posted by Mark Rand on 30/01/2022 10:24:33:
How would that work? But maybe.
Tony
not done it yet30/01/2022 11:24:30
7517 forum posts
20 photos
Posted by Hopper on 30/01/2022 09:42:10:
My first thought was perhaps, a close relative of K-9.🙂
Neil Wyatt30/01/2022 16:50:12
19226 forum posts
749 photos
86 articles
It's used in the headstock, and is a device for removing the ties of incautious machinists.
Nicholas Farr30/01/2022 16:59:47
3988 forum posts
1799 photos
Hi Neil, and one might very quickly see the point, close up! devil
Regards Nick.
John Reese30/01/2022 23:10:40
1071 forum posts
I think it i a spur center for wood turning. Used in the headstock.
