Member postings for AJAX
Here is a list of all the postings AJAX has made in our forums. Click on a thread name to jump to the thread.
Thread: Small (20mm 10mm bore pulley) - source of?
03/10/2023 17:25:02
Does it matter if the pulley is aluminium rather than steel? Just curious to know. If I were in this situation, I'd just bodge a temporary one from anything I had to hand, then make a better one.
Thread: Warco Economy Mill
05/09/2023 23:06:20
A-section belt? Bore size? Do you have a lathe?
Edited By AJAX on 05/09/2023 23:06:44
05/09/2023 23:04:27
Posted by jay g on 05/09/2023 21:05:31:
Looking about i see 4 step pulleys around the £30-60 and could knock up a bracket with some plate so not as bad as i thought.
Will keep you all updated as it moves along.
Thanks everyone that replied
Don't pay that much for a pulley. It could be more than you paid for the machine!
Tell me what pulley you need and I'll take a look to see if I have a spare. The price will be reasonable.
Thread: Adcock Shipley 1ES disassembly
04/09/2023 22:36:18
Posted by jason evans on 04/09/2023 19:31:23:
Hi
At some point in the near future I have to disassemble my 1ES into manageable chunks in order to get it down the side of the house and into garage.
im thinking, table off, overarm off, motor out, then removing main column from base. Anyone have experience taking the 1ES apart. I’m sure I could work it out but any help/things to avoid doing would be greatly appreciated
thanks
jay
I bolted mine down to two wooden "skids". That way I can slide a pallet truck under and scoot it around to wherever I need, singlehandedly. Depending on your route this may work for you.
Thread: Help identify collet chuck
25/08/2023 18:15:36
Looks like 40int
25/08/2023 18:13:03
Posted by jason evans on 25/08/2023 06:02:31:
Hi
Just got a deal on an Adcock Shipley 1ES mill. It is 3 phase with work light and coolant pump. After advice on best way to power it from 240v whilst keeping all original switches working as well as the light and coolant.
thanks
jay
I have the same milling machine, with a vertical head. You can run the coolant pump from a single phase supply with the addition of a capacitor. I ripped out the electrics from around the back of the machine, fitted an electrical enclosure, and installed a VFD. This is the cheapest and most flexible option.
Thread: Removing the countershaft pulley speed 10 lathe?
23/07/2023 08:08:06
Have you checked whether there is another grub screw hidden under the first one you already removed?
Thread: How to remove this pulley?
01/07/2023 21:10:15
I have a couple of pullers similar to the ones shown above and they work well with an impact driver.
Thread: Adjusting the horizontal mill
19/04/2023 19:18:35
Posted by Steve355 on 18/04/2023 21:22:24:
Any reason not to go for a 12 pole, 3 phase, 1 hp, 450 rpm motor that popped up on eBay?
12 pole motor
it’s cheaper than the 12” pulley and would provide the “correct” speeds.
Steve
That advert is strange. Many photos, but none of the data plate. Maybe it is 440V only.
Thread: Vee pullies
17/04/2023 13:29:22
I have a collection of used vee pulleys, some of which may be suitable. What bore size, diameter and belt section type do you need?
Edited By AJAX on 17/04/2023 13:29:42
Thread: Quick change toolpost for my Portass PD5
14/11/2022 19:06:19
Posted by Rowan Sylvester-Bradley on 14/11/2022 18:26:49:
Thank you for those answers. In trying to understand whether this will fit, I need to understand the function of the piece of metal ringed in red here:
Toolpost
What is the function of this? Can I remove it? Will the toolpost still work? Or can I make a smaller version of it, that will allow tool holders to be slid down so that they extend below the dovetail on the toolpost?
Thank you - Rowan
That part circled in red (your photo) can be removed and machined as you need. In my case I milled it to fit a slot in a compound slide.
20221114-190139 20221114-190112
Thread: 3 phase motor wiring
03/11/2022 17:31:29
I have a Tech / Techtop motor with similar wires (which I didn't use). I'm reasonably confident the user manual stated they were thermistor connections. A well known supplier of Techtop motors lists "Protective thermistors type PTC (1 per phase)" as a feature. I hope that helps.
Thread: Harrison M300 VFD wiring to include apron control lever
30/10/2022 08:29:18
I plan to convert my Harrison M300 to run from a single to 3-phase VFD drive.
WEG CFW300 IP20 2.2kW 230V 1ph to 3ph AC Inverter Drive, DBr, Unfiltered
CFW300B10P0B2DB20 (13059419)
I have used WEG inverters in several other machines and found the wiring to be very straightforward (start, stop, e-stop, direction and speed control) but the M300 presents a particular challenge and I am interested to know how others have used the apron spindle control lever.
The spindle lever mechanically latches in one of three positions to select forward / stop / reverse. The lever rotates a cam that acts on two micro-switches. Effectively, this whole system acts as a latching switch and not the more appropriate momentary action switch used with most VFD setups. Consider what would happen if the spindle was running and an e-stop was pressed and then cleared. The spindle would start automatically.
I have considered using a PLC or timer relay(s) to convert the switch logic levels to timed pulses, thus simulating the effect of a start / stop push button. However, I wonder if there is a simpler solution that I am ignoring?
Thread: Harrison M300 Lathe VFD and motor options
27/10/2022 13:35:28
Posted by DC31k on 25/10/2022 13:45:49:
Posted by Clive Foster on 25/10/2022 13:33:06:
but look about three screens worth down the page where it shows the Y/YY links.
I think this is the image to which you refer:
https://www.wat.com.tr/UPLOAD/CONTENT/haberler/resim-8-yazisiz.png
So there is no need to access the star point. Both high and low voltage can be achieved from within the terminal box.
Yes, you are quite right. I have rewired the connection box (some of the wiring was "shocking" ) after performing an insulation resistance test and checking each of the windings. Should be good to go next week.
Edited By AJAX on 27/10/2022 13:35:42
27/10/2022 13:32:16
Posted by Tony Ray on 25/10/2022 12:49:59:
I can't really help with the question about the 40% ED only to say that if that's 40% running at full load amps how often would you do that? I don't think I've ever got close to FLA on my M250 and I have taken some serious cuts on it.
Regarding the existing motor maybe your suspicions are correct, mine was made in 1998 and changing the links over to get it in delta was a 10 min job. You might want to consult the Harrison users forum as someone will probably be able to tell you what motor it should have.
I would be tempted to sell some of your motor collection to fund the purchase of a suitable used or new motor.
I doubt I will ever approach 40% FL. As previously mentioned, I have no intention of driving this machine hard and now that I have understood the Y/YY wiring options I'm willing to give it a go before considering alternative motors.
I cleaned up the motor last night and will be refitting it later today. I hope to have a VFD fitted later next week.
Thread: Elliot progress 2gs drill oil
26/10/2022 12:08:56
I can't answer your question but I'd be interested to know how you made the sight glass and the material used.
25/10/2022 09:41:58
Posted by KWIL on 25/10/2022 09:36:36:
I would suggest sticking with the original motor as I have, I run on a dedicated radial. I wrote up a detailed conversion of my M300 in MEW some time ago (2009), using all of the original control functions.
Edited By KWIL on 25/10/2022 09:37:01
I'm not convinced the "original" (existing) motor is original. Looking at the data plate Y/YY and duty cycle, and mess inside the connection box I suspect this has been swapped.
25/10/2022 01:27:06
I've found a couple of useful links
  • https://my.motovario.com/technical-data-2/m/iec/std/catalog/series-and-hookup-a169/
  • https://www.wat.com.tr/baglanti-en/
and it appears the 9-wire motors have the star point "hard wired" in the windings. This may incentivize me to consider using another motor.
9-leads
25/10/2022 01:07:18
Tony, thank you for your reply.
Assuming I keep the existing motor (not yet decided) it will need to be reconfigured delta. Taking a closer look at the motor I see two issues.
Firstly, the motor data plate rating is 40% ED. If I understand correctly, this is a 40% duty cycle assuming full load Please correct me if I am wrong. In other words, the motor could be used at its full rated power for 4 minutes out of every 10 minutes. Without seeing a graph, I am unable to determine the duty cycle at other (more realistic for me) loads. Would it be 80% duty cycle at half power? This could be a problem.
Secondly, the motor connection box is presented with 9 labelled wires. It appears that someone has removed the original connection points and links. U1, V1 and W1 go to the power supply. The remaining 6 wires are paired as follows: U5-U2, V5-V2 and W5-W2. The connection plate identifies 220/440V is possible, as is YY/Y connection. I don't see any reason why this cannot be wired delta when I figure out the connections.
alpac
Thread: Meddings dril tru Bench Drill Repair.
24/10/2022 20:42:49
Posted by bob jenner on 19/10/2022 14:28:43:
Hi, my name is Bob and I live in the West Wickham area.
I would like to ask for help for a part on a Meddings Dril Tru bench drill.
The machine has a serial number DBT 7742, apparently dated back to 1965 !
The part in question is the head clamp device that consists of two pieces of 1/1/4" round material, threaded on one half with 3/8" BSF, and these two halves are pulled together by a handle/rod that passes through them. Each half has an angle cut on it that will make contact with the pillar, once the head has been placed upon it. Turning the screwed rod locks the head.
I intend to make the parts but do not know the the angle to machine.
I have spoken to meddings, but they say that no drawing are available of this part.
Thanks.
Bob, do you want to make it or would you prefer to purchase one if I can find a spare? I have a lot of Meddings spare parts but my home workshop is somewhat chaotic at present due to recent purchases.
