John Smith 47 | 27/10/2021 12:12:50 |
393 forum posts 12 photos | Hello What do you use to stop your steel tools from rusting? (as well as lightly lubricate and clean them)
JasonB | 27/10/2021 12:18:12 |
![]() 25215 forum posts 3105 photos 1 articles | Nothing as they don't Have a look at this recent thread
Edited By JasonB on 27/10/2021 12:19:12 |
Mick B1 | 27/10/2021 12:19:45 |
2444 forum posts 139 photos | For me it's not so much stop them rusting as fix it when they do. I find a patch of green scotchbrite or suchlike with a good spray of WD40 will usually get it off as if it had never been. In the worst cases there's just-visible roughness when the light's in the right direction, but never anything measurable. Perhaps I just don't let it get bad enough. |
martin haysom | 27/10/2021 12:22:50 |
![]() 165 forum posts | a dry workshop |
John Smith 47 | 27/10/2021 12:34:40 |
393 forum posts 12 photos | Posted by JasonB on 27/10/2021 12:18:12:
Edited By JasonB on 27/10/2021 12:19:12 Yes, lots of chat about how to avoid the need... |
peak4 | 27/10/2021 12:42:58 |
![]() 2207 forum posts 210 photos | Line your drawers with VCI paper; If it gets uncomfortable transfer it to your tool boxes. Bill Edited By peak4 on 27/10/2021 12:43:16 |
JA | 27/10/2021 12:54:50 |
![]() 1605 forum posts 83 photos | Although my workshop is dry I use plastic air tight food containers from the local supermarket and small "jam" jars to keep parts safe. I put a little oil in the jars and use vapour plastic bags in the boxes. I have found that VCI paper left a thin green corrosion deposit on brass. I phoned the manufacturer of the paper about this and they were most helpful. They recommended the plastic bags since their paper was not suitable for brass. JA |
John Paton 1 | 27/10/2021 13:00:32 |
![]() 327 forum posts 20 photos | Ambersil corrosion inhibitor - as used by the Navy I believe. It leaves a thin and slightly tacky film so is not great in dusty environments. I apply it using a trigger spray bottle. Last year when I was moving house I had to store my garage and workshop items in a draughty, unheated industrial unit with a leaky roof. Fortunately Ambersil did just what not said on the tin and WD40 seems to clean it off easily now I am 'home and dry'. |
John Smith 47 | 27/10/2021 13:00:46 |
393 forum posts 12 photos | As others have mentioned elsewhere, you need to be careful about using anything completely "air tight" because in colder conditions you run the risk of condensation. |
John Smith 47 | 27/10/2021 13:24:01 |
393 forum posts 12 photos | Posted by peak4 on 27/10/2021 12:42:58:
Line your drawers with VCI paper; If it gets uncomfortable transfer it to your tool boxes. Bill Bill I see you have been fan of Motorex for a while. According to that link it works by leaving "a fine film of oil" behind. Edited By John Smith 47 on 27/10/2021 13:26:58 |
Bo'sun | 27/10/2021 14:54:14 |
754 forum posts 2 photos | Cromwells used to sell Solent corrosion inhibitor but I can't seem to find it, so now use Ambersil. |
Nick Wheeler | 27/10/2021 15:39:24 |
1227 forum posts 101 photos | Have you considered putting reusable desiccant packs in your boxes? |
KWIL | 27/10/2021 15:55:33 |
3681 forum posts 70 photos | Camelia oil leaves a dry film and helps prevent rust. Good for woodworking tools as well. However cannot suggest a "cure" for rusty fingers, fortunately I do not have that problem and do not cause any such marking. |
Oily Rag | 27/10/2021 16:05:22 |
![]() 550 forum posts 190 photos | Rocol Moisture Guard! Green semi drying spray used by most grinding companies to protect finishes which rust surprisingly quickly at this time of year. Good for 5 years - so it says on the tin. Just checked my reground lathe ways, which are in the shed wrapped in grease proof paper, and they are perfect. Cleans off easily with brake cleaner or white spirit. Martin |
DMB | 27/10/2021 16:30:19 |
1585 forum posts 1 photos | Heavily insulated workshop with all machines covered at night with old plastic sheeting and bags that originally contained sand/ ballast/ gardening peat or similar. Some heat on most of year round as if I turn it off, liable to absent mindedly forget to switch back on. One mill has 4 old style lamps, 60W wired in series in a protective wooden box, lathe has tubular heater on thermostat and a timer. Workshop always cosy nothing that's protected rusts. Hygrometer shows 60% humidity this afternoon and temperature 80F. Heat only goes up so high when using machines with heat of the drive motors. Doesn't take long to cover/uncover machines with the plastic sheeting and bags, but I only do the machine that I want to use. Lot of tools kept in spare bedroom with the benefit of central heating. Second mill, bandsaw, massive bench drill, linisher, workbench, all covered but no heater. I find that the 2 machines which are covered and have a heater, keep the whole shed warm - 10 X 8ft, so not a great volume. Cheapest would probably be to oil/lanoline all and cover and check regularly.
Dave Wootton | 27/10/2021 17:18:30 |
505 forum posts 99 photos | Hi John I use a spray called ACF50 I get it from Demon Tweeks, it dries clear and seems to last for ages, originally used it to stop the alloy rims on my motorbike corroding, now use it on everything. I live fairly close to the sea and without using it rust appears very quickly, this does the trick, got a dehumidifier but the salt air used to start corrosion quickly, this seems to stave it off. Dave |
Tim Hammond | 27/10/2021 17:35:02 |
89 forum posts | +1 for ACF 50. I used it extensively when I had a motorbike, but use it now as anti-corrosive / lubricant on virtually everything - in fact I was using it on the catches and hinges on my windows this morning. The makers claim that it's safe with most plastics and rubbers and I have experienced no problems over many years of using the product. Also, like Dave, I live very near to the sea, and it's worked well. |
R Johns | 27/10/2021 18:32:08 |
42 forum posts | My grandads shipwright tools dating from WWII are now in my shed. In addition to a wipe over with oil I have kept up his tradition of keeping moth balls in the tool chest. No idea of the chemistry but I have no rusted tools.
Elmo |
Howard Lewis | 27/10/2021 18:55:25 |
7227 forum posts 21 photos | Spray / wipe with oil, to prevent moisture and air contacting the steel.. For long term storage, intermittent use (Verniers, etc Shouldn't be left outside in boxes!. ) you could use Waxoyl, or Lanolin. Both need warming to thin for easier wiping and coating. Howard. |
Jon Lawes | 27/10/2021 20:35:22 |
![]() 1078 forum posts | I use duck oil, but it would appear I'm on my own on that one! |
