Home Made Lathe, Safe?
Ebay Find
Pete.02/10/2021 17:10:51
910 forum posts
303 photos
Every now and then I see something, and just don't have words to describe.
The bolts coming out the chuck look like a medieval torture device.
I don't mean to be unkind, but this just looks flat out dangerous.
Michael Gilligan02/10/2021 17:33:24
23121 forum posts
1360 photos
At the current bid of £10 someone would probably get a bargain
... as long as they render it down to a collection of components !!
jimmy b02/10/2021 17:50:38
857 forum posts
45 photos
Words fail me!
Jim
Ady102/10/2021 18:06:52
6137 forum posts
893 photos
Looks fine to me
Andrew Johnston02/10/2021 18:16:03
7061 forum posts
719 photos
It's a box chuck, albeit larger than normal. Box chucks are standard accessories for clockmakers and instrument lathes.
JasonB02/10/2021 18:34:45
I should think it would be OK to free hob a few gear ondevil
Ian Parkin02/10/2021 18:34:56
1174 forum posts
303 photos
Interesting use of a variable speed on a single phase induction motor too.
Rob McSweeney02/10/2021 18:42:21
98 forum posts
Posted by Michael Gilligan on 02/10/2021 17:33:24:
Seller has set a reserve "to cover the cost of components" which suggests that - a. buying it as a source of parts won't be an economic proposition, and b. he won't find a buyer.
Dave Halford02/10/2021 18:52:55
2536 forum posts
24 photos
Posted by Ian Parkin on 02/10/2021 18:34:56:
There's probably a trigger off a mains drill somewhere
Ady102/10/2021 19:19:10
6137 forum posts
893 photos
I like the spindle flywheel counterweight
larry phelan 103/10/2021 09:17:19
1346 forum posts
15 photos
At least it,s Made in England. Can,t be that bad.
Tony Pratt 103/10/2021 09:21:18
2319 forum posts
13 photos
Vibration free at 2950 rpm, currently 2 bids maybe sailors looking for a boat anchor?wink 2
Tony
Baz03/10/2021 09:30:13
1033 forum posts
Only thing that puts me off is collection from Kilmarnock, can’t get any fuel to get there!
Peter Cook 603/10/2021 12:18:33
462 forum posts
113 photos
Not sure that's an induction motor as its rated at 2950 rpm. More likely to be a universal brushed motor and the speed controller is probably one of these
Edited By JasonB on 03/10/2021 13:07:25
John Haine03/10/2021 12:26:53
5563 forum posts
322 photos
They don't use universal motors on grinders because of the risk of overspeed and I can imagine a cheap grinder using an induction motor quoting its speed as 2950, synchronous speed being 3000 on 50hz.
noel shelley03/10/2021 12:42:41
2308 forum posts
33 photos
John, Syncronous speed 3000rpm 50hz, slip and losses =2850rpm(or so) for a 2pole motor.on load.Noel.
Peter Cook 603/10/2021 13:04:56
462 forum posts
113 photos
John, Noel - the motor is clearly marked 60Hz 240V, and if you look at the closeup of the speed controller, inside the red box it looks like the one I linked to.
But I must confess I haven't tried my controller ( used for an old electric drill) on an induction motor. I wouldn't expect it to work.
Michael Gilligan03/10/2021 13:28:52
23121 forum posts
1360 photos
Posted by Peter Cook 6 on 03/10/2021 13:04:56:
Presumably the link that Jason removed [see Code of Conduct]
John Haine03/10/2021 13:45:39
5563 forum posts
322 photos
Ah, only looked at the photos on my phone, didn't see the motor plate. But a 240V 60Hz motor in the UK? Where did that come from? I just assumed that the 2950rpm was a bit of typical specmanship. I can imagine that the horrible induction motors used in cheap grinders would "speed control" down to 0 rpm run off one of those controllers, and up to max, just not very linear!!
Edited By John Haine on 03/10/2021 13:47:49
Dalboy03/10/2021 14:13:36
1009 forum posts
305 photos
We had a Black museum when I was at work of some of the things people did to power tool this should have been in that
