What is your favourite "unusual tool that you find useful" ?
John Smith 4704/06/2021 00:32:26
393 forum posts
12 photos
Hi All
OK, I'll go first.
He is my favourite "unusual tool that I find useful":
It is a binocular dissection microscope, in case any of you were wondering.
USE:
It's a simple but amazingly powerful bit of kit that I originally got second hand. We used them a lot at university. In truth I now only use it rather occasionally, as I've started using "Clip On Flip Up Magnifying Reading Glasses" which make you look a bit nuts but are super-useful.  I tend to use "+1.0" or "+2.0"...
...But when you need to see what's REALLY going on when you are working at a small scale - e.g. when you need to do some precision fettling, or what's happening to the blade of your knife, or checking something for micro-cracks, or even remove a pesky splinter from your finger.... nothing else comes close!
Being binocular, everything really 'pops' into 3D and you can work for long periods of time if required...
J
PS In an age of digital everything, it's a refreshing change to use something that is 100% NON-digital! Lovely bit of kit.
Edited By John Smith 47 on 04/06/2021 00:39:36
Luker04/06/2021 07:12:39
230 forum posts
172 photos
Looking forward to this thread!
Here's mine: Its a V-block set that can be used as an angle as well...
James Alford04/06/2021 09:12:14
501 forum posts
88 photos
Old bicycle spokes. It is amazing how often I seem to use one for "something".
James.
Ady104/06/2021 09:27:36
6137 forum posts
893 photos
A steel safe
When I bought the house the owner said do you want it
I said yes. Then thought what a dummy I was to do that.
Now it's an anvil, a welding bench, has a big 5 inch multi-angle vice attached to it and the front door frame is a 2 ton hydraulic press frame
John Smith 4704/06/2021 09:38:56
393 forum posts
12 photos
Ady1 - that's crying out for a photo!
Chris Bradbury04/06/2021 09:55:07
23 forum posts
A small Swiss Army penknife that is on my keyring. I use it everyday from letter opening to peeling fruit. It has a pair of tweezers that are brilliant for splinter removal.
Steve Skelton 104/06/2021 10:57:03
152 forum posts
6 photos
Leatherman Crunch - the ones with "Mole" type locking on the plier jaws. Has got me out of trouble on numerous occasions.
old mart04/06/2021 11:52:21
4655 forum posts
304 photos
In the workshop. I have a magnet on a 2 foot long handle, and a smaller one on a telescopic handle.
Ady104/06/2021 13:25:07
6137 forum posts
893 photos
When it was clean and new
It is no longer clean and new...
Edited By Ady1 on 04/06/2021 13:26:05
Bo'sun04/06/2021 15:51:40
754 forum posts
Posted by James Alford on 04/06/2021 09:12:14:
James.
I agree James, especially the stainless steel ones. Just be aware that some are "double butted" with 2mm dia. ends and a thinner, around 1.8mm, centre section. I kept some non-stainless ones years ago and they just went stupidly rusty.
old mart04/06/2021 16:13:53
4655 forum posts
304 photos
The DT Swiss stainless bike spokes are stronger and harder than the stainless spokes from the 50's and 60's, but not so hard that they won't run through a thread rolling tool if their length needs adjusting. I have a stock of them which gets raided for little jobs occasionally.
Do you have a key for your safe, Ady?
Edited By old mart on 04/06/2021 16:14:58
Robert Atkinson 204/06/2021 17:04:57
1891 forum posts
37 photos
Ice Hockey pucks. They are useful as:
Bench blocks -Easily cut or drilled to hold small parts while fling or drilling - non marking
Hand "mallet" for tapping items into position
Jacking pad under trolley jack - stops marking and is anti-slip.
backing when center-popping / drilling / shaping thin material
Vibration damper eg when milling etc
Cheap enough to be disposable.
Robert G8RPI.
larry phelan 104/06/2021 17:29:37
1346 forum posts
15 photos
I dinna know a Scotsman to refuse anything, and rightly so !
SillyOldDuffer04/06/2021 17:39:40
10668 forum posts
2415 photos
Ady104/06/2021 18:09:27
6137 forum posts
893 photos
Posted by old mart on 04/06/2021 16:13:53:
Around somewhere upstairs
You could actually cut into the back in about 5 minutes flat with an angle grinder
Its a legal safe and they are mainly used as a fire/catastrophic event protection box, the front area frame is 1-2 inches of steel but the rest of the box is pretty weedy 2-5 mm plate, the bottom is probably somewhere inbetween
Weighs about 200+kgs, if it was a proper one it would be nearer half a ton
Nick Wheeler04/06/2021 18:32:11
1227 forum posts
101 photos
Posted by Robert Atkinson 2 on 04/06/2021 17:04:57:
Robert G8RPI.
And a pair of them screwed to a chunk of motorcycle tyre make a good bell silencer:
you can just see the cross cut in the bottom that fits over the ball of the clapper. The whole thing is then rotated to silence the bell when needed. Works well on small bells!
old mart04/06/2021 19:32:01
4655 forum posts
304 photos
Posted by old mart on 04/06/2021 11:52:21:
Iforgot to add my latest telescopic magnet with built in light from Lidl.
Nick Wheeler04/06/2021 20:37:34
1227 forum posts
101 photos
Posted by Steve Skelton 1 on 04/06/2021 10:57:03:
I think the Wave is the best value and most useful tool I've ever bought. It was so essential when I worked as a recovery driver that I couldn't be without it, even after breaking a couple of blades. When I stopped doing that job, I sent it back, and got a new one by return of post. Considering that all three blades were broken due to abuse - like prying off a damaged Krooklok - I thought that was exceptional service.
Neil Wyatt04/06/2021 21:05:53
19226 forum posts
749 photos
86 articles
QCTP Knurling Tool
My crude but effective knurling tool!
Mick B104/06/2021 22:16:57
2444 forum posts
139 photos
Neil said in the Magic Parallel MoleGrip thread that he used a little adjustable when having to use the long arm of a hex key to reach a socket-head screw.
I use a silver steel extension rod I made 20-odd years ago for a drill as an extension lever for the short arm of a hex key when I need to use the long arm to turn a socket screw. I use it whenever I'm mounting or dismounting the Myford vertical slide on my Warco lathe, which is very often.
I can't even get the long arm of the hex key into the screw head concentrically 'cos of the vice on the slide, so I use a ball-ended hex key. Be aware that not all hex keys sold as ball-ended really are. The Lidl variant I have doesn't really work at the 8 or 10 degree angle I have to use - the Rolson does, and has worn well.
